ListFieldConflictFilters
Zusammenfassung
The ListFieldConflictFilters function lists the fields in a versioned feature class, table, or feature service layer that have field conflict filters applied.
Syntax
ListFieldConflictFilters(table)
| Parameter | Erläuterung | Datentyp |
table |
Input geodatabase table, feature class, or feature service layer. |
String |
Rückgabewert
| Datentyp | Erläuterung |
String |
A list containing strings for each field name that has conflict filters applied is returned. |
Codebeispiel
ListFieldConflictFilters example 1
List field conflict filters.
import arcpy
# Get a list of fields with conflict filters applied and print the name.
filteredFields = arcpy.da.ListFieldConflictFilters('C:/MyProject/municipal.sde/Primary_UG')
for field in filteredFields:
print(field)
ListFieldConflictFilters example 2
List the field conflict filters for a feature service.
import arcpy
filteredFields = arcpy.da.ListFieldConflictFilters('https://myserver.com/server/rest/services/MyService/FeatureServer/0')
print(field)
