Distribute a geoprocessing module
Distribute and install a custom geoprocessing module by following standard patterns of distributing Python packages.
This topic follows the foo module example from the Create geoprocessing modules topic.
Distribute a geoprocessing module as a compressed archive
To distribute a geoprocessing module as a compressed archive, archive the module (the foo package, as an example) as a .zip file or other preferred compression format. Then provide the following steps to your audience:
Clone the default ArcGIS Pro conda environment.
Hinweis:
Modifying the ArcGIS Pro default Python environment (
arcgispro-py3) is not advisable and may result in unintended consequences. It is recommended that you only modify a cloned environment.Extract the
foopackage into the clone's site-packages folder (%LocalAppData%\ESRI\conda\envs\<clone_environment_name>\Lib\site-packages).Switch the current ArcGIS Pro conda environment to the cloned environment using the Python Package Manager.
Distribute a geoprocessing module with pip
Geoprocessing modules can be distributed through pip with a wheel file by using the setuptools library.
Hinweis:
To distribute a module with pip, the conda, pip, setuptools, and wheel packages are required in your Python environment. These packages are included with the default ArcGIS Pro Python environment.
Create a wheel file for distribution
A distribution package is required for the foo package so that it can be installed in the Python site-packages directory. With a distribution package, the package can be shared and used by others.
To create a wheel file, complete the following steps:
Create a
setup.pyscript similar to the following:setup.py
Sample code to create a
setup.pyscript.import os from setuptools import setup def read(fname): return open(os.path.join(os.path.dirname(__file__), fname)).read() setup(name='foo', version='1.0', author='Esri', description=("Example for extending geoprocessing through Python modules"), long_description=read('Readme.txt'), python_requires='~=3.3', packages=['foo'], package_data={'foo':['esri/toolboxes/*', 'esri/arcpy/*', 'esri/help/gp/*', 'esri/help/gp/toolboxes/*', 'esri/help/gp/messages/*'] }, )If distributing a geoprocessing module that supports additional languages, the
setupfunction'spackage_dataparameter must include the additional language directories. For example, if including a Spanish localization,setup.pyshould be the following:setup.py for Spanish localization
Sample code for
setup.pyto include Spanish localization directories.import os from setuptools import setup def read(fname): return open(os.path.join(os.path.dirname(__file__), fname)).read() setup(name='foo', version='1.0', author='Esri', description=("Example for extending geoprocessing through Python modules"), long_description=read('Readme.txt'), python_requires='~=3.3', packages=['foo'], package_data={'foo':['esri/toolboxes/*', 'esri/arcpy/*', 'esri/help/gp/*', 'esri/help/gp/toolboxes/*', 'esri/help/gp/messages/*', 'esri/help/es/gp/*', 'esri/help/es/gp/toolboxes/*', 'esri/help/es/gp/messages/*'] }, )The
setup.pybuild script sets several properties and directs the build utility to the package directory. The long description is stored in an accompanyingReadme.txtfile. Thesetup.pyandReadme.txtfiles should be located in thesrcdirectory. For more information on usingsetup(), see Packaging and distributing projects. The directory structure for thefoopackage will be as follows (exclude the additionalesSpanish language folder if only supporting English):Src ├ setup.py ├ Readme.txt └──foo ├ __init__.py ├ bar.py └──esri ├──arcpy │ └ SamplePythonToolbox.py ├──help │ ├──es │ │ └──gp │ │ ├ SamplePythonToolbox_toolbox.xml │ │ ├ SampleTool_SamplePythonToolbox.xml │ │ ├──messages │ │ │ └ messages.xml │ │ └──toolboxes │ │ └ SamplePythonToolbox.xml │ └──gp │ ├ SamplePythonToolbox_toolbox.xml │ ├ SampleTool_SamplePythonToolbox.xml │ ├──messages │ │ └ messages.xml │ └──toolboxes │ └ SamplePythonToolbox.xml └──toolboxes ├ SamplePythonToolbox.pyt ├ SamplePythonToolbox.pyt.xml └ SamplePythonToolbox.SampleTool.pyt.xmlTo build an installer for the
foopackage, run the following command from thesrcdirectory using the command prompt:python setup.py sdist bdist_wheelThe
sdist bdist_wheelcommand createsdist,build, andfoo.egg-infofolders in thesrcparent directory. In thedistfolder, a wheel file namedfoo-1.0-py3-none-any.whlis created. A wheel file can be distributed directly with pip.
Install from a wheel file using pip
After cloning and switching environments, open the Python Command Prompt to install the wheel file directly with pip. Pip will install the wheel file in the active environment.
Run the following command from the Python Command Prompt from the
src\distdirectory:pip install foo-1.0-py3-none-any.whlWhen the
foopackage is installed, the following directory structure will be created in thesite-packagesdirectory (exclude the additionalesSpanish language folder if only supporting English):site-packages └──foo ├ __init__.py ├ bar.py └──esri ├──arcpy │ └ SamplePythonToolbox.py ├──help │ ├──es │ │ └──gp │ │ ├ SamplePythonToolbox_toolbox.xml │ │ ├ SampleTool_SamplePythonToolbox.xml │ │ ├──messages │ │ │ └ messages.xml │ │ └──toolboxes │ │ └ SamplePythonToolbox.xml │ └──gp │ ├ SamplePythonToolbox_toolbox.xml │ ├ SampleTool_SamplePythonToolbox.xml │ ├──messages │ └──toolboxes │ └ SamplePythonToolbox.xml └──toolboxes ├ SamplePythonToolbox.pyt ├ SamplePythonToolbox.pyt.xml └ SamplePythonToolbox.SampleTool.pyt.xmlHinweis:
The
messagesfolder is only present if there are message files in the package.If your computer has restrictions that prohibit running an installation, copying the
foodirectory from thebuild\libdirectory to the%LocalAppData%\ESRI\conda\envs\<environment_name>\Lib\site-packagesfolder will produce the same effect as installing from an archived file. When copying the package manually, it will not be recognized or managed bypip.
Use the geoprocessing module
In ArcGIS Pro, the SamplePythonToolbox tool is available from the Geoprocessing pane and is searchable. The toolbox and tool can also be accessed from arcpy as follows: arcpy.SamplePythonToolbox.SampleTool()
Using ArcGIS Pro and the Python package development process, it is possible to build and distribute a package that extends geoprocessing with custom toolboxes that can be viewed and run from within the ArcGIS system toolboxes and arcpy, and the geoprocessing module can be internationalized to support multiple languages.
