Create lists of data
A common task in a batch processing script is cataloging the available data so it can iterate through the data during processing. ArcPy has a number of functions built specifically for creating such lists.
Function
ListDatasets(wild_card, feature_type)
Returns the datasets in the current workspace
ListFeatureClasses(wild_card, feature_type, feature_dataset)
Returns the feature classes in the current workspace
ListFields(dataset, wild_card, field_type)
Returns a list of fields found in the input value
ListFiles(wild_card)
Returns the files in the current workspace
ListIndexes(dataset, wild_card)
Returns a list of indexes found in the input value
ListRasters(wild_card, raster_type)
Returns a list of rasters found in the current workspace
ListTables(wild_card, table_type)
Returns a list of tables found in the current workspace
ListWorkspaces(wild_card, workspace_type)
Returns a list of workspaces found in the current workspace
ListVersions(sde_workspace)
Returns a list of versions the connected user has permission to use
List functions
The result of each of these functions is a list, which is a list of values. A list can contain any data type, such as a string, which can be, for example, a path to a dataset, field, or row from a table. Once the list is created with the values you want, you can iterate through it in your script to work with each individual value.
Learn more about listing tools, toolboxes, and environment settings
List function parameters
The parameters of these functions are similar. A few, such as ListFields, require an input dataset value, since the items the functions are listing reside in a certain object or dataset. Other functions do not require an input dataset because they list data in the current workspace that are defined in the environment settings. All functions have a wildcard parameter, which is used to restrict the objects or datasets listed by name. A wildcard defines a name filter, and all the contents in the newly created list must pass that filter. For example, you may want to list all the feature classes in a workspace that start with the letter G. The following example shows how this is done:
import arcpy
# Set the workspace. List all of the feature classes that start with 'G'
arcpy.env.workspace = "D:/St_Johns/data.gdb"
fcs = arcpy.ListFeatureClasses("G*")
The list can also be restricted to match certain data properties, such as only polygon feature classes, integer fields, or coverage datasets. This is what the type parameter is used for in all functions. In the next example, the feature classes in a workspace are filtered using a wildcard and a data type, so only polygon feature classes that start with the letter G are in the resulting list:
# Set the workspace. List all of the polygon feature classes that
# start with 'G'
fcs = arcpy.ListFeatureClasses("G*", "polygon")
Using your list
ArcPy uses a Python list type as the returned type for all its list function results, since lists support the flexibility required for data access and multiple data types. A for loop is ideal for working with a list because it can be used to step through the list one item at a time. A for loop iterates through each item in the list. Below is an example of a for loop used to iterate through the list generated in the previous example:
# For each feature class in the list of feature classes
for fc in fcs:
    # Copy the features from the workspace to a folder
    arcpy.management.CopyFeatures(fc, "D:/St_Johns/Shapefiles/" + fc)
Following is another example of how to use an ArcPy list function. The script is used to create raster pyramids for all rasters that are Tagged Image File Format (TIFF) images in a folder.
# Set the workspace. List all of the TIFF files
arcpy.env.workspace = "D:/St_Johns/images"
# For each raster in the list of rasters
for tiff in arcpy.ListRasters("*", "TIF"):
    # Create pyramids
    arcpy.management.BuildPyramids(tiff)
A list provides the opportunity to use and manage the results of a list function in a variety of ways. Lists are a versatile Python type and provide a number of methods (append, count, extend, index, insert, pop, remove, reverse, and sort) that can be used to manipulate and extract information.
For instance, if you want to know how many feature classes you have in a workspace, you can use Python's built-in len function to provide that number.
import arcpy
arcpy.env.workspace = "c:/St_Johns/Shapefiles"
fcs = arcpy.ListFeatureClasses()
# Use Python's built-in function len to reveal the number of feature classes
# in the workspace
fcCount = len(fcs)
print(fcCount)
Tipp:
A list can easily show its contents. Lists can be manipulated with a number of methods, including sort, append, and reverse.
>>> import arcpy
>>> arcpy.env.workspace  = "c:/data/water.gdb"
>>> print(fcs)
['water_pipes', 'water_services', 'water_stations']
>>> fcs.sort(reverse=True)
>>> print(fcs)
['water_stations', 'water_services', 'water_pipes']
As lists are an ordered collection, they also permit indexing and slicing.
>>> print(fcs[0])
water_stations
>>> print(fcs[1:])
['water_services', 'water_pipes']
Searching directories and subdirectories
ArcPy list functions can be used to iterate over a single directory or workspace, but in some cases, iterating through other subfolders and workspaces is necessary. For files, this can be achieved with Python's os.walk function which is used to iterate or walk through folders to find additional subfolders and files. However, os.walk is strictly file based and does not recognize databases and non-file-based data types that are important in ArcGIS. For instance, os.walk will not see raster datasets or other contents in a file geodatabase workspace or a feature dataset.
In the arcpy.da module, the Walk function can also be used to iterate through a directory, and can also look into databases and identify ArcGIS data types.
Walk (top, topdown, onerror, followlinks, datatype, type)
Generates data names in a Catalog tree by walking the tree top down or bottom up. Each directory/workspace in the tree yields a tuple of three (dirpath, dirnames, filenames).
arcpy.da.Walk function
Hinweis:
Unlike the list functions, Walk does not use the workspace environment to identify its starting workspace. Instead, the first starting (or top) workspace that Walk traverses is specified in its first argument, top.
In the following example, the Walk function is used to iterate through a Catalog tree and identifies all polygon feature classes contained within.
Use Walk function to catalog polygon feature classes.
import arcpy
import os
workspace = "c:/data"
feature_classes = []
for dirpath, dirnames, datatypes in arcpy.da.Walk(workspace,
                                                  datatype="FeatureClass",
                                                  type="Polygon"):
    # Append all Polygon feature classes to a list for further processing
    for datatype in datatypes:
        feature_classes.append(os.path.join(dirpath, filename))
In some cases, there may be subdirectories that should be avoided when traversing the Catalog tree, for example, directories of backed-up files. If the topdown argument is True or unspecified, the workspaces can be modified in-place to avoid any undesired workspaces or to add additional workspaces as they are created.
Use the Walk function to catalog raster data. Any rasters in a folder named back_up will be ignored.
import arcpy
import os
rasters = []
for dirpath, dirnames, filenames in arcpy.da.Walk(
        workspace, topdown=True, datatype="RasterDataset"):
    # Disregard any folder named 'back_up' in creating list
    #  of rasters
    if "back_up" in dirnames:
        dirnames.remove('back_up')
    for filename in filenames:
        rasters.append(os.path.join(dirpath, filename))
Example: Using arcpy.da.Walk to analyze data
The Walk function (as well as list functions) is commonly used for processing data in bulk. The following script takes advantage of the arcpy.da.Walk function to analyze all datasets in an enterprise workspace.
import arcpy
import os
# Enterprise workspace to be used
admin_workspace = "Database Connections/tenone@sde.sde"
analyze_contents = []
for dirpath, workspaces, datatypes in arcpy.da.Walk(
        admin_workspace,
        followlinks=True,
        datatype=['Table', 'FeatureClass', 'RasterDataset']):
    # Create full path, and add tables, feature classes, raster datasets
    analyze_contents += [
        os.path.join(dirpath, datatype) for datatype in datatypes]
    # create full path, add the feature datasets of the .sde file
        os.path.join(dirpath, workspace) for workspace in workspaces]
# Run Analyze Datasets on the complete list
arcpy.management.AnalyzeDatasets(admin_workspace,
                                 "SYSTEM",
                                 analyze_contents,
                                 "ANALYZE_BASE",
                                 "ANALYZE_DELTA",
                                 "ANALYZE_ARCHIVE")
Tipp:
By default, sde connection files are not iterated to save from unintentional opening of remote databases. To deliberately iterate through an sde connection file, set the followlinks argument to True.
