UnitConversion
Zusammenfassung
Converts pixels from one unit to another. It supports conversion of distance, speed, and temperature.
Diskussion
For more information about how this function works, see the Unit Conversion raster function.
The referenced raster dataset for the raster object is temporary. To make it permanent, you can call the raster object's save method.
Syntax
UnitConversion(raster, {from_unit}, {to_unit})
Parameter Erläuterung Datentyp
raster
The input raster that will contain the converted units.
Raster
from_unit
The original unit type of the pixels.
  • MetersPerSecond—Meters per second
  • KilometersPerHour—Kilometers per hour
  • Knots—Knots
  • FeetPerSecond—Feet per second
  • MilesPerHour—Miles per hour
  • Celsius—Celsius
  • Fahrenheit—Fahrenheit
  • Kelvin—Kelvin
  • inches—Inches
  • Feet—Feet
  • Yards—Yards
  • Miles—Miles
  • NauticalMiles—Nautical miles
  • Millimeters—Millimeters
  • Centimeters—Centimeters
  • Meters—Meters
The default value is None.
String
to_unit
The converted unit type of the pixels.
  • Knots—Knots
  • Celsius—Celsius
  • Kelvin—Kelvin
  • inches—Inches
  • Feet—Feet
  • Yards—Yards
  • Miles—Miles
  • Meters—Meters
String
Rückgabewert
Datentyp Erläuterung
Raster
The output raster.
Codebeispiel
UnitConversion example 1
This example calculates the input raster from meters per second to kilometers per hour.
from arcpy.ia import *
out_unit_raster = UnitConversion("wind_speed_meter_per_second.tif",
                                 "MetersPerSecond'", "KilometersPerHour")
out_unit_raster.save("C:/arcpyExamples/outputs/wind_speed_km_per_hour.tif")
UnitConversion example 2
This example calculates the input temperature raster from Celsius to Kelvin.
# Import system modules
import arcpy
# Set the analysis environments
arcpy.env.workspace = "C:/arcpyExamples/data"
# Set the local variables
inRaster_File = "temperature_celcius.tif"
from_unit = 'Celsius'
to_unit = 'Kelvin'
# Run UnitConversion function
out_unit_raster = UnitConversion(inRaster_File, from_unit, to_unit)
# Save the output
out_unit_raster.save("C:/arcpyExamples/outputs/temperature_kelvin.tif")
