VectorFieldRenderer
Zusammenfassung
Visualizes flow direction and magnitude information in a raster with vector symbols.
Diskussion
The referenced raster dataset for the raster object is temporary. To make it permanent, you can call the raster object's save method.
Syntax
VectorFieldRenderer(raster, {is_uv_components}, {reference_system}, {mass_flow_angle_representation}, {calculation_method}, {symbology_name})
| Parameter | Erläuterung | Datentyp |
raster |
The input raster. |
Raster |
is_uv_components |
Specifies whether the input components represent U-V, or magnitude and direction.
The default value is None. |
Boolean |
reference_system |
Specifies how the direction component is measured.
The default value is 2. |
Integer |
mass_flow_angle_representation |
Specifies the angle of mass flow.
The default value is From. |
Integer |
calculation_method |
Specifies the thinning method to be used to calculate the magnitude and direction value of a tile.
The default value is Vector Average. |
String |
symbology_name |
Specifies the name of the symbol depicting direction and magnitude.
The default value is Single Arrow. |
String |
Rückgabewert
| Datentyp | Erläuterung |
Raster |
The output raster displayed according to your rendering parameters. |
Codebeispiel
import arcpy
Stretch_raster = arcpy.ia.Stretch(imagePath1, "PercentClip", None, None, None, None, True, 0.25, 0.75, None, None, None)
