LabelClass
Zusammenfassung
Provides access to a layer's label class properties.
Diskussion
The LabelClass object is used for managing labeling properties such as label expressions or SQL queries that are associated with a layer's individual label classes. The listLabelClasses method on the Layer object will return a list of existing LabelClass objects. The createLabelClass method on the Layer object returns a reference to a new LabelClass.
Not all layers support labeling, so it is useful to test this ahead of time using the supports method on the Layer object. For example:
if lyr.supports("SHOWLABELS"):
If this statement is True, you will be able to modify all label class properties.
Hinweis:
With Windows 11, version 24H2, VBScript becomes a feature on demand and requires the VBScript capability.
Do one of the following:
  • Convert the expression type to Python or Arcade. See LabelClass example 4 below.
  • Enable the VBScript optional feature in the Windows system settings.
Eigenschaften
Name Erläuterung Datentyp
expression
(Lesen und schreiben)
A layer's individual label class expression using either a VBScript, JScript, or Python parser associated with the label class.
String
name
A layer's individual label class name.
String
SQLQuery
A layer's individual label class SQLQuery. This is useful for restricting labels to certain features.
String
visible
If True, the label class is visible. If False, it is not visible.
Boolean
Methoden
getDefinition(cim_version)
Returns a label classes' CIM definition.
For more information about working with the CIM and samples, see Python CIM access.
cim_version
A string that represents the major version of the CIM that will be used.
  • V2—The 2.x version of the CIM will be used.
  • V3—The 3.x version of the CIM will be used.
String
Rückgabewert
Datentyp Erläuterung
Object
Returns the CIM definition for a LabelClass.
setDefinition(definition_object)
Sets a label classes' CIM definition.
definition_object
A modified CIM definition object originally retrieved using getDefinition.
Object
Codebeispiel
LabelClass example 1
The following script will print the label class properties for only those layers that have labels turned on and supports the showLabels property.
import arcpy
aprx = arcpy.mp.ArcGISProject(r"C:\Projects\YosemiteNP\Yosemite.aprx")
m = aprx.listMaps("Yosemite National Park")[0]
for lyr in m.listLayers():
        if lyr.showLabels:
            print("Layer name: " + lyr.name)
            for lblClass in lyr.listLabelClasses():
                print("\t Class Name: \t" + lblClass.name)
                print("\t Expression: \t" + lblClass.expression)
                print("\t SQL Query:  \t" + lblClass.SQLQuery)
del aprx
LabelClass example 2
The following script finds a layer named Points of Interest and changes the label class properties for a particular label class named Summit so that not all of the summits are labeled. Only those over 2,000 meters in elevation are labeled.
import arcpy
lyr = m.listLayers("Points of Interest")[0]
  lblClass = lyr.listLabelClasses("Summit")[0]
  lblClass.expression = "Name"
  lblClass.SQLQuery = "Type_ = 'summit' And Elevation > 2000"
  lblClass.visible = True
aprx.save()
del aprx
LabelClass example 3
The following script creates two new label classes using Python and Arcade language options.
p = arcpy.mp.ArcGISProject('current')
m = p.listMaps('Map')[0]
l = m.listLayers('GreatLakes')[0]
#Enable layer labels but toggle off all existing label classes
l.showLabels = True
for lc in l.listLabelClasses():
    lc.visible = False
#Create new Label classes and toggle those on
lc1 = l.createLabelClass(name = 'Small Lakes - Python',
                         expression = '[AREA]',
                         sql_query = 'AREA < 10000',
                         labelclass_language = 'Python')
lc1.visible = True
lc2 = l.createLabelClass(name = 'Large Lakes - Arcade',
                         expression = '$feature.AREA',
                         sql_query = 'AREA > 10000',
                         labelclass_language = 'Arcade')
lc2.visible = True
The following script changes the expression engine language from Arcade to Python. It is also important to change the expression otherwise the newly specified expression engine language won't work properly with the expression.
m = p.listMaps('GreatLakes')[0]
l_cim = l.getDefinition('V3')         #Get Layer CIM definition
lc = l_cim.labelClasses[0]            #Get the first label class
lc.expressionEngine = 'Python'        #From 'Arcade' to Python
lc.expression = '[NAME]'              #From '$feature.NAME' to Python syntax
l.setDefinition(l_cim)                #Set Layer CIM definition
