GetWebToolInfo
Zusammenfassung
Returns the description of the network dataset used for the analysis and the run limits for a tool in the routing utility services registered with your portal or stand-alone ArcGIS Server site.
Diskussion
The GetWebToolInfo function allows you to get the tool limits or information for the network data source used by your portal.
Syntax
GetWebToolInfo(service_name, tool_name, {portal_url})
Parameter Erläuterung Datentyp
service_name
The name of the service containing the web tool.
Valid values are as follows:
  • asyncClosestFacility
  • asyncFleetRouting
  • asyncLocationAllocation
  • asyncODCostMatrix
  • asyncRoute
  • asyncServiceArea
  • asyncVRP
  • syncVRP
The values are case sensitive. A ValueError exception occurs when the service_name value is not in the list of supported values.
String
tool_name
The name of the web tool.
Valid values for each service_name value are as follows:
Field
FindClosestFacilities
asyncFleetRouting
SolveLastMileDelivery
SolveLocationAllocation
asyncODCostMatrix
GenerateOriginDestinationCostMatrix
asyncRoute
FindRoutes
asyncServiceArea
GenerateServiceAreas
asyncVRP
SolveVehicleRoutingProblem
syncVRP
EditVehicleRoutingProblem
The values are case sensitive. A ValueError exception occurs when the tool_name value is not in the list of supported values or the tool_name value doesn't exist for the specified service_name value.
portal_url
The URL of the portal containing the service or a dictionary specifying connection information for a routing service on a stand-alone ArcGIS Server site.
If no value is provided, the active portal URL will be used.
The default value is None.
String
Rückgabewert
Datentyp Erläuterung
Dictionary
The GetWebToolInfo object key-value pairs.
  • isPortal—The GetWebToolInfo dictionary object keys.
  • networkDataset—Provides the information about the network dataset used by the web tool.
  • serviceLimits—Provides the limits for the web tool.
Codebeispiel
GetWebToolInfo example 1
The following code sample shows how to get the maximum number of facilities supported by the Service Area utility service from your active portal.
# The following code sample shows how to get the maximum number of facilities supported by the Service Area utility
# service from your active portal.
import arcpy
# Get the active portal url
portal_url = arcpy.GetActivePortalURL()
print(f"Active portal: {portal_url}")
# Get the tool limits for the tool from the active portal
tool_info = arcpy.nax.GetWebToolInfo("asyncServiceArea", "GenerateServiceAreas")
max_facilities = tool_info["serviceLimits"]["maximumFacilities"]
print(f"Maximum facilities: {max_facilities}")
GetWebToolInfo example 2
The following code sample shows how to print the traffic support type for all the cost attributes from your network data source. The portal URL is specified explicitly.
# The following code sample shows how to print the traffic support type for all
# the cost attributes from the arcgis.com routing service.
import arcpy
    "asyncRoute", "FindRoutes", "https://www.arcgis.com/")
nd_info = tool_info["networkDataset"]
for attribute in nd_info["networkAttributes"]:
    if attribute["usageType"] == "Cost":
        print(f"{attribute['name']}: {attribute['trafficSupport']}")
GetWebToolInfo example 3
The following code sample shows how to call GetWebToolInfo for a routing service on a stand-alone ArcGIS Server site.
Learn more about how to specify a routing service info dictionary
    "asyncODCostMatrix", "GenerateOriginDestinationCostMatrix",
        "utilityUrl": f"https://mysite.mydomain.com/:6443/arcgis/rest/services/MyRouting/NetworkAnalysisUtilities/GPServer",
        "authenticationInfo": {
            "username": "my_username",
            "password": "my_password"
