LastMileDelivery input data types
The input data types that can be specified when performing a last mile delivery analysis are described below.
Hinweis:
The minimum requirements for the Last Mile Delivery solver are one order and one route. Each order and route must have a unique name. The earliest start time, the earliest start date, and the maximum total time are required for each route and can be specified using the EarliestStartTime, EarliestStartDate, and MaxTotalTime attributes on the Routes feature class. These three values can alternatively be specified as the earliestRouteStartTime, earliestRouteStartDate, and maxRouteTotalTime properties of the analysis object.
Orders
These are the orders that will be used as input for the last mile delivery analysis. These are the final customer locations where the routes deliver the packages, or the initial customer location where they are picking up packages for shipment.
The data type supports the following fields:
Field |
Description |
Data type |
The name of the order. The name must be unique. Order names are case sensitive and cannot be empty, even if the order is excluded from the solve operation. This field acts as a primary key and is used as a foreign key to refer to orders in the OrderSpecialties table. |
Text |
The amount of time that will be spent at the network location when the route visits it; that is, the impedance value for the network location. A zero or null value indicates that the network location requires no service time. The unit for this field value is specified by the |
Double |
The beginning time of the time window for the order. This field can contain a null value, which indicates no beginning time. A time window only states when a vehicle can arrive at an order; it doesn't state when the service time must be completed. To account for service time and departure before the time window ends, subtract the The time window fields ( The value for this field can be specified using a The time zone for the value is specified by the |
Date |
The ending time of the window for the order. This field can contain a null value, which indicates no ending time. |
Date |
A time window is considered violated if the arrival time occurs after the time window has ended. This field specifies the maximum allowable violation time for the time window of the order. It can contain a zero value but cannot contain a negative value. A zero value indicates that a time window violation is unacceptable; that is, the time window is hard. Conversely, a null value indicates that there is no limit on the allowable violation time. A nonzero value specifies the maximum amount of lateness. For example, a route can arrive at an order up to 30 minutes beyond the end of the time window. The unit for this field value is specified by the |
Double |
Defines when the item to be delivered to the order will be ready at the starting depot. The order can be assigned to a route only if the inbound arrive time precedes the route's latest start time value; this way, the route cannot leave the depot before the item is ready to be loaded onto it. This field can help model scenarios involving inbound-wave transshipments. For example, a job at an order requires special materials that are not currently available at the depot. The materials are being shipped from another location and will arrive at the depot at 11:00 a.m. To ensure a route that leaves before the shipment arrives isn't assigned to the order, the order's inbound arrive time is set to 11:00 a.m. The special materials arrive at 11:00 a.m., they are loaded onto the vehicle, and the vehicle departs from the depot to visit its assigned orders. The value for this field can be specified using a Notes:
Date |
Defines when the item to be picked up at the order must arrive at the ending depot. The order can be assigned to a route only if the route can visit the order and reach its end depot before the specified outbound depart time. This field can help model scenarios involving outbound-wave transshipments. For instance, a shipping company sends out delivery trucks to pick up packages from orders and bring them into a depot where they are forwarded on to other facilities, en route to their final destination. At 3:00 p.m. every day, a semitrailer stops at the depot to pick up the high-priority packages and take them directly to a central processing station. To avoid delaying the high-priority packages until the next day's 3:00 p.m. trip, the shipping company tries to have delivery trucks pick up the high-priority packages from orders and bring them to the depot before the 3:00 p.m. deadline. This is done by setting the outbound depart time to 3:00 p.m. The value for this field can be specified using a Notes:
Date |
The size of the delivery. You can specify size in dimensions such as weight, volume, or quantity. If there are multiple delivery quantities, specify them using the Enter delivery quantities without indicating units. For example, if a 300-pound object needs to be delivered to an order, enter 300. You will need to remember that the value is in pounds. Ensure that the If any of the The default is 0. Delivery quantities can't be negative. |
Double |
The size of the pickup. You can specify size in dimensions such as weight, volume, or quantity. If there are multiple pickup quantities, specify them using the These fields are analogous to the If any of the The default is 0. Pickup quantities can't be negative. |
Double |
Specifies the anchoring rule for the order, indicating that it must be the first or last order on a route. The field value is specified as one of the following integers (use the numeric code, not the name in parentheses):
If the order is additionally constrained to a specific route, that can be controlled using the |
Long |
Specifies the rule for assigning the order to a route. The field value is specified as one of the following integers (use the numeric code, not the name in parentheses):
Long |
The name of the route to which the order is assigned. This field is used to preassign an order to a specific route. It can contain a null value, indicating that the order is not preassigned to any route, and the solver identifies the best possible route assignment for the order. If this is set to null, the The |
Text |
This indicates the sequence of the order on its assigned route. This field is used to specify the relative sequence of an order on the route. This field can contain a null value specifying that the order can be placed anywhere along the route. The input sequence values are positive and unique for each route (shared between depot visits and orders) but do not need to start from 1 or be contiguous. |
Long |
Specifies the direction a vehicle may arrive at and depart from the order. The field value is specified as one of the following integers (use the numeric code, not the name in parentheses):
The |
Long |
The direction in which a point is moving. The units are degrees and are measured clockwise from true north. This field is used in conjunction with the Bearing data is usually sent automatically from a mobile device equipped with a GPS receiver. Try to include bearing data if you are loading an input location that is moving, such as a pedestrian or a vehicle. Using this field tends to prevent adding locations to the wrong edges, which can occur when a vehicle is near an intersection or an overpass, for example. Bearing also helps the tool determine on which side of the street the point is. |
Double |
The bearing tolerance value creates a range of acceptable bearing values when locating moving points on an edge using the The units are in degrees, and the default value is 30. Values must be greater than 0 and less than 180. A value of 30 means that when Network Analyst attempts to add a network location on an edge, a range of acceptable bearing values is generated 15 degrees to either side of the edge (left and right) and in both digitized directions of the edge. |
Double |
This field is only used in the solve process if the The time units of |
Double |
Network location fields
Together, these properties describe the point on the network where the object is located. |
Depots
The input is one or more depots for the given last mile delivery analysis. A depot is a location that a vehicle departs from at the beginning of its workday and returns to at the end of the workday. Vehicles are loaded (for deliveries) or unloaded (for pickups) at depots. For the Last Mile Delivery solver, the routes must all start at the same depot location and must all end at the same depot location. However, the start and end depot locations can be different or can be modeled as virtual depot locations not explicitly specified in the problem.
Field |
Description |
Data type |
The name of the depot. The Depot names are case sensitive and must be nonempty and unique. |
Text |
Specifies the direction a vehicle may arrive at and depart from the depot. The field value is specified as one of the following integers shown in parentheses (use the numeric code, not the name in parentheses):
The |
Long |
Double |
Double |
Double |
Routes
Specifies one or more routes that describe vehicle and driver characteristics. A route can have start and end depot service times, a fixed or flexible start time, time-based operating costs, distance-based operating costs, multiple capacities, various constraints on a driver's workday, and so on.
Hinweis:
Unlike other data types, such as Orders and Depots, this data type is a table and does not include any location information.
Field |
Description |
Data type |
The name of the route. This field is the primary key and is used as a foreign key in the Route names are case sensitive and cannot be empty, even if the route is not part of the solve operation. The name must be unique. |
Text |
The name of the starting depot for the route. This field is a foreign key to the All routes must have the same starting depot. They can all be the same location specified in the If the Virtual start depots are not allowed if orders or depots are in multiple time zones. If the route is making deliveries and |
Text |
The name of the ending depot for the route. This field is a foreign key to the All routes must have the same ending depot. They can all be the same location specified in the If the route is making pickups and |
Text |
The service time at the starting depot. This can be used to model the time spent loading the vehicle. This field can contain a null value; a null value indicates zero service time. The unit for this field value is specified by the The service times at the start and end depots are fixed values (the |
Double |
The service time at the ending depot. This can be used to model the time spent unloading the vehicle. This field can contain a null value; a null value indicates zero service time. The unit for this field value is specified by the The service times at the start and end depots are fixed values (the |
Double |
The earliest allowable starting date for the route. This is used by the solver in conjunction with the Either this field or the When using inputs across multiple time zones, the time zone for the |
Date Only |
The earliest allowable starting time of day for the route. This is used by the solver in conjunction with the Either this field or the When using inputs across multiple time zones, the time zone for the |
Time Only |
Indicates how long after the earliest allowed route start time the route can start. The value can be null or zero, which means that there is no flexibility in the starting time, or it can be a positive number. The unit for this field value is specified by the |
Double |
The amount of travel time needed to accelerate the vehicle to normal travel speeds, decelerate it to a stop, and move it off and on the network (for example, in and out of parking). By including an The cost for this attribute is incurred between visits to noncoincident orders and depots. For example, when a route starts from a depot and visits the first order, the total arrive/depart delay is added to the travel time. The same is true when traveling from the first order to the second order. If the second and third orders are coincident, the For example, there are five coincident orders in a high-rise building, and they are serviced by three different routes. This means three arrive/depart delays are incurred; that is, three drivers need to separately find parking places and enter the same building. However, if the orders can be serviced by one route instead, only one driver needs to park and enter the building, and only one arrive/depart delay is incurred. Since the solver tries to minimize cost, it attempts to limit the arrive/depart delays and identify the single-route option. (Multiple routes may need to be sent when other constraints—such as specialties, time windows, or capacities—require it.) The unit for this field value is specified by the |
Double |
The maximum amount (for example, volume, weight, or quantity) that can be carried by the vehicle. If there are multiple capacities, specify them using the Enter capacities without indicating units. For example, if the vehicle can carry a maximum of 40,000 pounds, enter 40000. You need to remember that the value is in pounds. Ensure that the Capacities can't be negative. A null value is equivalent to infinity. Achtung:The solver only performs a simple Boolean test to determine whether capacities are exceeded. If a route's capacity value is greater than or equal to the total quantity being carried, it is assumed the cargo fits in the vehicle. This may be incorrect, depending on the actual shape of the cargo and the vehicle. For example, the solver allows you to fit a 1,000-cubic-foot sphere into a 1,000-cubic-foot truck that is 8 feet wide. In reality, however, since the sphere is 12.6 feet in diameter, it won't fit in the 8-foot wide truck. |
Double |
A fixed monetary cost that is incurred only if the route is used in a solution (that is, it has orders assigned to it). This field can contain null values; a null value indicates zero fixed cost. This cost is part of the total route operating cost. |
Double |
The monetary cost incurred—per unit of work time—for the total route duration, including travel times as well as service times and wait times at orders and depots. This field can't contain a null value and has a default value of 1.0. The unit for this field value is specified by the |
Double |
The monetary cost incurred—per unit of distance traveled—for the route length (total travel distance). This field can contain null values; a null value indicates zero cost. The unit for this field value is specified by the |
Double |
The duration of regular work time before overtime computation begins. This field can contain null values; a null value indicates that overtime does not apply. For example, if the driver is to be paid overtime when the total route duration extends beyond eight hours, The unit for this field value is specified by the |
Double |
The monetary cost incurred per time unit of overtime work. This field can contain null values; a null value indicates that the |
Double |
The maximum allowable number of orders on the route. A null value indicates that there is no constraint on the number of orders a route can visit in a day. |
Long |
The maximum allowable route duration. The route duration includes travel times as well as service and wait times at orders and depots. Either this field or the The unit for this field value is specified by the |
Double |
The maximum allowable travel time for the route. The travel time includes only the time spent driving on the network and does not include service or wait times. This field can contain null values; a null value indicates that there is no constraint on the maximum allowable travel time. This field value can't be larger than the The unit for this field value is specified by the |
Double |
The maximum allowable travel distance for the route. This field can contain null values; a null value indicates that there is no constraint on the maximum allowable travel distance. The unit for this field value is specified by the |
Double |
The name of the zone that will be used for this route to specify its work territory. The This field can contain null values, which indicates that there is no route zone for this route. |
Text |
A Boolean value indicating a hard or soft route zone. A value of 1 (true) indicates that the route zone is hard; that is, an order that falls outside the route zone polygon can't be assigned to the route. This is the default. A value of 0 (false) indicates that orders that fall outside the route zone polygon can still be assigned, but the cost of servicing the order is weighted by a function that is based on the Euclidean distance from the route zone. As the straight-line distance from the soft zone to the order increases, the likelihood of the order being assigned to the route decreases. |
Long |
Specifies whether the route can be used when solving the problem. This field is constrained by a domain of values that are listed below (use the numeric code, not the name in parentheses).
Long |
Zones
Delineates work territories for given routes. A route zone is a polygon feature used to constrain routes to servicing only those orders that fall within or near the specified area. The following are examples of when route zones may be useful:
Some of your employees don't have the required permits to perform work in certain states or communities. You can create a hard route zone so they only visit orders in areas where they meet the requirements.
One of your vehicles breaks down frequently and you want to minimize response time by having it only visit orders that are close to your maintenance garage. You can create a soft or hard route zone to keep the vehicle nearby.
The data type supports the following field:
Field |
Description |
Data type |
The name for the zone. Names are case sensitive, cannot be empty, and must be unique. This field is the primary key and is used as a foreign key in the |
Text |
OrderSpecialties
The OrderSpecialties and RouteSpecialties classes list the specialties that can be required by orders and supported by routes. A route can service an order only if it supports all the specialties required for that order.
For example, an order may require a technician with a certain skill set or a vehicle with certain capabilities. You model these skills, capabilities, and so on, by adding them to the OrderSpecialties table. Next, you add the specialties that are supported by a route to RouteSpecialties. When the analysis is solved, orders that require certain specialties are matched with routes that can provide them.
The OrderSpecialties class supports the following fields:
Field |
Description |
Data type |
The name of the order. The value of this field corresponds to a value in the |
Text |
The name of the specialty. This indicates the required specialty for the order. Only a single specialty is listed per row. If an order requires more than one specialty, create a new row. Specialty names are case sensitive and cannot be empty. Specialty names can't contain spaces. For example, a senior technician specialty should be entered as SeniorTechnician. |
Text |
RouteSpecialties
The RouteSpecialties class supports the following fields:
Field |
Description |
Data type |
The name of the route. The value of this field corresponds to a value in the |
Text |
The name of the specialty. This indicates the specialty that the route supports. Only a single specialty is listed per row. If a route supports more than one specialty, create a new row. Specialty names are case sensitive and cannot be empty. Specialty names can't contain spaces. For example, a senior technician specialty should be entered as SeniorTechnician. |
Text |
PointBarriers
Use this parameter to specify one or more points that will act as temporary restrictions or represent additional time or distance that may be required to travel on the underlying streets. For example, a point barrier can be used to represent a fallen tree along a street or a time delay spent at a railroad crossing.
Field |
Description |
Data type |
The name of the barrier. |
Text |
Specifies whether the point barrier restricts travel completely or adds time or distance when it is crossed. The value for this attribute is specified as one of the following integers (use the numeric code, not the name in parentheses):
Long |
The added travel time when the barrier is traversed. This field value must be greater than or equal to zero, and the values are interpreted to be in the units specified by the |
Double |
The added distance when the barrier is traversed. This field value must be greater than or equal to zero, and the values are interpreted to be in the units specified by the |
Double |
The added cost when the barrier is traversed. This field value must be greater than or equal to zero, and the values are interpreted to be in unknown units. |
Double |
Specifies how the restriction point barriers are applied to the edge elements during the analysis. The field value is specified as one of the following integers (use the numeric code, not the name in parentheses):
Long |
Specifies the direction of traffic that is affected by the barrier. The field value is specified as one of the following integers (use the numeric code, not the name in parentheses):
Because junctions are points and don't have a side, barriers on junctions affect all vehicles regardless of the curb approach. |
Long |
Double |
Double |
Double |
LineBarriers
Use this parameter to specify one or more lines that prohibit travel anywhere the lines intersect the streets. For example, a parade or protest that blocks traffic across several street segments can be modeled with a line barrier. A line barrier can also quickly fence off several roads from being traversed, thereby channeling possible routes away from undesirable parts of the street network.
Field |
Description |
Data type |
Text |
Specifies whether the barrier restricts travel completely or scales the cost (such as time or distance) for traveling through it. The field value is specified as one of the following integers (use the numeric code, not the name in parentheses):
Long |
This is the factor by which the travel time of the streets intersected by the barrier is multiplied. The field value must be greater than zero. |
Double |
This is the factor by which the distance of the streets intersected by the barrier is multiplied. The field value must be greater than zero. |
Double |
This is the factor by which the cost of the streets intersected by the barrier is multiplied. The field value must be greater than zero. |
Double |
The information in this field defines which network edges and junctions are covered by the line or polygon and the portion of each edge element that is covered. You cannot directly read or edit the information contained in this field, but Network Analyst interprets it when solving an analysis. |
Blob |
PolygonBarriers
Use this parameter to specify polygons that either completely restrict travel or proportionately scale the time or distance required to travel on the streets intersected by the polygons.
Field |
Description |
Data type |
Text |
Long |
Double |
Double |
Double |
Blob |
