RouteSolverProperties
Zusammenfassung
Provides access to analysis properties from a route network analysis layer. The GetSolverProperties function is used to obtain a RouteSolverProperties object from a route network analysis layer.
Diskussion
The RouteSolverProperties object provides read and write access to all the analysis properties of a route network analysis layer. The object can be used to modify the desired analysis properties of the route layer, and the corresponding layer can be resolved to determine the appropriate results. A new route layer can be created using the Make Route Analysis Layer geoprocessing tool. Obtaining the RouteSolverProperties object from a new route layer allows you to reuse the existing layer for subsequent analyses rather than create a layer for each analysis, which can be slow.
After modifying the properties of the RouteSolverProperties object, the corresponding layer can be immediately used with other functions and geoprocessing tools. There is no refresh or update of the layer required to honor the changes modified through the object.
Eigenschaften
Name Erläuterung Datentyp
accumulators
(Lesen und schreiben)
Provides the ability to get or set a list of network cost attributes that are accumulated as part of the analysis. An empty list, [], indicates that no cost attributes are accumulated.
String
attributeParameters
Provides the ability to get or set the parameterized attributes to be used in the analysis. The property returns a Python dictionary. The dictionary key is a two-value tuple consisting of the attribute name and the parameter name. The value for each item in the dictionary is the parameter value.
Parameterized network attributes are used to model some dynamic aspect of an attribute's value. For example, a tunnel with a height restriction of 12 feet can be modeled using a parameter. In this case, the vehicle's height in feet should be specified as the parameter value. If the vehicle is taller than 12 feet, this restriction will then evaluate to True, thereby restricting travel through the tunnel. Similarly, a bridge could have a parameter to specify a weight restriction.
Attempting to modify the attributeParameters property in place won't result in updated values. Instead, you should always use a new dictionary object to set values for the property. The following two code blocks demonstrate the difference between these two approaches.
Do not attempt to modify the attributeParameters property in place; this coding method will not work.
solverProps.attributeParameters[('HeightRestriction', 'RestrictionUsage')] = "PROHIBITED"
Modify the attributeParameters property using a new dictionary object.
params = solverProps.attributeParameters
params[('HeightRestriction', 'RestrictionUsage')] = "PROHIBITED"
solverProps.attributeParameters = params
If the network analysis layer does not have parameterized attributes, this property returns None.
Dictionary
findBestSequence
Controls whether the stops are reordered to find optimal routes. The following is a list of possible values:
  • FIND_BEST_ORDER—The stops will be reordered to find the optimal route. This option changes the route analysis from a shortest-path problem to a traveling salesperson problem (TSP). A value of True can also be used to specify this option.
  • USE_INPUT_ORDER—The stops will be visited in the input order. A value of False can also be used to specify this option.
String
ignoreInvalidLocations
Specifies whether invalid input locations will be ignored. Typically, locations are invalid if they cannot be located on the network. When invalid locations are ignored, the solver will skip them and attempt to perform the analysis using the remaining locations.
  • SKIP—Invalid input locations will be ignored so that the analysis will succeed using only valid locations. This value may also be specified using a Boolean value of True.
  • HALT—Invalid locations will not be ignored and will cause the analysis to fail. This value may also be specified using a Boolean value of False.
String
impedance
Provides the ability to get or set the network cost attribute used as impedance. This cost attribute is minimized while determining the best route.
String
orderingType
Controls the ordering of stops when findBestSequence property is set to FIND_BEST_ORDER. The following is a list of possible values:
  • PRESERVE_BOTH—Preserves the first and last stops by input order as the first and last stops in the route.
  • PRESERVE_FIRST—Preserves the first stop by input order as the first stop in the route, but the last stop is free to be reordered.
  • PRESERVE_LAST—Preserves the last stop by input order as the last stop in the route, but the first stop is free to be reordered.
  • PRESERVE_NONE—Frees both the first and last stop to be reordered.
String
outputPathShape
Provides the ability to get or set the shape type for the route features that are output by the solver. The following is a list of possible values:
  • TRUE_LINES_WITH_MEASURES—The output routes will have the exact shape of the underlying network sources. Furthermore, the output includes route measurements for linear referencing. The measurements increase from the first stop and record the cumulative impedance to reach a given position.
  • TRUE_LINES_WITHOUT_MEASURES—The output routes will have the exact shape of the underlying network sources.
  • STRAIGHT_LINES—The output route shape will be a single straight line between the stops.
  • NO_LINES—No shape will be generated for the output routes.
String
restrictions
Provides the ability to get or set a list of restriction attributes that are applied for the analysis. An empty list, [], indicates that no restriction attributes are used for the analysis.
String
solverName
(Schreibgeschützt)
Returns the name of the solver being referenced by the network analysis layer used to obtain the solver properties object. The property always returns the string value Route Solver when accessed from a RouteSolverProperties object.
String
streetDirectionsProperties
Provides read and write access to StreetDirectionsProperties, allowing you to customize the directions output from your route layer.
Object
timeOfDay
Provides the ability to get or set the start date and time for the route. Route start time is mostly used to find routes based on the impedance attribute that varies with the time of the day. For example, a start time of 9 a.m. could be used to find a route that considers the rush-hour traffic. A value of None can be used to specify that no date and time should be used.
Instead of using a particular date, a day of the week can be specified using the following dates:
  • Today—12/30/1899
  • Sunday—12/31/1899
  • Monday—1/1/1900
  • Tuesday—1/2/1900
  • Wednesday—1/3/1900
  • Thursday—1/4/1900
  • Friday—1/5/1900
  • Saturday—1/6/1900
For example, to specify that the route should start at 5:00 p.m. on Tuesday, specify the value as datetime.datetime(1900, 1, 2, 17,0,0).
The timeZoneUsage parameter specifies whether the date and time refer to UTC or the time zone in which the first stop is located.
DateTime
timeZoneUsage
Specifies the time zone of the timeOfDay parameter.
  • GEO_LOCAL—The timeOfDay parameter refers to the time zone in which the first stop is located.
  • UTC—The timeOfDay parameter refers to Coordinated Universal Time (UTC). Choose this option if you want to solve the analysis for a specific time, such as now, but aren't certain in which time zone the facilities or demand points will be located.
When solving a route analysis that spans across multiple time zones and setting a start time, the orderingType cannot be set to PRESERVE_NONE. A starting location and time zone must be fixed.
String
timeZoneUsageForTimeFields
Specifies the time zone of datetime fields in the input data, such as the fields used for time windows.
  • GEO_LOCAL—The dates and times for stop time windows refer to the time zone in which the stop is located.
  • UTC—The dates and times for stop time windows refer to Coordinated Universal Time (UTC).
String
travelMode
(Schreibgeschützt)
Accesses the travel mode set on a network analysis layer as an arcpy.na.TravelMode object.
Object
uTurns
Provides the ability to get or set the policy that indicates how the U-turns at junctions that could occur during network traversal between stops are being managed by the solver. The following is a list of possible values:
  • ALLOW_UTURNS—U-turns are permitted at junctions with any number of connected edges.
  • NO_UTURNS—U-turns are prohibited at all junctions, regardless of junction valency. Note that U-turns are still permitted at network locations even when this setting is chosen; however, you can set the individual network locations' CurbApproach property to prohibit U-turns there as well.
  • ALLOW_DEAD_ENDS_ONLY—U-turns are prohibited at all junctions, except those that have only one adjacent edge (a dead end).
  • ALLOW_DEAD_ENDS_AND_INTERSECTIONS_ONLY—U-turns are prohibited at junctions where exactly two adjacent edges meet but are permitted at intersections (junctions with three or more adjacent edges) and dead ends (junctions with exactly one adjacent edge). Often, networks have extraneous junctions in the middle of road segments. This option prevents vehicles from making U-turns at these locations.
String
useHierarchy
Controls the use of the hierarchy attribute while performing the analysis. The following is a list of possible values:
  • USE_HIERARCHY—Use the hierarchy attribute for the analysis. Using a hierarchy results in the solver preferring higher-order edges to lower-order edges. Hierarchical solves are faster, and they can be used to simulate the preference of a driver who chooses to travel on freeways over local roads when possible—even if that means a longer trip. This option is applicable only if the network dataset referenced by the Network Analyst layer has a hierarchy attribute. A value of True can also be used to specify this option.
  • NO_HIERARCHY—Do not use the hierarchy attribute for the analysis. Not using a hierarchy yields an exact route for the network dataset. A value of False can also be used to specify this option.
String
useTimeWindows
Controls if time windows will be used at the stops. The following is a list of possible values:
  • USE_TIMEWINDOWS—The route will consider time windows on the stops. If a stop is arrived at before its time window, there will be wait time until the time window starts. If a stop is arrived at after its time window, there will be a time-window violation. Total time-window violation is balanced against minimum impedance when computing the route. This option is applicable only when the network cost attribute specified as the value for impedance property is in time units. A value of True can also be used to specify this option.
  • NO_TIMEWINDOWS—The route will ignore time windows on the stops. A value of False can also be used to specify this option.
Hinweis:
This property has been maintained for backward compatibility, but it is ignored in ArcGIS Pro. Route layers in ArcGIS Pro will always use time windows if the time windows are populated
String
Methoden
applyTravelMode(travel_mode)
Updates the analysis properties of a network analyst layer based on a travel mode object. The updated network analyst layer can then be solved to complete the analysis.
When a network analyst layer is created, it is assigned default values for all of its analysis properties. The individual analysis properties can be updated using a solver properties object obtained from the network analyst layer. A travel mode stores a predefined set of analysis settings that help to perform a particular analysis, such as a walking time travel mode that stores the analysis settings required to perform a time-based walking analysis.
Using the applyTravelMode method, all the analysis settings that are defined in a travel mode can be applied at once. After the analysis properties are updated, the network analyst layer can be solved to complete the analysis.
If there is an error when updating the solver properties, such as when the provided travel mode references properties that don't exist on the current network dataset or references properties that are no longer applicable to the network dataset that was used to create the network analyst layer corresponding to the solver properties object, no exceptions are raised. The method will execute successfully, but you will get errors when you try to solve such a network analyst layer.
If the travel_mode parameter does not reference a travel mode object or a string, a TypeError exception is raised. If the travel_mode parameter references a string and the string cannot be internally converted to a valid string representation of a travel mode object, a ValueError exception is raised.
travel_mode
A variable that references a travel mode object derived from a network dataset. A list of travel mode objects can be obtained by calling the arcpy.na.GetTravelModes function.
Object
Codebeispiel
RouteSolverProperties example 1 (workflow)
The script shows how to find the fastest route between a set of stops at two times of day. The travel time is different because of changing traffic conditions. The script illustrates how to create only one instance of a route layer and modify the timeOfDay property using the RouteSolverProperties object to achieve the desired results.
Legacy:
The GetNASublayer function can be used to retrieve the sublayers of a network analysis layer. It was introduced in ArcGIS Pro 2.7. In earlier software versions, the best way to retrieve a sublayer object of a network analysis layer was to use the listLayers method of the network analysis Layer object using the sublayer name as a wildcard.
# Name: RouteSolverProperties_workflow_01.py
# Description: Find the fastest route at two different times of day. The travel
#              time is different because of traffic conditions. Use the
#              RouteSolverProperties object to update an existing Route layer
#              before re-running the analysis.
# Requirements: Network Analyst extension
# Import system modules
import arcpy
from arcpy import env
import os
try:
    # Set environment settings
    output_dir = "C:/Data"
    # The NA layer's data will be saved to the workspace specified here
    env.workspace = os.path.join(output_dir, "Output.gdb")
    env.overwriteOutput = True
    # Set local variables
    input_gdb = "C:/Data/SanFrancisco.gdb"
    network = os.path.join(input_gdb, "Transportation", "Streets_ND")
    stops = os.path.join(input_gdb, "Analysis", "Stores")
    route_0830 = os.path.join(output_dir, "Output.gdb", "Route_MorningRush")
    route_1100 = os.path.join(output_dir, "Output.gdb", "Route_MidMorning")
    # Make a new route layer using travel time as impedance to determine fastest
    # route
    route_layer = arcpy.na.MakeRouteAnalysisLayer(network, "StoresRoute",
                                         "Driving Time",
                                         time_of_day="8:30 AM").getOutput(0)
    # Get the network analysis class names from the route layer
    na_classes = arcpy.na.GetNAClassNames(route_layer)
    # Load stops
    arcpy.na.AddLocations(route_layer, na_classes["Stops"], stops)
    # Solve the route layer
    arcpy.na.Solve(route_layer)
    # Get the routes sublayer from the route layer
    routes_sublayer = arcpy.na.GetNASublayer(route_layer, "Routes")
    # Save the resulting route as a feature class. This route was solved at 8:30
    # AM, morning rush hour.
    arcpy.management.CopyFeatures(routes_sublayer, route_0830)
    # Get the RouteSolverProperties object from the route layer to modify the
    # timeOfDay property of the route layer.
    solver_props = arcpy.na.GetSolverProperties(route_layer)
    # Set the impedance property to "Meters" to determine the shortest route.
    solver_props.timeOfDay = "11:00 AM"
    # Re-solve the route layer
    # Save the resulting route as a feature class. This route was solved at 11:00
    # AM, mid-morning when traffic is probably lighter.
    arcpy.management.CopyFeatures(routes_sublayer, route_1100)
    print("Script completed successfully")
except Exception as e:
    # If an error occurred, print line number and error message
    import traceback, sys
    tb = sys.exc_info()[2]
    print("An error occured on line %i" % tb.tb_lineno)
    print(str(e))
ApplyTravelMode example 2 (Python window)
This script shows how to apply the TruckingTime travel mode to an existing layer.
#Get the route layer object from a layer named "Route" in the map
doc = arcpy.mp.ArcGISProject('current')
map_obj = doc.listMaps()[0]
route_layer = map_obj.listLayers('Route')[0]
#Get the Trucking Time travel mode from the network dataset
desc = arcpy.Describe(route_layer)
travel_modes = arcpy.na.GetTravelModes(desc.network.catalogPath)
trucking_mode = travel_modes["Trucking Time"]
#Apply the travel mode to the analysis layer
solver_properties = arcpy.na.GetSolverProperties(route_layer)
solver_properties.applyTravelMode(trucking_mode)
