ServiceArea input data types
The input data types that can be specified when performing a service area analysis are described below.
Facilities
The input locations around which service areas are generated.
All fields from the input facilities are included in the output polygons when the geometryAtOverlap property of the analysis object is set to ServiceAreaOverlapGeometry.Overlap or ServiceAreaOverlapGeometry.Split.
The data type supports the following fields:
Field |
Description |
Data type |
The name of the facility. If the name is not specified, a name is automatically generated at solve time. |
Text |
Specify the extent of the service area to be calculated on a per facility basis. This attribute allows you to specify a different service area break value for each facility. For example, with two facilities, you can generate 5- and 10-minute service area polygons for one facility and 6-, 9-, and 12-minute polygons for the other facility. Separate multiple break values with a space, and specify the numeric values using the dot character as your decimal separator, even if the locale of your computer defines a different decimal separator. For example, the value If the travel mode set for the analysis uses a time-based impedance attribute, the values are interpreted to be in the units specified by the A value for this attribute overrides the default set for the analysis using the The default value is Achtung:Per-facility breaks are ignored if the Legacy:Routing services based on portals running versions of ArcGIS Enterprise earlier than 10.8 do not support per-facility break values and will ignore values in this field. |
Text |
The amount of time spent at the facility, which reduces the extent of the service area calculated for the given facility. The default value is 0. For example, when calculating service areas that represent fire station response times, The units for this attribute value are specified by the |
Double |
The extra distance traveled to reach the facility before the service is calculated. This attribute reduces the extent of the service area calculated for the given facility. The default value is 0. Generally, the location of a facility, such as a store location, isn't exactly on the street; it is set back somewhat from the road. This attribute value can be used to model the distance between the actual facility location and its location on the street if it is important to include that distance when calculating the service areas for the facility. The units for this attribute value are specified by the |
Double |
The extra cost spent at the facility, which reduces the extent of the service area calculated for the given facility. The default value is 0. Use this attribute value when the travel mode for the analysis uses an impedance attribute that is neither time based nor distance based The units for the attribute values are interpreted to be in unknown units. |
Double |
Specifies the direction a vehicle may arrive at and depart from the facility. The field value is specified as one of the following integers (use the numeric code, not the name in parentheses):
The |
Long |
The direction in which a point is moving. The units are degrees and are measured clockwise from true north. This field is used in conjunction with the Bearing data is usually sent automatically from a mobile device equipped with a GPS receiver. Try to include bearing data if you are loading an input location that is moving, such as a pedestrian or a vehicle. Using this field tends to prevent adding locations to the wrong edges, which can occur when a vehicle is near an intersection or an overpass, for example. Bearing also helps the tool determine on which side of the street the point is. |
Double |
The bearing tolerance value creates a range of acceptable bearing values when locating moving points on an edge using the The units are in degrees, and the default value is 30. Values must be greater than 0 and less than 180. A value of 30 means that when Network Analyst attempts to add a network location on an edge, a range of acceptable bearing values is generated 15 degrees to either side of the edge (left and right) and in both digitized directions of the edge. |
Double |
This field is only used in the solve process if the The units of |
Double |
Network location fields
Together, these properties describe the point on the network where the object is located. |
PointBarriers
Use this parameter to specify one or more points that will act as temporary restrictions or represent additional time or distance that may be required to travel on the underlying streets. For example, a point barrier can be used to represent a fallen tree along a street or a time delay spent at a railroad crossing.
Field |
Description |
Data type |
The name of the barrier. |
Text |
Specifies whether the point barrier restricts travel completely or adds time or distance when it is crossed. The value for this attribute is specified as one of the following integers (use the numeric code, not the name in parentheses):
Long |
The added travel time when the barrier is traversed. This field value must be greater than or equal to zero, and the values are interpreted to be in the units specified by the |
Double |
The added distance when the barrier is traversed. This field value must be greater than or equal to zero, and the values are interpreted to be in the units specified by the |
Double |
The added cost when the barrier is traversed. This field value must be greater than or equal to zero, and the values are interpreted to be in unknown units. |
Double |
Specifies how the restriction point barriers are applied to the edge elements during the analysis. The field value is specified as one of the following integers (use the numeric code, not the name in parentheses):
Long |
Specifies the direction of traffic that is affected by the barrier. The field value is specified as one of the following integers (use the numeric code, not the name in parentheses):
Because junctions are points and don't have a side, barriers on junctions affect all vehicles regardless of the curb approach. The |
Long |
Double |
Double |
Double |
LineBarriers
Use this parameter to specify one or more lines that prohibit travel anywhere the lines intersect the streets. For example, a parade or protest that blocks traffic across several street segments can be modeled with a line barrier. A line barrier can also quickly fence off several roads from being traversed, thereby channeling possible routes away from undesirable parts of the street network.
Field |
Description |
Data type |
Text |
Specifies whether the barrier restricts travel completely or scales the cost (such as time or distance) for traveling through it. The field value is specified as one of the following integers (use the numeric code, not the name in parentheses):
Long |
This is the factor by which the travel time of the streets intersected by the barrier is multiplied. The field value must be greater than zero. |
Double |
This is the factor by which the distance of the streets intersected by the barrier is multiplied. The field value must be greater than zero. |
Double |
This is the factor by which the cost of the streets intersected by the barrier is multiplied. The field value must be greater than zero. |
Double |
The information in this field defines which network edges and junctions are covered by the line or polygon and the portion of each edge element that is covered. You cannot directly read or edit the information contained in this field, but Network Analyst interprets it when solving an analysis. |
BLOB |
PolygonBarriers
Use this parameter to specify polygons that either completely restrict travel or proportionately scale the time or distance required to travel on the streets intersected by the polygons.
Field |
Description |
Data type |
Text |
Long |
Double |
Double |
Double |
BLOB |
