ServiceAreaPolygonCutoffGeometry
Zusammenfassung
Enumeration specifying the desired behavior of the ServiceArea output polygons when multiple cutoffs are specified.
Eigenschaften
| Name | Erläuterung | Datentyp |
Disks (Schreibgeschützt) |
Output polygons extend from the facility to the cutoff. If you create 5- and 10-minute service areas, the 10-minute service area polygon will include the area under the 5-minute service area polygon as well as the area from the 5-minute to the 10-minute break. |
Object |
Rings (Schreibgeschützt) |
Output polygons extend between the nearest cutoff values only. They do not include the area of smaller cutoffs. This creates polygons between consecutive cutoffs. |
Object |
