VehicleRoutingProblemInputDataType2
Zusammenfassung
Enumeration of input types for the VehicleRoutingProblem solver when using the VehicleRoutingProblemSchemaVersion.Two schema version.
Eigenschaften
| Name | Erläuterung | Datentyp |
Orders (Schreibgeschützt) |
The orders that will be used as input for the Vehicle Routing Problem analysis. These are the locations that the routes will visit. An order can represent a delivery (for example, furniture delivery), a pickup (such as an airport shuttle bus picking up a passenger), or some type of service or inspection. |
Object |
Depots (Schreibgeschützt) |
The depots that will be used as input for the Vehicle Routing Problem analysis. A depot is a location that a vehicle departs from at the beginning of its workday and returns to at the end of the workday. |
Object |
Routes (Schreibgeschützt) |
The routes that will be used as input for the Vehicle Routing Problem analysis. A route defines vehicle and driver characteristics. |
Object |
Breaks (Schreibgeschützt) |
The breaks that will be used as input for the Vehicle Routing Problem analysis. These include driver rest periods, such as lunch and bathroom breaks. |
Object |
RouteZones (Schreibgeschützt) |
The route zones that will be used as input for the Vehicle Routing Problem analysis. A route zone is a polygon that delineates work territories for given routes and is used to constrain routes to servicing only those orders that fall within or near the specified area. |
Object |
RouteRenewals (Schreibgeschützt) |
The route renewals that will be used as input for the Vehicle Routing Problem analysis. Route renewals are intermediate depots that routes can visit to reload or unload the cargo they are delivering or picking up. |
Object |
OrderPairs (Schreibgeschützt) |
The order pairs that will be used as input for the Vehicle Routing Problem analysis. Order pairs define pickups and deliveries that must be serviced by the same route. |
Object |
PointBarriers (Schreibgeschützt) |
Point barriers that temporarily restrict traversal across or add impedance to points on the network. |
Object |
LineBarriers (Schreibgeschützt) |
Line barriers that temporarily restrict traversal across a line. |
Object |
PolygonBarriers (Schreibgeschützt) |
Polygon barriers that temporarily restrict traversal or scale impedance on the parts of the network they cover. |
Object |
OrderSpecialties (Schreibgeschützt) |
The specialties that are required by orders. A route can service an order only if it supports all the specialties required for that order. For example, an order may require a technician with a certain skill set or a vehicle with certain capabilities. |
Object |
RouteSpecialties (Schreibgeschützt) |
The specialties that are supported by routes. A route can service an order only if the route supports all the specialties required for that order. For example, an order may require a technician with a certain skill set or a vehicle with certain capabilities. |
Object |
