VehicleRoutingProblemSolverProperties
Zusammenfassung
Provides access to analysis properties from a vehicle routing problem Network Analyst layer. The GetSolverProperties function is used to obtain a VehicleRoutingProblemSolverProperties object from a vehicle routing problem Network Analyst layer.
Diskussion
The VehicleRoutingProblemSolverProperties object provides read and write access to all the analysis properties of a vehicle routing problem Network Analyst layer. The object can be used to modify analysis properties of the vehicle routing problem layer, and the corresponding layer can be re-solved to determine the appropriate results. A new vehicle routing problem layer can be created using the Make Vehicle Routing Problem Analysis Layer geoprocessing tool. Obtaining the VehicleRoutingProblemSolverProperties object from a new vehicle routing problem layer allows you to reuse the existing layer for subsequent analyses rather than create a new layer for each analysis, which can be time consuming.
After modifying the properties of the VehicleRoutingProblemSolverProperties object, the corresponding layer can be immediately used with other functions and geoprocessing tools. There is no refresh or update of the layer required to honor the changes modified through the object.
Eigenschaften
| Name | Erläuterung | Datentyp |
attributeParameters (Lesen und schreiben) |
Provides the ability to get or set the parameterized attributes to be used in the analysis. The property returns a Python dictionary. The dictionary key is a two-value tuple consisting of the attribute name and the parameter name. The value for each item in the dictionary is the parameter value. Parameterized network attributes are used to model some dynamic aspect of an attribute's value. For example, a tunnel with a height restriction of 12 feet can be modeled using a parameter. In this case, the vehicle's height in feet should be specified as the parameter value. If the vehicle is taller than 12 feet, this restriction will then evaluate to Attempting to modify the Do not attempt to modify the
Modify the
If the network analysis layer does not have parameterized attributes, this property returns |
Dictionary |
defaultDate (Lesen und schreiben) |
Provides the ability to get or set the implied date for time field values that don't have a date specified with the time. If a time field for an order object, such as TimeWindowStart1, has a time-only value, the date is assumed to be the The day of the week can also be specified as the default date using the following dates:
For example, to specify that the implied date for time field values should be Tuesday, specify the property value as |
DateTime |
distanceAttribute (Lesen und schreiben) |
Provides the ability to get or set the distance cost attribute used to define the length along the elements of the network. |
String |
distanceFieldUnits (Lesen und schreiben) |
Provides the ability to get or set the distance units used by distance fields of the analysis layer's sublayers and tables (network analysis classes). The unit does not have to be the same as the unit of the network cost attribute specified as the
String |
excessTransitTimeImportance (Lesen und schreiben) |
Provides the ability to get or set the importance of reducing excess transit time. Excess transit time is the amount of time exceeding the time required to travel directly between the paired orders. The excess time results from breaks or travel to other orders or depots between visits to the paired orders. This parameter is only relevant if using Order Pairs.
String |
ignoreInvalidLocations (Lesen und schreiben) |
Specifies whether invalid input locations will be ignored. Typically, locations are invalid if they cannot be located on the network. When invalid locations are ignored, the solver will skip them and attempt to perform the analysis using the remaining locations.
String |
outputPathShape (Lesen und schreiben) |
Provides the ability to get or set the shape type for the route features that are output by the solver.
String |
restrictions (Lesen und schreiben) |
Provides the ability to get or set a list of restriction attributes that are applied for the analysis. An empty list, |
String |
solverName (Schreibgeschützt) |
Returns the name of the solver being referenced by the Network Analyst layer used to obtain the solver properties object. The property always returns the string value |
String |
streetDirectionsProperties (Lesen und schreiben) |
Provides read and write access to |
Object |
timeAttribute (Lesen und schreiben) |
Provides the ability to get or set the time-based network cost attribute used to define the traversal time along the elements of the network. This cost attribute is minimized by the solver while finding the solution. |
String |
timeFieldUnits (Lesen und schreiben) |
Provides the ability to get or set the time unit used by the temporal fields of the analysis layer's sublayers and tables (network analysis classes). The unit does not have to be the same as the unit of the network cost attribute specified as the
String |
timeWindowViolationImportance (Lesen und schreiben) |
Provides the ability to get or set the importance of honoring time windows without causing violations. A time window violation occurs when a route arrives at an order, depot, or break after a time window has closed. The violation is the interval between the end of the time window and the arrival time of a route. The following is a list of possible values:
String |
timeZoneUsageForTimeFields (Lesen und schreiben) |
Specifies the time zone of datetime fields in the input data, such as the fields used for time windows.
String |
spatialClustering (Lesen und schreiben) |
Specifies whether to use spatial clustering.
Boolean |
travelMode (Schreibgeschützt) |
Accesses the travel mode set on a network analysis layer as an |
Object |
useHierarchy (Lesen und schreiben) |
Controls the use of the hierarchy attribute while performing the analysis. The following is a list of possible values:
String |
uTurns (Lesen und schreiben) |
Provides the ability to get or set the policy that indicates how the U-turns at junctions that could occur during network traversal between stops are being managed by the solver. The following is a list of possible values:
String |
Methoden
applyTravelMode(travel_mode)
Updates the analysis properties of a network analyst layer based on a travel mode object. The updated network analyst layer can then be solved to complete the analysis.
When a network analyst layer is created, it is assigned default values for all of its analysis properties. The individual analysis properties can be updated using a solver properties object obtained from the network analyst layer. A travel mode stores a predefined set of analysis settings that help to perform a particular analysis, such as a walking time travel mode that stores the analysis settings required to perform a time-based walking analysis.
Using the applyTravelMode method, all the analysis settings that are defined in a travel mode can be applied at once. After the analysis properties are updated, the network analyst layer can be solved to complete the analysis.
If there is an error when updating the solver properties, such as when the provided travel mode references properties that don't exist on the current network dataset or references properties that are no longer applicable to the network dataset that was used to create the network analyst layer corresponding to the solver properties object, no exceptions are raised. The method will execute successfully, but you will get errors when you try to solve such a network analyst layer.
If the travel_mode parameter does not reference a travel mode object or a string, a TypeError exception is raised. If the travel_mode parameter references a string and the string cannot be internally converted to a valid string representation of a travel mode object, a ValueError exception is raised.
travel_mode |
A variable that references a travel mode object derived from a network dataset. A list of travel mode objects can be obtained by calling the VRP only solves with a time-based impedance, so only time-based impedance travel modes will be allowed. |
Object |
Codebeispiel
The script shows how to create a Vehicle Routing Problem layer, add the data, and solve it with the current date as the default date. It then updates the default date to Tuesday and solves again. This is based on the tutorial network dataset of the San Francisco region.
# Name: VehicleRoutingProblemSolverProperties_Workflow.py
# Description: Find the optimal VRP solution solving for today or a day of the
# week. Uses the SolverProperties to update the existing VRP layer
# before re-running the analysis.
# Requirements: Network Analyst extension
# Import system modules
import arcpy
from arcpy import env
import os
import datetime
try:
# Set environment settings
output_dir = r"C:\Data"
# The NA layer's data will be saved to the workspace specified here
env.workspace = os.path.join(output_dir, "Output.gdb")
env.overwriteOutput = True
# Set local variables
input_gdb = "C:/Data/SanFrancisco.gdb"
network = os.path.join(input_gdb, "Transportation", "Streets_ND")
layer_name = "StoreDeliveryRoute"
travel_mode = "Driving Time"
time_units = "Minutes"
distance_units = "Miles"
in_orders = os.path.join(input_gdb, "Analysis/Stores")
in_depots = os.path.join(input_gdb, "Analysis/DistributionCenter")
in_routes = os.path.join(input_gdb, "Analysis/Routes")
routes_today = os.path.join(output_dir, "Output.gdb", "Routes_Today")
routes_tuesday = os.path.join(output_dir, "Output.gdb", "Routes_Tuesday")
# Create a new Vehicle Routing Problem (VRP) layer. Since the time-based
# attributes such as ServiceTime on orders and CostPerUnitTime on routes is
# recorded in minutes, we use minutes for time_units parameter. As we are
# using cost per unit distance in routes, we have to specify a distance
# attribute. The values for CosterPerUnitDistance are in miles, so we
# specify miles for distance units parameter
result_object = arcpy.na.MakeVehicleRoutingProblemAnalysisLayer(network,
layer_name, travel_mode,
time_units, distance_units,
line_shape="STRAIGHT_LINES")
# Get the layer object form the result object. The route layer can now be
# referenced using the layer object.
layer_object = result_object.getOutput(0)
# Get the names of all the sublayers within the VRP layer.
sub_layer_names = arcpy.na.GetNAClassNames(layer_object)
# Store the layer names that we will use later
orders_layer_name = sub_layer_names["Orders"]
depots_layer_name = sub_layer_names["Depots"]
routes_layer_name = sub_layer_names["Routes"]
# Load the store locations as orders. Using field mappings we map the
# TimeWindowStart1, TimeWindowEnd1, and DeliveryQuantities properties
# for Orders from the fields of store features and assign a value of
# 0 to MaxViolationTime1 property. The Name and ServiceTime properties
# have the correct mapped field names when using the candidate fields
# from store locations feature class.
candidate_fields = arcpy.ListFields(in_orders)
order_field_mappings = arcpy.na.NAClassFieldMappings(layer_object,
orders_layer_name,
False, candidate_fields)
order_field_mappings["TimeWindowStart1"].mappedFieldName = "TimeStart1"
order_field_mappings["TimeWindowEnd1"].mappedFieldName = "TimeEnd1"
order_field_mappings["DeliveryQuantities"].mappedFieldName = "Demand"
order_field_mappings["MaxViolationTime1"].defaultValue = 0
arcpy.na.AddLocations(layer_object, orders_layer_name, in_orders,
order_field_mappings, "")
# Load the depots from the distribution center features. Using field mappings
# we map the Name properties for Depots from the fields of distribution
# center features and assign a value of 8 AM for TimeWindowStart1 and a
# value of 5 PM for TimeWindowEnd1 properties
depot_field_mappings = arcpy.na.NAClassFieldMappings(layer_object,
depots_layer_name)
depot_field_mappings["Name"].mappedFieldName = "Name"
depot_field_mappings["TimeWindowStart1"].defaultValue = "8 AM"
depot_field_mappings["TimeWindowEnd1"].defaultValue = "5 PM"
arcpy.na.AddLocations(layer_object, depots_layer_name, in_depots,
depot_field_mappings, "")
# Load the routes from a table containing information about routes. In this
# case, since the fields on the routes table and property names for Routes
# are the same, we will just use the default field mappings
arcpy.na.AddLocations(layer_object, routes_layer_name, in_routes, "", "")
# Solve the VRP layer
arcpy.na.Solve(layer_object)
# Save the resulting Routes sublayer
arcpy.management.CopyFeatures(routes_layer_name, routes_today)
# Get the solver properties object from the vehicle routing problem layer
solverProps = arcpy.na.GetSolverProperties(layer_object)
# Update the default date to tuesday using the specified day in the above
# doc (Tuesday - 1/2/1900) for the vehicle routing problem layer using the
#solver properties object
solverProps.defaultDate = datetime.date(1900, 1, 2)
arcpy.management.CopyFeatures(routes_layer_name, routes_tuesday)
except Exception as e:
# If an error occurred, print line number and error message
import traceback
import sys
tb = sys.exc_info()[2]
print("An error occurred on line %i" % tb.tb_lineno)
print(str(e))
This script shows how to find routes for a fleet of trucks using the Trucking Time travel mode.
#Get the VRP layer object from a layer named "VRP" in the map
doc = arcpy.mp.ArcGISProject('current')
map_obj = doc.listMaps()[0]
vrp_layer = map_obj.listLayers('VRP')[0]
#Get the Trucking Time travel mode from the network dataset
desc = arcpy.Describe(vrp_layer)
travel_modes = arcpy.na.GetTravelModes(desc.network.catalogPath)
trucking_mode = travel_modes["Trucking Time"]
#Apply the travel mode to the analysis layer
solver_properties = arcpy.na.GetSolverProperties(vrp_layer)
solver_properties.applyTravelMode(trucking_mode)
