RadiusVariable
Zusammenfassung
Defines a variable search radius by specifying a maximum distance and the number of points for analysis. If the number of points cannot be satisfied within that maximum distance, a smaller number of points will be used.
Diskussion
Tools that use radius objects: Kriging and IDW.
Syntax
RadiusVariable({numberOfPoints}, {maxDistance})
Name Erläuterung Datentyp
numberOfPoints
(Optional)
The numberOfPoints is an integer value specifying the number of nearest input sample points to be used to perform the interpolation.
The default value is 12.
Long
maxDistance
(Optional)
The maxDistance specifies the distance, in map units, by which to limit the search for the nearest input sample points. The default value is the length of the extent's diagonal.
If the number of points cannot be satisfied within that distance, a smaller number of points will be used.
Double
Eigenschaften
numberOfPoints
(Lesen und schreiben)
Long
maxDistance
The maxDistance specifies the distance, in map units, by which to limit the search for the nearest input sample points. If the number of points cannot be satisfied within that distance, a smaller number of points will be used.
Double
Codebeispiel
RadiusVariable example 1 (Python window)
Demonstrates how to create a RadiusVariable class and use it in the Kriging tool within the Python window.
import arcpy
from arcpy import env
from arcpy.sa import *
env.workspace = "C:/sapyexamples/data"
myRadius = RadiusVariable(12)
outKriging = Kriging("ca_ozone_pts.shp", "ELEVATION", "SPHERICAL", 2000, myRadius, "C:/sapyexamples/output/krigvpradiusv")
outKriging.save("C:/sapyexamples/output/krigradvar")
RadiusVariable example 2 (stand-alone script)
Calculates a surface with the Idw interpolation tool using the RadiusVariable class.
# Name: RadiusVariable_Ex_02.py
# Description: Uses the RadiusVariable object to run IDW tool.
# Requirements: Spatial Analyst extension
# Import system modules
import arcpy
# Set environment settings
# Set local variables
inFeature = "ca_ozone_pts.shp"
# Create the Radius Variable
numberOfPoints = 5
maxDistance = 200000
searchRadius = RadiusVariable(numberOfPoints, maxDistance)
# Run IDW
outIDWRadVar = Idw(inFeature, "elevation", 2000, 3, searchRadius)
# Save the output
outIDWRadVar.save("C:/sapyexamples/output/idwradvar")
