TopoPointElevation
Zusammenfassung
Defines a list of point feature classes representing surface elevations and the fields identifying their elevation values.
Diskussion
This object is used in the tool Topo To Raster.
Syntax
TopoPointElevation(inFeatures)
Name Erläuterung Datentyp
inFeatures
The input point feature datasets.
Optionally, you can supply the name of a field that stores the elevation values to use for the input points.
List
Eigenschaften
inFeatures
(Lesen und schreiben)
The input feature datasets and the fields to be used for the attributes.
List
Codebeispiel
TopoPointElevation example 1 (Python window)
Demonstrates how to create a TopoPointElevation class and use it in the TopoToRaster tool within the Python window.
import arcpy
from arcpy import env
from arcpy.sa import *
env.workspace = "C:/sapyexamples/data"
myTopoPtElev = TopoPointElevation([["spots.shp", "spot_meter"], ["spots2.shp", "elev"]])
myTopoContour = TopoContour([["contours.shp", "spot_meter"]])
myTopoBoundary = TopoBoundary(["boundary.shp"])
myTopoLake = TopoLake(["lakes.shp"])
myTopoSink = TopoSink([["sink1.shp", "elevation"], ["sink2.shp", "NONE"]])
myTopoStream = TopoStream(["streams.shp"])
myTopoCliff = TopoCliff(["cliff.shp"])
myTopoCoast = TopoCoast(["coast.shp"])
myTopoExclusion = TopoExclusion(["ignore.shp"])
outTopoToRaster1 = TopoToRaster([myTopoPtElev, myTopoContour, myTopoBoundary, myTopoLake, myTopoSink, myTopoStream, myTopoCliff, myTopoCoast, myTopoExclusion])
outTopoToRaster1.save("C:/sapyexamples/output/ttraster1")
TopoPointElevation example 2 (stand-alone script)
Interpolates a surface with TopoToRaster using the TopoPointElevation class as one of the input parameters.
# Name: TopoBoundary_Ex_02.py
# Description: Run TopoToRaster using all the supported objects.
# Requirements: Spatial Analyst extension
# Import system modules
import arcpy
# Set environment settings
# Create all the supported Objects
# Run TopoToRaster
outTopoToRaster = TopoToRaster([myTopoPtElev, myTopoContour, myTopoBoundary, myTopoLake, myTopoSink, myTopoStream])
# Save the output
outTopoToRaster.save("C:/sapyexamples/output/ttraster2")
