Create and manage airport signs
Mit Aviation Airports-Lizenz verfügbar.
Mit Aviation Charting-Lizenz verfügbar.
After setting up labeling for the AirportSign layer, you can create, edit, and manage features inside the AirportSign feature class in an ArcGIS Aviation Airports geodatabase.
Create airport sign features
To create airport sign features, complete the following steps:
Open a map in ArcGIS Pro containing ArcGIS Aviation Airports data.
On the Edit tab, in the Features group, click Create
.The Create Features pane appears.
Click the AirportSign feature class inside the Create Features pane to begin creating AirportSign point features on the map.
Using the Point tool
, click a location on the map where you want to add an AirportSign point feature.Alternatively, right-click anywhere on the map, click Absolute X, Y, Z
and provide the coordinate location.In the Manage Edits group, click Save
to save the added point features.
Learn more about creating point features in ArcGIS Pro
Manage Signs
The Manage Signs tool allows you to edit airport signs in a map or scene. This tool allows you to choose the panel style, type the text that is displayed on the sign, and add directional arrows with that text. If editing in a scene, the tool also gives you a 3D preview of what you have configured.
Hinweis:
The tool is dependent on the schema of the AirportSign feature class as specified in the Esri ArcGIS Aviation Airports data model provided in the ArcGIS Aviation data product files available for download at My Esri.
The Attributes pane detects the selection of an airport sign and provides edit options using the Manage Signs tab if you have ArcGIS Aviation authorized.
To edit airport signs, complete the following steps:
On the Map tab, in the Selection group, click the Attributes button
The Attributes pane appears.
Select an airport sign on the map.
The feature appears as AirportSign in the upper portion of the Attributes pane. The pane also contains the Manage Signs, Attributes, and Geometry tabs in the lower portion of the pane.
The Manage Signs option is only available when an airport sign is selected. Any other feature selection—for example, an airfield light—makes that option unavailable.
Click the Sign Type drop-down arrows in the Front and Back sections.
You can provide text values in the Sign Text text box based on the sign type chosen.
You can also preview the sign based on the procedural symbology.
Optionally, add arrows to denote direction for some sign types by right-clicking the Sign Text field.
Right-click any of the Sign Type rows to move or remove them.
Check the Auto Apply check box to apply changes to the attributes automatically.
This check box is available for both the Manage Signs and Attributes options.
Hinweis:
If the Auto Apply check box is not checked, you can manually apply the changes to the attributes on the Attributes tab by clicking Apply.
The following fields are populated on the Attributes tab:
AIRPORTSIGNMSGBACKAIRPORTSIGNMSGFRONT
