Get started with ArcGIS Maritime
Mit ArcGIS Maritime-Lizenz verfügbar.
ArcGIS Maritime is a system for managing and producing maritime data compliant with the International Hydrographic Organization's (IHO) S-100 series of standards and S-57, as well as the MIL-PRF-89023 performance specification for Digital Nautical Chart (DNC).
ArcGIS Maritime provides tools for creating a maritime database, importing data, symbolizing data, editing data, and exporting products.
Lizenz:
The following licenses are required for some workflows:
An active ArcGIS 3D Analyst extension license is required for generating depth areas workflows.
An active ArcGIS Bathymetry license is required for sounding selection and shallow-bias contouring workflows.
The following sections describe additional capabilities of the ArcGIS Maritime extension.
S-57
You can do the following for the S-57 standard:
Convert S-57 data to S-101 format
Import products into a geodatabase for centralized management and editing
Use the Maritime Display Properties pane to customize a Maritime Chart Service layer with more than 35 display settings
DNC
You can do the following for DNC production:
Create and edit DNC features
Edit notes and delete notes on existing features
Group layers in the Contents pane by theme
S-100
You can do the following for the S-100 standard:
Paper charting
You can do the following for paper chart production:
Supported product specifications
ArcGIS Maritime supports the following IHO product specifications in ArcGIS Pro 3.7:
Electronic Navigational Chart (ENC) 3.1.3
Inland Electronic Navigational Chart (IENC) 2.4, 2.5, and 2.6
Bathymetric Inland Electronic Navigational Chart (bIENC) 2.5 and 2.6
Additional Military Layers (AML) 3.0
Contour Line Bathymetry (CLB) 2.1
Environmental Seabed Beach (ESB) 2.1
Large Bottom Objects (LBO) 2.1
Maritime Foundation Facilities (MFF) 2.1
Routes Area Limits (RAL) 2.1
Small Bottom Objects (SBO) 2.1
S-4 Regulations of the IHO for International (INT) Charts
S-58 ENC Validation Checks Edition 8.0.0
S-101 ENC Product Specification 2.0.0
S-124 Navigational Warnings 2.0.0
S-131 Marine Harbour Infrastructure (MHI) 2.0.0 (draft)
Learn more about ArcGIS Maritime data models that support these specifications
