Keyboard shortcuts for editing
Keyboard shortcuts are keys or combinations of keys that you press to run a command instead of clicking an icon or command name. You can customize existing keyboard shortcuts, remove them, and add new ones.
To view, modify, add, or remove keyboard shortcuts, click the ribbon Help tab and click Shortcuts
in the Customize group, or press F12.
Tip:
If the Contents pane is active, F12 opens a properties dialog box for the map, layer, or table that is highlighted in the pane. If the active view is a Layout, the Elements pane appears.
To deselect the Contents pane, click any empty space in the active view.
The default keyboard shortcuts for editing are listed in the following table:
General editing
Keyboard shortcut |
Action |
Comment |
Ctrl+Shift+M |
Open the Modify Features pane. |
To find an editing tool, expand a category or type the name in the Search text box. |
Ctrl+Shift+C |
Open the Create Features pane. |
To find a feature template, expand a layer name or type your search criteria in the Search text box. |
Ctrl+Shift+T |
Open the Attibutes pane. |
Select features and edit their attributes. |
C and drag |
Pan |
Pan the view. |
X and drag |
Zoom out |
Press X and drag the pointer. Release the pointer to zoom out. |
Z and drag |
Zoom in or out |
Zoom the view in or out. |
T |
Show vertices. |
Press and hold to show vertices of existing features near the pointer as you draw a new line. |
Spacebar |
Snapping |
Press and hold to turn snapping on or off as you create or modify features. |
Esc or Ctrl+Delete |
Cancel edits |
Deactivate the current interactive editing tool and cancel any unfinished edits. |
F2 |
Finish |
Apply your changes to the current feature and complete the active operation. |
Undo and Redo
Keyboard shortcut |
Action |
Comment |
Ctrl+Z |
Undo |
Incrementally undo actions and edits recorded in the undo stack. |
Ctrl+Y |
Redo |
Incrementally restore actions and edits recorded in the undo stack. |
Selection tools
Keyboard shortcut |
Action |
Comment |
Shift+ Select |
Add the selected feature |
Add the selected feature to the current selection. Note:When using editing tools that sketch geometry such as the Reshape tool |
Ctrl+ Select |
Remove the selected feature |
Remove the selected feature from the current selection. |
Ctrl+Shift+ Select |
Select only this feature |
Keep the selected feature and remove all other features from the current selection. |
Edit vertices
Keyboard shortcut |
Action |
Comment |
T and hover |
Show vertices within the snapping tolerance. |
Flash a square at vertices that are within the current snapping tolerance of the pointer. |
Shift and click vertices |
Select multiple vertices. |
Drag multiple segments in unison between the selected vertices. |
Shift and click segments |
Select all vertices between the clicked segments. |
Shift+Ctrl and click a selected vertex |
Unselect a vertex. |
Unselect one of many selected vertices. |
A and click |
Add a vertex |
Create a vertex where you click a segment. |
D and click |
Delete a vertex |
Delete the clicked vertex. |
H and drag |
Edit the elevation. |
Move a z-enabled vertex vertically and preserve its x,y coordinates. Hover over a control handle until the pointer becomes a vertex and drag the vertex. This shortcut is available in 3D scenes. |
Ctrl and drag |
Move a Bézier curve. |
Move a Bézier curve and preserve its shape. Hover over a curve until the pointer becomes a segment, and drag the curve. |
Ctrl and drag |
Move a Bézier handle. |
Move a Bézier control handle that can't otherwise be selected when it is coincident with another vertex. Hover over a control handle until the pointer becomes a vertex and drag the handle. |
Ctrl+H |
Move the z-value to the pointer. |
Move the z-value for the selected vertex to the elevation of the pointer. The x- and y-values are preserved. This is available only when stereoscopic mode is enabled. |
Ctrl+G |
Move the pointer z-value. |
Move the pointer z-value to the elevation of the selected vertex. This is available only when stereoscopic mode is enabled. |
Modify annotation
The following shortcuts are available when you edit annotations in the Modify Features pane.
Keyboard shortcut |
Action |
Comment |
Ctrl and drag |
Change the Follow Feature distance. |
In Follow Feature mode, change the distance between the annotation feature and the boundary feature. |
O |
Open the Follow Feature Options dialog box. |
In Follow Feature mode, change settings for text alignment, placement constraints, and other annotation options. |
Geometry properties table
The following shortcuts are available when you edit vertex values in the geometry properties table in the Modify Features pane or in the Attributes pane on the Geometry tab.
Keyboard shortcut |
Action |
Comment |
Down arrow key |
Advance to the next vertex. |
Advance to the next vertex and flash it on the map. |
Up arrow key |
Return to the previous vertex. |
Return to the previous vertex and flash it on the map. |
Shift and click |
Select inclusive rows. |
Select all rows between the first and last row you click. |
Ctrl and click |
Select multiple rows. |
Shift+Down arrow key |
Add the next vertex. |
Add the next vertex to the selection and flash it on the map. Rows are deselected if you switch arrow keys while pressing Shift. |
Shift+Up arrow key |
Add the previous vertex. |
Add the previous vertex to the selection and flash it on the map. Rows are deselected if you switch arrow keys while pressing Shift. |
Ctrl+U |
Switch the selection. |
Deselect the current selection and select all unselected rows. |
Ctrl+A |
Select all vertices. |
Ctrl+Spacebar |
Select or deselect the row. |
Select or deselect the current row. |
Tab |
Advance to the next field. |
Apply the current edit and go to the next column. If at the end of a row, go to the first cell in the next row. |
Ctrl+Enter |
Apply the edit and go to the next row. |
Apply the current edit and go to next row in the same column. |
Shift+Enter |
Apply the edit and go to the previous row. |
Apply the current edit and go to the previous row in the same column. |
Copy and paste in tables
The following shortcuts are available when you edit values in tables that appear in the Attributes pane, the Modify Features pane, and the Template Properties dialog box.
Keyboard shortcut |
Action |
Comment |
Ctrl+C |
Copy the selection. |
Copy the selected value in the cell. |
Ctrl+V |
Paste the selection. |
Paste the copied value to the cell. |
F2 |
Edit the cell. |
Edit the contents of the current cell. |
Esc |
Cancel the action. |
Cancel the edited value and restore the original value to the cell. |
Text formatting tags
The following formatting shortcuts are available when you modify selected annotation in the Attributes pane on the Annotation tab.
Keyboard shortcut |
Action |
Comment |
Ctrl+U |
Apply underline. |
Insert inline text formatting tags <UND> |
Ctrl+Shift+A |
Apply all caps. |
Insert inline text formatting tags <ACP> |
Ctrl+Shift+K |
Apply lowercase. |
Insert inline text formatting tags <SCP> |
Ctrl+Shift+Plus sign (+) |
Apply superscript. |
Insert inline text formatting tags <SUP> |
Ctrl+Equal sign (=) |
Apply subscript. |
Insert inline text formatting tags <SUB> |
Move
Keyboard shortcut |
Action |
Comment |
Ctrl and click |
Relocate the anchor. |
Relocate the selection anchor to the clicked location. You can zoom in to a feature without the current location of the anchor being visible in the active view. |
Ctrl and drag |
Move the anchor. |
Move the selection anchor. |
Scale
Keyboard shortcut |
Action |
Comment |
F |
Apply a scale factor. |
Open the Scale dialog box. |
Ctrl and click |
Ctrl and drag |
Move the anchor. |
S |
Access the secondary anchor. |
Turn the secondary anchor on and off. When it is turned on, the anchor is positioned at the pointer location. |
Rotate
Keyboard shortcut |
Action |
Comment |
A |
Specify the angle. |
Open the Angle dialog box. |
Ctrl and click |
Ctrl and drag |
Move the anchor. |
S |
Create annotation
Keyboard shortcut |
Action |
Comment |
Ctrl+W |
Find text |
Replace the text string in the text box with the label expression or field value from the topmost selected feature layer. When you select feature-linked annotation, the text is calculated from the origin feature class. If it can't be calculated, the word Text is used. |
N |
Find the next text. |
Step through the selected annotation features when using Find Text |
F6 |
Specify absolute X,Y,Z |
Open the Absolute X,Y,Z dialog box. |
Tab |
Switch sides Flip annotation |
Flip unfinished text 180 degrees and to the left or right side of the followed edge. This shortcut is available when you create text with Follow feature |
O |
Use the Follow Feature options. |
Open the Editor Settings dialog box. This shortcut is available when you create text with Follow feature |
Ctrl and drag |
Create point features
Keyboard shortcut |
Action |
Comment |
F6 |
Create polyline and polygon features
Keyboard shortcut |
Action |
Comment |
F6 |
A |
Specify the direction |
Open the Direction dialog box. |
D |
Specify the distance |
Open the Distance dialog box. |
G |
Specify the direction and distance |
Open the Direction and Distance dialog box. |
F |
Specify deflection |
Open the Deflection dialog box. |
F7 |
Specify segment deflection |
Open the Segment Deflection dialog box. |
P |
Make the line parallel |
Constrain the direction of a new line segment parallel to another segment. Hover over an existing segment and press the keyboard shortcut. Release the key to set the constraint and flash the segment to which it is constrained. |
E |
Make the line perpendicular |
Constrain the direction of a new line segment perpendicular to another segment. Hover over an existing segment and press the keyboard shortcut. Release the key to set the constraint and flash the segment to which it is constrained. |
Cancel the edits |
Cancel an unfinished feature. |
F3 |
Square and finish the feature |
Autocomplete the last two segments at right angles and finish the feature. |
F4 or Shift+double-click |
Finish the current part |
Apply your changes to the current part and leave the construction tool active to create another part for the feature. |
Spacebar |
Turn snapping on and off |
Temporarily turn snapping off when you press and hold the Spacebar. Temporarily turn snapping on when you are creating freehand polyline or polygon features. |
Create arc segments
Keyboard shortcut |
Action |
Comment |
R |
Specify a radius. |
Open the Radius dialog box. |
Create endpoint arc segments
Keyboard shortcut |
Action |
Comment |
R |
Specify a radius. |
Create by tracing
Keyboard shortcut |
Action |
Comment |
O |
View the options. |
Open the Options dialog box. |
Tab |
Set a negative offset. |
Switch the side of the offset and trace the other side of an edge. |
Ctrl and drag |
Trace selected features. |
Trace only selected features. If Trace selected features is turned on, you can trace selected features and unselect features. |
Create by streaming
Keyboard shortcut |
Action |
Comment |
O |
View the options. |
F8 |
Start or stop streaming. |
Begin or stop streaming. |
Spacebar |
Temporarily turn on snapping. |
Snapping is automatically turned off until you finish the feature. To temporarily turn on snapping as you drag the pointer, press the Spacebar. |
Create a circle
Keyboard shortcut |
Action |
Comment |
F6 |
R |
Specify a radius. |
Create an ellipse
Keyboard shortcut |
Action |
Comment |
F6 |
Specify absolute x,y,z |
A |
Shift and drag |
Make the geometry a circle |
Constrain the geometry to a circle. Create the first point of the ellipse, press the keyboard shortcut, and drag. |
Elevation tools
Keyboard shortcut |
Action |
Comment |
S |
Suspend the sketch plane. |
Suspend the current 3D elevation sketch plane while using Get Z from View |
Create a rectangle
Keyboard shortcut |
Action |
Comment |
Tab |
Turn Horizontal/Grid Aligned |
When turned on, constrains the feature vertical or horizontal at 90-degree angles. |
A |
Specify a direction |
L |
Specify a length |
Open the Length dialog box. |
W |
Specify a width |
Open the Width dialog box. |
F6 |
Shift and drag |
Make the shape a square. |
Constrain the shape to a square. Create the first point of the rectangle, press the keyboard shortcut, and drag. |
Shift |
Turn Square on or off. |
When turned on, constrains the shape to a square. |
Topology error inspector
Keyboard shortcut |
Action |
Comment |
Up arrow key and Down arrow key |
Move the pointer. |
Move the pointer up and down the rows in the error table. |
Zoom in and center the map on the error feature in the current row. |
This is the same as clicking Zoom To Alternatively, press Ctrl+Shift+Equal sign (=) |
Ctrl+N |
Pan the active map to the selected error. |
This is the same as clicking Pan To Alternatively, press Ctrl+Shift+N |
F |
Select the primary features causing the error. |
This is the same as clicking Select Features |
X |
Mark the error as an exception. |
This is the same as right-clicking the current row and clicking Mark as Exception |
E |
Clear the exception and mark the record as an error. |
This is the same as right-clicking the current row and clicking Clear Exception |
R |
Show the Rules drop-down menu and enable filtering for topology rules. |
This is the same as clicking Rules Note:On the context menu of an error row, this shortcut shows a rule description. |
M |
Show errors in the current map extent. |
This is the same as clicking Map Extent |
V |
Identify topology errors and symbolize them on layers in the current map extent. |
This is the same as clicking Validate |
Ctrl+U |
Switch selected rows. |
This is the same as clicking Switch |
Ctrl+Shift+A |
Unselect all selected rows. |
This is the same as clicking Clear |
Ctrl+8 |
Flash the shape of the error feature in the map. |
This is the same as right-clicking the current row and clicking Flash |
Zoom in and center the map on the error feature. |
This is the same as right-clicking the current row and clicking Zoom To |
Ctrl+Spacebar |
Select or unselect the current row. |
This is the same as right-clicking the current row and clicking Select/Unselect |
R |
View a description and an example graphic of the rule violated by this error. |
This is the same as right-clicking the current row and clicking Rule Description. Note:On the toolbar, this shortcut shows the Rules menu |
