Specify an exact x,y,z location
The Absolute X,Y,Z command places a vertex or a point feature at an exact x,y,z coordinate location. A z-value can be specified if the feature is z-aware. This command is available if you are actively creating a feature and right-click the active map or scene.
When you specify an absolute x,y,z location, consider the following:
To place a vertex or a point feature at an exact x,y,z location, complete the following steps:
  1. Click a template in the Create Features pane and choose a construction tool.
  2. Right-click the map and click Absolute X,Y,Z , or press the F6 key.
    The Absolute X,Y,Z dialog box appears.
  3. Choose a units format, type the x,y,z coordinates, and press Enter.
    Absolute X,Y,Z
  4. Continue sketching the feature, or click Finish or press F2 if you're finished.
Back to top
