Catalog pane, catalog views, and browse dialog boxes
The Catalog pane, catalog views, and browse dialog boxes provide complementary ways to work with items in an ArcGIS AllSource project. These items can be stored in the project file (.aprx), in system folders on your computer, on network drives, in ArcGIS Online or ArcGIS Enterprise portals, on stand-alone servers, or on cloud storage devices.
The Catalog pane is a tree view of items you have added to your project, items in your active portal, items on your computer, and items you have designated as favorites. Catalog views provide access to the same items but offer information and options not available in the Catalog pane. Browse dialog boxes appear when you need to browse to a location to complete a task, such as adding data to a map or opening a project.
Whether to access items from the Catalog pane or a catalog view is often a matter of personal preference. You can also use the pane and views together. For example, you can manage style items in a catalog view, view feature class metadata in a second catalog view, and add a web layer to a map from the Catalog pane.
Images of a browse dialog box, a catalog view, and the Catalog pane
Image 1 shows a browse dialog box for adding data to a map. Image 2 shows a catalog view with a preview of feature class geography. Image 3 shows the Catalog pane listing the contents of the project.
The visibility of hidden files and folders and protected operating system files in ArcGIS AllSource matches your File Explorer settings. For this reason, some files on network drives may be visible to you and not to others or vice versa.
Item categories
Items you can use in ArcGIS AllSource are organized into nonexclusive content categories. Each category appears in the Catalog pane, the Contents pane of catalog views, and on browse dialog boxes. The categories are as follows:
  • Project
  • Portal
  • Computer
  • Favorites
The Project category lists the item connections in your project and the content available from those connections. Item connections include the default geodatabase, default toolbox, and home folder, as well as other connections you add to the project. Item connections provide access to content in databases, servers, and cloud data warehouses. They also act as shortcuts to folders and other items on your computer.
The Portal category lists the items and groups in your active portal.
The Computer category lists items on your local and mapped network drives. You can access content in this category in the same way you do with File Explorer.
The Favorites category lists items you have designated as project favorites. Favorites can be readily added to any project or automatically added to all new projects.
Supported actions
The following table compares actions supported by the Catalog pane, catalog views, and browse dialog boxes. Supported actions have a green marker , partially supported actions have a yellow marker , and unsupported actions have no marker. An action is partially supported if some of the functionality described is available or if the functionality is available under specific conditions.
Action
Catalog pane
Catalog view
Browse dialog box
Browse, search for, and access GIS content on your computer, network drives, and portals.
Supported
Supported
Supported
Sort search results for project items stored on your computer or network drives.
Supported
Supported
Sort and filter search results for portal items.
Supported
Supported
Supported
Sort and filter search results for project items.
Supported
Supported
Supported
Browse and search for portal groups.
Supported
Supported
Supported
Connect to items such as folders, databases, and servers to add them to a project.
Supported
Supported
Designate or create items as project favorites and add favorites to a project.
You can't manage favorites from browse dialog boxes; however, you can access the favorites collection. For example, you can browse into a favorite file geodatabase and add data to a map.
Supported
Supported
Partially supported
Create items, add items to a project, and import items.
You can create, add, and import items from the Insert tab on the ribbon. You can perform these actions in the Catalog pane or a catalog view by right-clicking the appropriate item container (if present) or an empty area of the pane or view. On browse dialog boxes, you can create folders, file geodatabases, mobile geodatabases, database connections, and toolboxes.
Supported
Supported
Partially supported
View folder shortcuts and access their contents.
Supported
Supported
Supported
Access metadata for viewing and editing.
Supported
Supported
Manage items with operations such as rename, alias, copy, move, and delete.
Supported
Supported
Partially supported
Preview data and create thumbnail images of data.
Supported
View geometry type, modification date, and file size for file geodatabase items.
Partially supported
Supported
Supported
View date created, average rating, number of views, and details score for portal items.
Supported
Supported
Display project items in columns or as tiles.
Supported
Import, view, and manage styles.
Partially supported
Supported
Browse the catalog with the location bar.
Supported
Supported
Open the File Explorer location of an item.
Supported
Supported
Key: Supported Functionality is supported; Partially supported Functionality is partially supported
Back to top
