Install a localized version of ArcGIS AllSource
For general installation steps, see Install ArcGIS AllSource. Additional information is provided here for localized versions of ArcGIS AllSource or language packs that you have downloaded.
By default, ArcGIS AllSource runs in the language that matches your Windows display language if you have the appropriate language pack installed. For example, if your Windows display language is French, and you install a French language pack, ArcGIS AllSource runs in French. To run ArcGIS AllSource in a language that does not match your Windows display language, you must change your language options.
A localized setup (Setup.exe) includes setup files for both the core ArcGIS AllSource product and a specific language pack:
  • ArcGISAllSource.msi
  • AllSource<language>LP.msi
Both setups are installed by Setup.exe. For example, if you run Setup.exe for ArcGIS AllSource Spanish, both ArcGIS AllSource and the Spanish language pack are installed.
Two different Add/Remove Program items are created for ArcGIS AllSource and the language pack. Uninstalling one does not uninstall the other.
Install language packs
Any language packs that are downloaded separately from ArcGIS AllSource are also installed separately. To install a language pack that is not part of a localized version, you run only the AllSource<language>LP.msi file for the language.
Language packs are downloaded and installed separately from ArcGIS AllSource. You can download them from My Esri if you have permission in your organization to download software.
ArcGIS AllSource supports the following languages:
  • Arabic
  • Chinese (Simplified)
  • Chinese (Traditional)
  • Czech
  • Finnish
  • French
  • German
  • Hebrew
  • Italian
  • Japanese
  • Korean
  • Polish
  • Portuguese (Brazilian)
  • Russian
  • Spanish
  • Swedish
  • Turkish
  • Ukrainian
Back to top
