Essential ArcGIS Data Interoperability server extension vocabulary
Available with Data Interoperability license.
Term |
Description |
Data format |
A data format defines how digital information is encoded and stored in a file or other data source.
Data source |
A data source is an instance of a dataset stored in a specific format. |
Data transformation |
A data transformation is the process of reorganizing or restructuring data from the source format into destination data. |
Data translator |
A data translator converts data from one format to another format. For example, a data translator can convert MapInfo TAB data to an Esri shapefile. |
Extract, transform, and load |
Extract, transform, and load (ETL) refers to the three separate functions that are combined into a single tool and run as a series, in the following order:
Spatial ETL |
Spatial ETL is a category of tools used for manipulating spatial data, which incorporates the data processing methodologies of traditional extract, transform, and load software. |
FME Workbench |
This is the primary FME Desktop application used to build translation and transformation workflows. |
FMW files |
This is the file that contains the Workbench workspace. This workspace is where the translation or a transformation work is authored and shared. The FMW file can be either referenced or embedded to an ETL tool. |
ArcGIS service owner account |
The operating system account, usually named arcgis, that owns and runs Spatial ETL and other web tools on a server machine. The account must be used to import web and database credentials into Workbench on each server machine that will host web tools. |
Embedded workspace |
An embedded workspace is a workspace that has been imported into a Spatial ETL tool. Embedding a workspace allows you to share FMW files as part of your tool. |
Published parameters |
Published parameters in a workspace allow you to interact with a Spatial ETL tool during runtime. In the User Parameters dialog box, you can uncheck Published to use a constant value for the parameter instead of a user-defined value. |
Transformer |
A transformer is an FME Workbench object that performs a particular restructuring of features or schema. It is a visual object that you add to your workspace canvas and connect between the source and destination features or to other transformers. |
