Upgrade the ArcGIS Data Interoperability server extension
Available with Data Interoperability license.
The ArcGIS Data Interoperability server extension setup package is designed to detect and upgrade from an existing installation of the extension. For the extension to function, it must be at the same version as your ArcGIS Server. So, if you upgrade to ArcGIS Server 12.0, you will also need to upgrade the earlier version of the ArcGIS Data Interoperability server extension installed on your machine.
Complete the following steps to upgrade your ArcGIS Data Interoperability server extension installation:
Sign in to the machine as a user with administrative privileges.
Start the ArcGIS Data Interoperability setup program.
Click Next in the Welcome to the ArcGIS Data Interoperability for Server Setup Program pane of the installation wizard.
The Master Agreement dialog box appears.
Review the master agreement and accept it or close the dialog box if you do not agree with the terms.
Click Next.
The Destination Folder dialog box appears.
Specify the installation location and click Next.
The Ready to install the Program dialog box appears.
Click Install to begin the installation.
Once the installation is complete, the InstallShield Wizard Completed dialog box appears.
Click Finish.
Repeat these steps for each machine in an ArcGIS Server multi-machine site.
