What's new
With ArcGIS Enterprise 12.2, ArcGIS Data Pipelines includes new data sources, new and enhanced tools, new output format options, and expanded administrative capabilities.
Inputs
The following input data sources have been added:
Microsoft SQL Server—Use records from a Microsoft SQL Server table as input to your data pipeline workflows.
Oracle—Use records from an Oracle table as input to your data pipeline workflows.
PostgreSQL—Use records from a PostgreSQL table as input to your data pipeline workflows.
Tools
The following tools and tool enhancements have been added:
Create buffers—A new spatial data management tool used to create areas around input geometries.
Find and replace—A new tool for modifying and standardizing field information. You can replace specific strings or null or empty strings with new values.
Update fields—Now supports selecting which string format to output when converting geometry, date, or date only fields to strings. For example, you can choose to convert a geometry field to a WKT string format.
Filter by attribute—Now supports direct SQL input in addition to the guided query builder.
Outputs
The following new outputs and output enhancements are available:
File—A new output option for writing results to your content as a CSV, GeoJSON, or Apache Parquet file. You can create new files, or overwrite existing files that you own.
Feature layer—Feature layer outputs have been enhanced to cancel automatically when the underlying feature service append jobs become unresponsive. This improved cancellation behavior mitigates extended timeouts which can save you time and resources during service disruptions.
Administration
The following new administration capabilities are available:
Data Pipelines Server administration—Administrators can view server logs, manage compute resources, and configure server settings in the Data Pipelines app.
Max cores per worker—Administrators can configure the maximum number of processor cores available to each compute resource. Use all available cores or specify a maximum. This can be configured using the Data Pipelines Server page, or the Data Pipelines Server administration API.
Automation
The following automation capabilities are now supported:
Leverage ArcGIS API for Python to automate and run your data pipeline workflows.
Leverage ArcGIS REST APIs to administer your ArcGIS Data Pipelines Server site and automate and run your data pipeline workflows.
