ADP_102033: Input datasets have incompatible schemas, the field names and types must match
Message
Input datasets have incompatible schemas, the field names and types must match.
Dataset schemas must have the same number of fields with the same names and types to use the Dataset schemas match exactly merge type.
Solution
Use any of the following solutions to merge datasets successfully:
To update the schema of a dataset to match the schema of another, use the Map fields tool.
If the datasets have a mismatched number of fields, use the Select fields tool to maintain only the matching fields.
If the datasets have fields with different names or types, use the tool Update fields tool to modify the names and types of the mismatched fields.
To keep all fields in the merged output without modifying names or types, use the Combine dataset schemas merge type. To learn more about merge types, see the Merge topic.
