ADP_102078: The input dataset has a different geometry type than the selected layer
Message
The input dataset has a different geometry type than the selected layer.
Feature layers can only be updated with datasets containing the same geometry type. For example, to update a polygon layer you must specify a polygon geometry field.
Solution
If the input dataset contains a geometry column of the same type as the feature layer to update, specify the geometry field in the Geometry parameter.
If the input dataset does not contain a geometry column, use the Create geometry tool to create one.
