ADP_102079: No geometry field specified for the input dataset. Failed to update the selected layer
Message
No geometry field specified for the input dataset. Failed to update the selected layer.
Feature layers can only be updated with datasets containing the same geometry type. For example, to update a polygon layer you must specify a polygon geometry field.
Solution
If the input dataset contains a geometry column of the same type as the feature layer to update, specify the geometry field in the Geometry parameter.
If the input dataset does not contain a geometry column, use the Create geometry tool to create one.
