ArcGIS Data Pipelines Server administrator operations
The following sections describe tools and properties available to ArcGIS Data Pipelines Server administrators. Each tool or property is described along with its path. Tools available in the install directory can be found at <ArcGIS Data Pipelines Server install directory>\tools, and operations located in the ArcGIS Data Pipelines Server administration site can be found by browsing to the URL https://machine.domain.com:14443/arcgis/admin.
Update system properties
Administrators can edit ArcGIS Data Pipelines Server properties to fit their organization. Custom property values can be set at https://machine.domain.com:14443/arcgis/admin/system/properties/update. The following properties are available for configuration:
  • maxWorkersPerMachine—Use this property to increase or decrease the number of workers that can be active simultaneously. Workers are the compute resources that are allocated to power the Data Pipelines editor, scheduled task runs, and stand-alone data pipeline runs.
  • maxMemoryPerWorkerInMiB—Use this property to increase or decrease the amount of memory each worker can use. For example, if you process large amounts of data, you may need to increase this value in order for the runs to complete successfully.
  • reservedInteractiveWorkersPerMachine—Use this property to increase or decrease the number of workers that are reserved for interactive authoring in the Data Pipelines editor. For example, if you have a single-machine ArcGIS Data Pipelines Server site, and maxWorkersPerMachine is set to 6, then by default two of those workers will be reserved specifically for working in the Data Pipelines editor, and four will be available for scheduled task runs and stand-alone data pipeline runs.
  • allowedHosts—Use this property to specify which hosts can be used to read in data when using the URL input. The default is none (""). It is recommended you specify a list of hosts to allow read access to. For example, specify the hosts in a list as follows: "exampleHost.com, exampleHost2.org, exampleHost3.ca"
    To allow users to read data from all hosts, specify a wildcard value of (.*). Use wildcards (*) with caution as it grants users the ability to read data from any host.
Import an existing server certificate
To import an existing server certificate, click Home > Machines > MachineName > sslCertificates > importExistingServerCertificate.
This operation imports an existing server certificate into the keystore. If the certificate is a Certificate Authority (CA) signed certificate, you must first import the CA root or intermediate certificate using the importRootOrIntermediate operation.
Import a root certificate
To import a root certificate, click Home > Machines > MachineName > sslCertificates > importRootOrIntermediate.
This operation imports a CA's root and intermediate certificates into the keystore. To create a production-quality CA-signed certificate, add the CA's certificates to the keystore that enables the SSL mechanism to trust the CA (and the certificates it has signed). While most of the popular CA's certificates are already available in the keystore, you can use this operation if you have a custom CA or specific intermediate certificates.
Update the security configuration
To update the security configuration, click Home > Security > SecurityConfig > UpdateSecurityConfig.
This operation updates the security configuration, including TLS protocols and cipher suites, for your ArcGIS Data Pipelines Server site. This operation causes the REST service endpoints to be redeployed on every server machine in the site. If you updated the communication protocol as part of this operation, it takes ArcGIS Web Adaptor one minute to recognize changes to the communication protocol of your site.
Delete a site
To delete a site, click Home > Delete Site.
This operation deletes the site configuration and releases all server resources. It is suited for development or test servers that need to be cleaned up regularly and can also be performed before uninstallation. Use caution with this option because it deletes all settings and other configurations and is an unrecoverable operation.
This operation performs the following tasks:
  • All server machines participating in the site are stopped.
  • All server machines are unregistered from the site.
  • The configuration store is deleted.
Configure ArcGIS Web Adaptor
To configure ArcGIS Web Adaptor, click Home > System > Web Adaptors > Configuration.
The ArcGIS Web Adaptor configuration is a resource for all the configuration parameters shared across the web adaptors in the site. This resource identifies the shared key used by all the web adaptors to encrypt key data bits in the incoming requests to the server.
Back up the site
It is recommended that you frequently export your site settings through the admin API. You can do this by browsing to Home > Export Site. It is recommended when defining a destination property for the exported site that the location be a network drive, or a location other than the ArcGIS Data Pipelines Server machine itself. The destination must be a location that is accessible to the ArcGIS Data Pipelines Server machine. In the event of a site failure, the site can be recovered by creating a new server site and browsing to Home > Import Site.
If you have a multimachine ArcGIS Data Pipelines Server site and the site fails, it is only necessary to import the site once as described above and then join other ArcGIS Data Pipelines Server machines to the site normally.
Edit the log settings
To edit the log settings, click Home > Logs > Logs > Settings > Edit.
This procedure updates the log settings for the entire server site, such as log output location, level, and format, as well as log file age.
Back to top
