Uninstall ArcGIS Data Pipelines
Uninstall ArcGIS Data Pipelines Server
The installation mode you choose determines the default uninstallation mode. For example, if you install silently from the command line, the uninstallation defaults to uninstalling silently from the command line.
Uninstall ArcGIS Data Pipelines Server using the wizard
If you used the authorization wizard to install ArcGIS Data Pipelines Server, it is recommended that you use the wizard for the uninstallation process as well.
To uninstall ArcGIS Data Pipelines Server, complete the following:
  1. Browse to your installation directory. The installation directory contains the ArcGIS Data Pipelines Server files.
  2. Run the following:
    <ArcGIS Data Pipelines Server installation directory>/uninstall_ArcGISDataPipelinesServer
  3. On the dialog box that appears, click Yes, confirming that you want to uninstall ArcGIS Data Pipelines Server.
    ArcGIS Data Pipelines Server is uninstalled.
When you use the wizard, you have the following options:
  • Repair—Repair any errors in a previous installation of ArcGIS Data Pipelines Server.
  • Remove—Remove all files associated with an ArcGIS Data Pipelines Server installation on a single server machine.
To uninstall ArcGIS Data Pipelines Server, select Remove. Follow the prompts in the wizard until a status bar appears. When the status bar indicates that the uninstallation is complete, click Finish.
Uninstall ArcGIS Data Pipelines Server silently
To uninstall ArcGIS Data Pipelines Server silently from the command line, run the following command:
To uninstall ArcGIS Data Pipelines Server silently from the command line, run the following command with the correct product code from the table below:
msiexec /x <product code> /qb
For example, to uninstall 12.0 use the following command:
msiexec /x {C12E5DB8-9886-4089-89FB-652E6CAFE043} /qb
ArcGIS Data Pipelines Server version Product code Language pack product code
12.1 {47592468-38F3-4920-A2E1-C60B898933EF} {511D1537-ACD5-4E41-88BB-32785ECF244F}
12.0 (Beta) {C12E5DB8-9886-4089-89FB-652E6CAFE043} N/A
Uninstall ArcGIS Data Pipelines web app
Note that the ArcGIS Data Pipelines web app is only used at ArcGIS Enterprise 12.0. At ArcGIS Enterprise 12.1 and above, the web app is bundled with the installation and uninstallation of Portal for ArcGIS.
Uninstall ArcGIS Data Pipelines web app using the wizard
If you used the wizard to install the ArcGIS Data Pipelines web app, it is recommended that you use the wizard for the uninstallation process as well.
To uninstall the ArcGIS Data Pipelines web app, complete the following:
  1. Browse to your Portal for ArcGIS installation directory. The installation directory contains the ArcGIS Data Pipelines web app files.
    <Portal for ArcGIS installation directory>/Uninstall_ArcGISDataPipelinesWebApp
  3. On the dialog box that appears, click Yes, confirming that you want to uninstall ArcGIS Data Pipelines web app.
    ArcGIS Data Pipelines web app is uninstalled.
  • Repair—Repair any errors in a previous installation of ArcGIS Data Pipelines web app.
  • Remove—Remove all files associated with an ArcGIS Data Pipelines web app installation.
Uninstall ArcGIS Data Pipelines web app silently
To uninstall ArcGIS Data Pipelines web app silently from the command line, run the following command:
<Portal for ArcGIS installation directory>/Uninstall_ArcGISDataPipelinesWebApp.sh
msiexec /x {004057B2-EBAA-4121-8253-02211F4C7A56} /qb
