Esri Business Locations and U.S. Business Summary methodology
Esri creates business locations data for Canada and the United States and business summary data for the United States based on business data licensed by Data Axle. This topic describes the methodology used to create that data.
Tip:
Esri also provides a copy of this topic as a technical paper: 2026 Esri Business Locations and U.S. Business Summary methodology (PDF).
A summary of the updates to methodology in this release
The Esri Business Locations point dataset is part of a comprehensive portfolio of ArcGIS Places data that focuses specifically on businesses. Esri creates the Business Locations product from business data licensed by Data Axle. The data features important business attributes, such as company location, industry classification, employee count, sales volume, brands, shopping center information, and more. This release includes more than 13 million U.S. and approximately 1 million Canadian business location points.
Esri also uses Data Axle's business records to create the Business Summary product for the United States. Business summaries are built from the Business Locations dataset and provide ready-to-use information about business sectors for geographic areas such as ZIP codes or census tracts.
For this release, the Business Locations point data and associated Business Summary product are built from Data Axle's August 2026 data. Consult Esri's Data Axle technical documentation topic for more information about Business Location points and Business Summary data.
Note that Data Axle implemented changes in 2025 to their sales volume model that removed sales volumes from corporate headquarters. Business Locations and Business Summary users may observe shifts in sales volume estimates when comparing current data to older vintages.
About Data Axle business data
Data Axle builds its business database from many sources, such as business filings, utility connections, press releases, corporate websites, and annual reports. The data is continuously updated using an extensive phone verification process with more than 24 million verification calls made per year.
NAICS and SIC—Each record includes Data Axle's proprietary eight-digit NAICS-based industry code, which adds two digits to the standard six-digit 2022 North American Industry Classification System (NAICS) structure for enhanced granularity. A proprietary six-digit SIC code, extending the standard four-digit Standard Industrial Classification (SIC), is also provided. All businesses receive one NAICS-based code reflecting their primary activity. A second code may also be assigned to capture additional business activities; for example, a supermarket could have a primary NAICS-based code indicating a grocery store and a secondary code indicating a health and personal care retailer.
Employee counts—Data Axle provides actual employee counts when the information is available; when an actual count is not available, Data Axle provides an estimated count for the location. A kiosk location, such as an ATM, does not have an employee count.
Data modeling—Data Axle sales volume attributes are modeled, as verifiable sales volume figures are extremely difficult to obtain from private businesses. The primary source of information for the model is the U.S. Department of Commerce's data for sales per employee for each NAICS code. This data is also used to estimate Canadian sales volumes, along with the exchange rate and current inflation calculation; the final figures are expressed in Canadian dollars. Note that sales volumes are not provided for those lines of business unrelated to commerce, such as government offices; associations, clubs, and organizations; and educational institutions.
Square footage—The August 2026 data from Data Axle incorporates an updated square footage estimation model. This update improves the square footage estimates for both chain and independent locations, including large-format retailers, grocery stores, and businesses located inside another business (such as a pharmacy counter inside a larger store). Due to this update, users may see notable shifts in square footage estimates when comparing current data to older vintages.
To create the Esri Business Locations point datasets, Esri uses latitude and longitude coordinate values provided by Data Axle to place business points on the map. Most businesses can be located to rooftop- or street-level accuracy. However, some business locations can only be placed to city or ZIP/postal code centroid-level accuracy. The location type and location confidence attributes provided by Esri can help determine the spatial accuracy of a business record.
Quality filtering—Prior to release, some business records are removed that do not meet quality requirements. Typically, this is due to business records missing attributes such as a street address or spatial issues, such as missing latitude and longitude values or locations outside expected geographic boundaries. Reasonable efforts are made to remove duplicated business records from the Business Locations dataset and data quality issues are reported to Data Axle at regular intervals.
Licensing restrictions—Note that the Esri Business Locations points contain the business attributes from Data Axle that Esri is permitted to provide to customers through Esri software. This does not include all the attributes Data Axle offers through its own platform.
Esri U.S. Business Summary data
To create the Business Summary product, various geographic codes are first appended to each business point location. The total number of business points, total sales volumes, and total employee counts are then summarized by each geographic code. This is done for specific business categories and for overall total businesses.
The business categories are generally groupings of two- to four-digit NAICS codes focused on specialized sectors, for instance, Finance & Insurance (NAICS 52) or Health & Personal Care Retailers (NAICS 456). There are 62 ready-to-use business summaries available.
The Business Summary product is available for the following U.S. geography levels:
American Indian, Alaska Native, and Native Hawaiian Areas (AIANNH)
School Districts—Elementary
School Districts—Secondary
School Districts—Unified
State Legislative Districts—Lower Chamber
State Legislative Districts—Upper Chamber
USA
Business summaries can be estimated and then generated for user-defined custom polygons, such as rings and drive-time areas.
Removal of kiosks—Note that records flagged as a kiosk from Data Axle's place type attributes are not included in the Business Summary calculations. Kiosk listings typically include locations such as ATMs, electric charging stations, donation drop boxes, mailing kiosks, and video rental kiosks. While these records are omitted from Business Summary calculations, the records remain in the Business Locations dataset.
