Hardware resources and performance
ArcGIS Drone2Map uses multithreaded CPUs and NVIDIA GPUs with CUDA compute capabilities to quickly turn drone imagery into usable data. However, not all steps use systems resources the same way. In addition to your computer’s hardware, the characteristics of the drone flight—such as number of images, overlap between images, and ground sampling distance (GSD)—can affect performance. The sections below outline the hardware components that are used during processing and provide guidance for optimizing processing speeds.
Key factors that influence processing speed
The following are the most common factors that influence the speed of processing in Drone2Map projects:
  • Hardware components
    • CPU
    • GPU
    • RAM
    • Storage
  • Flight characteristics
    • Number of images
    • Image resolution
  • Project settings and generated products
    • Ground sampling distance
    • Image scale
    • Matching strategy
    • Point cloud density
    • Output products
Hardware components
Your computer's hardware components are used in varying capacities when processing projects. The following is a summary of the behavior of the main components when processing:
  • CPU
    • Drone2Map uses parallel processing with systems with multicore CPUs.
    • The CPU is the most important hardware component that influences processing speeds. All processing steps benefit from upgrading the CPU, so upgrading the CPU should be the highest priority to achieve faster processing times.
    • A CPU with higher clock speed typically performs better than a comparable CPU with more cores.
  • GPU
    • Drone2Map uses NVIDIA GPUs with Compute Unified Device Architecture (CUDA) capabilities to further increase processing speeds. Specific functionality that uses deep learning models such as the processing of Gaussian Splats products and using auto linking during adjustment requires GPUs to be at a minimum compute capability of 7.5 and have 8GB of VRAM.
    • The GPU significantly increases the processing speeds of the Dense Matching and 2D Products steps.
    • The GPU provides moderate processing performance improvements for the Adjust Images step.
  • RAM
    • Drone2Map uses the available RAM dynamically to optimize performance. For optimal performance, the amount of memory should be double the number of CPU threads, for example, 12 core CPU = 24 threads and requires a minimum of 48 GB RAM.
    • Additional RAM increases processing speeds by allowing Drone2Map to do more work in parallel.
    • Systems with high CPU core counts and not enough RAM may limit the processing potential of the CPU. The recommended best practice would be to have at least 32 GB of RAM when using CPUs with high core counts.
  • Storage
    • It is recommended that you store projects and images on SSDs or SSD RAIDs for optimal performance.
    • Avoid processing projects from USB, network drives, and cloud storage drives, as the increased latency and risk of network outages may degrade performance or cause processing to fail.
    • Once processing is complete, you can copy projects to slower HDDs for long-term storage.
Drone2Map provides multiple options for managing flights and increasing processing speed. The following tips can be used to ensure fast, high-quality products:
  • Number of images
    • Increasing the number of images in a project increases the time it takes to process the project.
    • Remove any images that do not contribute to the project, such as images during takeoff or landing and images outside the project area.
    • Use the Project Area tool to delineate the region of interest.
  • Resolution of images—Higher-resolution images generally require more processing power and storage space. Consider the resolution of the drone images when budgeting for hardware components to ensure optimal performance.
Selecting additional output products increases processing time. You may want to select all products when processing a project, but selecting only the products that are within the scope of the project will maximize efficiency.
Drone2Map preserves key processing milestones, allowing for flexibility when deciding which products to process. If you decide to create additional products, you’ll only have to process the steps that are required for that product.
As with adding more products, increasing the quality of processing options generally results in longer processing times. It is recommended that you use the processing template that matches the project requirements, as these templates are optimized for quality and performance.
The following processing steps have the greatest impact on processing speed:
  • General options
  • Adjust images options
    • Image scale
    • Matching neighborhood
Consider the example scenarios below to determine the template to use.
Scenario 1: Rapid template
You are out in the field viewing images from a recently captured drone flight on a computer with lower-end hardware resources. Now that the flight has completed, you are unsure of the quality. You want to see how well the flight reconstructs in Drone2Map, but you have limited time to finalize the mission and return to the office.
To obtain the fastest reconstruction, it is recommended that you create the project with the Rapid template configured. In the processing options for the project, On the Adjust Images tab, you can decrease the Max Tie Points option to speed up processing at the cost of accuracy. Using these settings provides the fastest possible True Ortho.
Scenario 2: 2D products template
Multiple flights were recently completed, and you now must process them in Drone2Map. You have a limited window of time for results but want high-quality products. The computer you're using is a desktop machine with mid-range hardware resources. Each flight needs a True Ortho and both elevation surfaces processed.
To process projects quickly but at a high quality, it is recommended that you create the project with the 2D products template. The default settings for this template configure the project resolution to 1x GSD, process the dense point cloud at high density, and run a second pass at 1x resolution when generating tie points to obtain more matches. You can increase the matching neighborhood under tie point options to potentially gain more matches between neighboring images, but this is only recommended if you are not as confident in the levels of overlap between images.
Scenario 3: 3D products template
You have a project that you want to process to output high-quality 2D and 3D products. Time is not a concern, and you want the highest quality that Drone2Map can provide.
Considering how 3D products are processed, it is recommended that you create the project with the 3D products template configured. This template is automatically set up to process the project resolution at 1x GSD. You can increase the point cloud density to ultra instead of high. The default template tie points settings are configured to run a second pass at full resolution to gather more matches. You can increase the matching neighborhood to Large or X-Large to obtain the maximum number of tie points. This provides the highest level of processing available in Drone2Map. Keep in mind that depending on your hardware resources, processing may take more time to complete with these settings.
