Install a localized ArcGIS Drone2Map setup
A localized setup (Setup.exe) includes the following setup files for the core ArcGIS Drone2Map product and a specific language pack:
  • Drone2Map.msi
  • Drone2Map<language>LP.msi
Both setups are installed by Setup.exe. For example, if you run Setup.exe for ArcGIS Drone2Map Spanish, both Drone2Map and the Spanish language pack are installed.
Two Add/Remove program items are created for Drone2Map and the language pack. Uninstalling one does not uninstall the other.
Additional language packs are installed separately. To install a second language pack, run only the Drone2Map<language>LP.msi file for the language.
Drone2Map supports the following languages:
  • Arabic
  • Chinese (Simplified)
  • Chinese (Traditional)
  • Czech
  • Finnish
  • French
  • German
  • Hebrew
  • Italian
  • Japanese
  • Korean
  • Polish
  • Portuguese (Brazilian)
  • Russian
  • Spanish
  • Swedish
  • Turkish
  • Ukrainian
When running a localized Drone2Map installation, the option to run Drone2Map when the setup completes appears on the Ready to Install dialog box. If the option is left selected, Drone2Map starts after the installation of the core product and its corresponding language pack. Drone2Map does not start automatically after a silent installation.
