Map units, location units, and display units
Three units of measurement are commonly referenced when working within a map or scene to display the most accurate rendering of units: map units, display units, and location units. Map and display units are configured using the Map Properties dialog box and are described in more detail below. Location units and all other units for a project are set within the application settings Units section. Unit options allow you to specify which units of measurement are available in various contexts for the current project or the application.
Map units
Map units are the units in which the spatial data in the map or scene is drawn. Map units are determined by the linear coordinate system of the map or local scene.
Map units are read-only, and you can only change them by changing the coordinate system of the 2D or 3D map. To do this, right-click the 2D or 3D map in the Contents pane and choose Properties from the context menu. The Map Properties dialog box appears. Click the Coordinate System tab, and choose a coordinate system from the list.
Display units
Display units are used by the coordinate system display at the bottom of the 2D or 3D map. The values displayed are the real-world coordinate values corresponding with the pointer's location on the 2D or 3D map.
To change the display units, right-click a 2D or 3D map in the Contents pane and choose Properties from the context menu. The Map Properties dialog box appears. Click the General tab, and choose a unit from the Display Units drop-down list. Alternatively, click the arrow next to the coordinates at the bottom of the map or scene view and choose a unit from the available list.
Location units
Location units are the coordinate units available to the project. To view and modify location units, click the Project tab on the ribbon. In the list to the left, click Settings. On the Settings dialog box, click the Units tab. To add a unit, expand the drop-down for the appropriate unit type. In the last row of the table, click <Select Unit Code>, and choose from the list of available units. To remove, format, or assign the default, right-click the unit. If you add a 2D or 3D map with a coordinate system in decimal degrees, and you previously set your default to linear units—such as feet or meters—the location units will revert to decimal degrees because the specified default is not applicable.
