Optional installation packages
Additional installation packages are available to install alongside ArcGIS Drone2Map. These files are not installed with ArcGIS Drone2Map, but they can be downloaded individually from My Esri and installed on each machine with ArcGIS Drone2Map.
Deep Learning Libraries
The Deep Learning Libraries package adds in Python-based deep learning models that are used in the automated ground control point linking feature, as well as the processing of Gaussian splats. Without this package installed alongside ArcGIS Drone2Map, those functions will be disabled.
DJI Camera Support
The DJI Camera Support component package adds software modules to convert pixel values to temperature units for images captured by specific DJI thermal infrared cameras. Without this software, ArcGIS Drone2Map reports pixel values of relative brightness instead of temperature for those cameras.
ArcGIS Coordinate Systems Data
The ArcGIS Coordinate Systems Data package expands the geographic datum and vertical transformation options available in ArcGIS Drone2Map. Coordinate systems and transformations used throughout the world are added through this installation.
Download the list of supported geographic and vertical coordinate systems.
Download the list of supported geographic and vertical transformations.
ArcGIS Raster Data
The ArcGIS Raster Data package contains a compressed global elevation model primarily intended as a backup for users who work offline and don't have higher resolution elevation data available. After it is installed, the elevation model appears by default in the Elevation surfaces section of the Contents pane.
