Product output types
You can create 2D and 3D products in ArcGIS Drone2Map. Each of these products is different and can be refined with a variety of options. It is important to understand the expected results of generating a product. The sections below describe each of the products you can create in ArcGIS Drone2Map and their use cases.
2D products
You can enable or disable 2D products in the Manage pane or in the processing options. Some products include a variety of configuration options that can modify their appearance or quality. The following are some of the 2D products that can be created in Drone2Map:
Image Collection
The Image Collection product is a mosaic dataset from which all other products are derived. Since it is required for processing in ArcGIS Drone2Map, the layer is always checked. When you run an adjustment, the imagery in the Image Collection mosaic dataset is block adjusted to better align it. This allows the software to generate solution points and seamlines to cleanly mosaic the imagery together. Because the Image Collection product is a mosaic dataset, you can use it in other software such as ArcGIS Pro for other types of analysis, but it is recommended that you run an adjustment first.
True Ortho
The True Ortho product is an orthorectified imagery product, but it is fully corrected to be a nadir-displaying image. This means that the sides of objects, such as buildings or mountains, are no longer present, even to the edges of the project area. Your view is a true vertical standpoint from all features in the project area. This is achieved by first creating a detailed digital surface model (DSM)—for example, from Dense Image matching on well-overlapping imagery using pixel-wise stereo. Subsequently, this detailed surface is used to generate an output ortho image by blending source image pixels rectified in their position given their pixel-accurate elevation
Production of the True Ortho product is fully automated and requires no editing of seamlines or removal of objects, reflections, or inconsistent colors. It is ideal for change detection and feature extraction because the top-down view is consistently reproducible with other flights. The True Ortho product is created as either a three-band RGB or single-band thermal TIF image in the coordinate system of the project. You can refine the True Ortho product in the processing options or using preprocessing tools.
Digital Surface Model
The Digital Surface Model product is an elevation surface generated using aerial triangulation. Point clouds are generated using matching overlapping images to determine heights for features in the images. These point clouds are then filtered by standardized lidar class codes to provide a classification type for the features. With the Digital Surface Model product, all surface-level features are present, which include objects such as buildings, vehicles, and vegetation. Once created, the Digital Surface Model product is symbolized and assigned a scale based on the elevation values.
Digital Terrain Model
The Digital Terrain Model product is an elevation surface generated using aerial triangulation. Point clouds are generated using matching overlapping images to determine heights for features in the images. These point clouds are then filtered by standardized lidar class codes to provide a classification type for the features. With the Digital Terrain Model product, all above-surface-level features are filtered out to provide an elevation surface depicting only the terrain or the earth's surface. Once created, the Digital Terrain Model product is symbolized and assigned a scale based on the elevation values.
DSM Point Cloud
The DSM Point Cloud product is a rasterized point cloud version of the Digital Surface Model product. Each point in the DSM Point Cloud product matches a pixel that contains an elevation value in the Digital Surface Model product. Density of the points is controlled by the project's ground sample distance (GSD) value, which can be increased up to the dataset’s full resolution. Points are filtered by standardized lidar class codes that provide a classification type for the features. With the DSM Point Cloud product, all surface-level features are present, which include objects such as buildings, vehicles, and vegetation. Once created, the DSM Point Cloud product is symbolized based on elevation values. The DSM Point Cloud product is output as an .slpk file by default but can also be generated in LAS format.
3D products
3D products in ArcGIS Drone2Map are derived using high-quality point clouds. You can enable or disable them in the Manage pane or processing options. Some products include a variety of output formats that can be used in other software for further analysis or presentation. The following are some of the 3D products that can be created in Drone2Map:
DSM Mesh
The DSM Mesh product converts the digital surface model (DSM) elevation surface into a triangle mesh. Areas with more variation in height will have more triangles than areas without variation. Since the DSM is used as a source for the geometry of the mesh, it is considered to be a 2.5-dimension mesh product. The product imagery is applied to the resulting mesh, giving it a more realistic appearance. The DSM Mesh product output is an .slpk file by default but can be created in other formats, such as DAE, OBJ, OSGB, and 3D Tiles.
3D Mesh
The 3D Mesh product uses the dense image matching points created during the Surface Reconstruction step to generate a high-detail textured triangle mesh. Because the dense point cloud is used for the geometry of the 3D Mesh product, you maintain a high level of detail on features since points are generated around all angles of that feature. This provides 3D features that are consistent with the real-world object being portrayed regardless of the viewing angle. The 3D Mesh product output is an .slpk file by default but can be created in other formats, such as DAE, OBJ, OSGB, and 3D Tiles.
3D Point Cloud
The 3D Point Cloud product is a full 3D point layer that accurately represents vertical surfaces and overhanging features, along with any observations under them. The points are created through the Surface Reconstruction processing step and are generated using triangulation of overlapping imagery. Each matched pixel produces a 3D point, with any redundant points and noise filtered out. This leaves a thinned but still highly detailed point cloud. Points are assigned a z-value and grouped together to depict larger features in three-dimensional space.
The Point Cloud product is symbolized as RGB points by default, so the points resemble what is seen in the imagery, but in 3D. You can modify the symbology of the 3D Point Cloud product to also display elevation. Point clouds are created as a single .slpk file by default but can be output in LAS format as smaller individual tiles.
Gaussian Splats
The Gaussian Splats product is a 3D layer that provides highly photorealistic recreations of objects. It is generated as a large collection of ellipsoidal 3D points in space using deep learning tools. Project images are fed into a model that derives matching points between them. Each point is provided a position, size, direction, shape and color which ultimately get overlapped and blended together smoothly, making the final result look soft and natural. Gaussian Splats allow for very fine detailed features to be rendered clearly such as wire fences, telephone transmission lines, or dense vegetation.
