Raster and imagery default settings
The raster and imagery default options allow you to change settings that will be applied to all of your imagery and raster datasets. To access these options, click Project > Settings > Raster and Imagery.
The raster and imagery options consist of the following categories:
  • Appearance
  • Cache
  • Raster Dataset
  • Mosaic Dataset
  • Raster Formats
Appearance
The Appearance options allow you to set rendering defaults for rasters that you add to a view.
Check the Use band wavelength information when available check box to allow Drone2Map to determine which bands will be used to display multispectral data as RGB. Due to technological advances, sensors are increasingly incorporating additional bands of information. If you consistently work with a sensor that is not one of the raster products, it may make sense to uncheck this check box and alter the Three band data and Multispectral data defaults.
You can choose a default color scheme from the Color Scheme drop-down menu. The color scheme is used to display single-band data when first added to a view. The default color scheme for a single-band raster added to a view is black to white for the stretched renderer or a random color scheme for the unique values renderer. To go back to the system defaults, click the Reset button.
The Set default RGB composition section allows you to manually set the bands displayed as red, green, and blue in the composite. The band composition can be set differently for Three band data and Multispectral data. You can type the band number in the box, or you can use the up and down arrows to adjust the band number. If a raster product is added to a view, Drone2Map will override these defaults if the Use band wavelength information when available check box is checked.
You can use the Enable custom rendering defaults option to set a specific way to display all of your datasets. This is turned off by default because users tend to work with many kinds of data, from high-resolution imagery to classified raster datasets. It makes sense to enable this if you work with a specific type of dataset.
The background of a raster dataset can be displayed in a specific color or with transparency. This allows you to hide or highlight the background. To display the background value in a specific color, check the Display background value check box, and specify the background value and the color. Usually, the background color is set to transparent so that it is hidden.
The NoData color allows you to hide or highlight these values. Typically, the NoData color is set to transparent so that the NoData values are hidden.
Cache
When checked, if an image service has cache generated, it will display the image service cache rather than the image service.
Raster dataset
The Build pyramid settings expander allows you to set the Build pyramid dialog box settings, Resampling method, Compression method, and Compression quality.
Parameter
Choose how to handle raster datasets that do not have pyramids built:
  • Always prompt for pyramids—Display a dialog box prompt to ask whether the pyramids should be built.
  • Always build pyramids—Always build pyramids before adding the raster dataset to the display. This may take some time.
  • Never build pyramids—Never build pyramids when adding a raster dataset to the display.
Resampling method
Choose the resampling method used when building pyramids:
  • Nearest Neighbor—This method uses the value of the closest cell to assign a value to the output cell when resampling.
  • Bilinear—This method determines the new value of a cell based on a weighted distance average of the four nearest input cell centers.
  • Cubic—This method determines the new value of a cell based on fitting a smooth curve through the 16 nearest input cell centers.
Compression method
Choose the compression type to use when building the raster pyramids:
  • Default—If the source data is compressed using a wavelet compression, it builds pyramids with the JPEG compression type; otherwise, LZ77 is used.
  • LZ77—The LZ77 compression algorithm is used to build the pyramids. You can use LZ77 for any data type.
  • JPEG—The JPEG compression algorithm is used to build pyramids. Only data that adheres to the JPEG compression specification can use this compression type. If JPEG is chosen, you can set the Compression Quality value.
  • JPEG YCbCr—A lossy compression using the luma (Y) and chroma (Cb and Cr) color space components. You can set the Compression Quality value of the pyramid output.
  • None—No compression is used when building pyramids.
Compression quality
The compression quality to use when pyramids are built with the JPEG or JPEG YCbCr compression method. The value must be between 0 and 100. The values closer to 100 produce a higher-quality image, but the compression ratio is lower.
The Calculate statistics expander allows you to set the Calculate statistics dialog box settings, X Skip Factor, and Y Skip Factor.
Parameter
Calculate statistics settings
Choose how to handle raster datasets that do not have statistics calculated:
  • Always prompt for calculating statistics—Display a dialog box prompt to ask if the statistics should be calculated.
  • Always calculate statistics—Always calculate statistics before adding the raster dataset to the display. This may take some time.
  • Never calculate statistics—Never calculate statistics when adding a raster dataset to the display.
X Skip Factor
The number of horizontal pixels between samples.
A skip factor controls the portion of the raster that is used when calculating the statistics. The input value indicates the horizontal or vertical skip factor, where a value of 1 will use each pixel and a value of 2 will use every second pixel. The skip factor can only range from 1 to the number of columns and rows in the raster.
Y Skip Factor
The number of vertical pixels between samples.
Check Use world file to define the coordinates of the raster if you want to override the dataset's native georeferencing with the world file information.
Check Create tiled TIFF to write out tiled .tiff files. If the box is not checked, stripped .tiff files are created.
The Maximum number of values to display option is set to 65,536 by default. This is the maximum number of values you can get with 16-bit data. Increasing this number allows you to work with datasets that have a greater bit depth without scaling them down to 16 bit; however, this increases computational effort and lowers performance.
The Proxy files location allows you to work around restrictions that system administrators put on data repositories. For example, if you need to build pyramids for an image but only have read permissions to that folder, the pyramids are built in the proxy location.
Mosaic dataset
These options allow you to control how a mosaic dataset is presented in the Contents pane.
  • Expand the mosaic layer in the Contents pane—Display its component layers, boundary, footprint, and image in the Contents pane.
  • Show the boundary on the map—Display the full extent of the dataset as a polygon on the map.
  • Show the footprint on the map—Show the extent of each raster within the mosaic dataset on the map.
  • Show the seamlines on the map—Seamlines are shown as a feature layer on the map.
  • Show the image on the map—Uncheck this box to improve performance if it is not necessary to immediately see your imagery or raster dataset.
Multidimensional Dataset
Drone2Map supports the display of multidimensional data for reference. You can enable the Verify that the dataset is tiled for pixel time series access option to ensure the dataset will display changes over time.
Raster formats
This section shows you a table of the raster and imagery formats you can work with in Drone2Map.
Enabling and disabling specific formats is not currently supported. All formats are enabled.
