Specify text for labels
Label text strings are derived from one or more feature attributes. Labels are dynamic, so if feature attribute values change, the labels also change. When you turn on labeling, features are initially labeled based on one field; for example, on the 2D map, you can label ground control points to better describe their locations. To set a single field-based label, right-click a feature class in the Contents pane and click Label .
This label field defaults to the first field of string type that contains the text Name in its name (case insensitive). If no field with that text in its name exists, it defaults to the first field of string type, then the first field of integer type, and then the first field of any type.
You can add attribute fields to your labels. For example, you may label your weather stations with both daily precipitation and maximum wind speed. Whether your labels are based on one attribute field or many fields, the statement that determines your label text is called the label expression. Each label class has its own label expression.
You can insert your own text in the label expression to have it appear with your labels on the map. For example, on your weather map, you can add abbreviated measurement units to each label (for example, in for inches and MPH for miles per hour). You can also use Arcade, Python or JScript in your label expression to change how the text is displayed. For instance, you can insert a function to make precipitation values appear on one line of text and wind speed values appear on a second line.
You can further control how text appears on the map by using text formatting. Using text formatting tags, you can specify different text display properties for different portions of your label text.
Label expressions
Using an advanced label expression, you can add any Arcade, Python or JScript logic to your label expressions, including conditional logic and looping. For example, you can produce labels that have only the first letter of each word capitalized, regardless of how the text strings are stored in the attribute fields. You can also use label expressions to adjust the formatting of your labels by using formatting tags. These are special characters for changing the appearance of all or part of your labels. For example, you can use the bold formatting tag to make the first line bold in a stacked, multiline label.
Tip:
Arcade expressions are used throughout the ArcGIS platform. Arcade expressions work in Runtime, ArcGIS Pro, and ArcGIS Runtime SDKs, while other languages do not.
With Windows 11, version 24H2, VBScript becomes a feature on demand and requires the VBScript capability.
To continue to use the VBScript option, do one of the following:
  • Convert the expression type to Python or Arcade.
  • Enable the VBScript optional feature in the Windows system settings.
A label expression can either be a simple single-line expression, or a more complex expression spanning multiple lines of code and making use of the parser's programming logic. Arcade enables complex expressions by default. When using Python or JScript, the Advanced check box must be checked, and the code must be wrapped in a function to enable multiline expressions.
If you have coded value descriptions in your data, you can use the Use coded value descriptions option to display those descriptions in the label instead of the code.
Field values are automatically cast to text strings. If you want to use a numeric value in an arithmetic operation or when making a comparison, you must cast it back to a numeric data type.
NULL values are not cast to text strings. They are passed to the expression as NULL.
When using Arcade, the field values maintain their data type.
The following examples add two integer fields:
Arcade
$feature.FIELD1 + $feature.FIELD2
Python
int([FIELD1]) + int([FIELD2])
JScript
parseInt([FIELD1]) + parseInt([FIELD2])
Additional Maplex Label Engine options
The Maplex Label Engine provides you the additional ability to control the white space used in your label.
The Remove extra spaces option removes additional space characters from the label text. These extra spaces include all preceding, succeeding, and interior space characters. If the option is unavailable, the spaces are used for formatting, for example, allowing you to indent text in a stacked label.
The Remove extra line breaks option removes additional line breaks from the label text. If the option is unavailable, multiline spacing is possible in a stacked label.
Write a label expression
To write a label expression, complete the following steps:
  1. Right-click a layer in the Contents pane and click Labeling Properties .
    The Label Class pane appears.
  2. Choose a language from the Language menu.
  3. Type an Arcade, Python or JScript expression. You can also create an expression by double-clicking the field to add it to the expression or by selecting the field, right-clicking, and choosing Append to append the field to the clicked location, separated by a space or spaces. Use provided text functions by double-clicking to add them to the expression.
    When using Python and JScript, fields are enclosed in square brackets [ ] regardless of the data type of the layer's data source. Arcade uses a different method to specify fields.
    Field syntax
    $feature.fieldname
    Joined field syntax
    $feature['tablename.fieldname']
    Coded value domain field syntax
    DomainName($feature, 'fieldname')
    Caution:
    Do not use variable names that duplicate field names when using Arcade. In this situation, labels will not be created.
    When labeling a field in which the name contains special characters or starts with a number, Arcade uses the same format as joined field syntax, for example, $feature['33field'], $feature['acres²'], $feature['st_area(SHAPE)'].
    Optionally, enter ArcGIS Pro text formatting tags in the Expression box to apply formatting to a portion of your label text.
    When using Arcade, field formatting on the layer is not brought over to the labels. Arcade formatting methods must be used.
    If your expression will span multiple lines of code, check the Advanced check box and enter your label expression. This is not necessary when using Arcade.
  4. Click Verify to ensure that there are no syntax errors, and click Apply.
    If there are syntax errors, the line number and reason are referenced in the error. To see these numbers, right-click the label expression input box and select Show Line Numbers.
    Both regular and advanced label expressions can be exported as label expression files (.lxp), which can be loaded into other layers or maps.
Expression examples
The following are examples of label expressions.
Concatenate a string to a field value
Concatenate a string to the value in a field; for example, this expression creates a label in which the value of the PARCELNO field is preceded by the text "Parcel no:":
Arcade
"Parcel no: " + $feature.PARCELNO
Python
"Parcel no: " + [PARCELNO]
JScript
Round a decimal number
Round a decimal number to a set number of decimals; for example, this expression displays an AREA field rounded to one decimal place:
Arcade
round(number($feature.AREA), 1)
Python
round(float([AREA]), 1)
JScript
function FindLabel ( [AREA] )
var ss;
var num= parseFloat([AREA]);
ss =  num.toFixed(1);
  return (ss);
Convert to uppercase and lowercase
Convert text labels to all uppercase or lowercase; for example, this expression makes a NAME field all lowercase:
Arcade
lower($feature.NAME)
Python
def FindLabel ( [NAME] ):
  S = [NAME]
  S = S.lower()
  return S
JScript
[NAME].toLowerCase()
Convert to proper case
Convert text labels to proper case; for example, this expression takes a NAME field that is uppercase and makes it proper case:
Arcade
Proper($feature.NAME, 'firstword')
Python
  S = [NAME]
  S = S.title()
  return S
JScript
function FindLabel ( [NAME] )
var str = [NAME];
var iLen = String(str).length;
var upper = (str.substring(0,1)).toUpperCase();
var lower = (str.substring(1, iLen)).toLowerCase()
return upper + lower;
Stack text from multiple fields
Create stacked text; for example, this expression creates a label with the NAME field and the ADDRESS field on separate lines:
Arcade
$feature.NAME + TextFormatting.NewLine + $feature.ADDRESS
Python
[NAME] + '\n' + [ADDRESS]
JScript
[NAME] + "\r" + [ADDRESS]
Stack text from one field
Create stacked text based on text from one field; for example, this expression uses the comma to specify where the stack occurs:
Arcade
replace($feature.LABELFIELD, ', ', '\n')
Python
def FindLabel ( [LABELFIELD] ):
  S = [LABELFIELD]
  S = S.replace(', ', '\n')
  return S
JScript
function FindLabel ( [LABELFIELD] )
var r, re;
var str = [LABELFIELD];
re = /,/g;
r = str.replace(re, "\r");
return r;
Format labels
Format the labels; for example, this expression displays the label as currency:
Arcade
"Occupancy Revenue: $" + round($feature.MAXIMUM_OC * $feature.RATE, 2)
Python
def FindLabel ( [MAXIMUM_OC], [RATE] ):
  import locale
  locale.setlocale(locale.LC_ALL, '')
  S = locale.currency(float([MAXIMUM_OC]) * float([RATE]))
  return S
JScript
function FindLabel ( [MAXIMUM_OC], [RATE] )
var ss;
var num1 = parseFloat([MAXIMUM_OC]);
var num2 = parseFloat([RATE]);
var num3 = num1 * num2
ss =  num3.toFixed(2);
  return ("$" + ss);
Label with part of the string
Use only part of the field as the label; for example, this expression displays the third through fifth characters:
Arcade
mid($feature.LABELFIELD, 2, 3)
Python
  S = [LABELFIELD]
  return S[2:5]
JScript
var S;
S = str.substring(2, 5);
return S;
Create a conditional if-else statement
Specify a conditional if-else statement. These functions label cities with their name in a large, red font if their population is equal to or exceeds 250,000 and in the default label font if the population is less than 250,000:
Arcade
if ($feature.POPULATION >=250000) {
    return "<CLR red='255'><FNT size = '14'>" + $feature.NAME + "</FNT></CLR>"
else {
    return $feature.NAME
Python
def FindLabel ( [NAME], [POPULATION] ):
  if int([POPULATION]) >= 250000:
    return "<CLR red='255'><FNT size = '14'>" + [NAME] + "</FNT></CLR>"
  else:
    return [NAME]
JScript
function FindLabel ( [NAME], [POPULATION]  )
if (parseFloat([POPULATION]) >= 250000){
return ("<CLR red='255'><FNT size = '14'>" + [NAME] + "</FNT></CLR>");
else
return ([NAME]);
To label a subset of features based on a field value, create the SQL query in the label class instead of through the label expression.
