Customize editing options
ArcGIS Drone2Map supports the customization of the editing toolbar that appears when you are actively editing features in a map or scene. Additionally, you can further customize other editing settings, such as snapping, through the status bar at the bottom left of a map or scene. The Snapping Settings dialog box contains all the available options for customizing the editing toolbar and status bar.
The status bar appears at the bottom of the active map or scene. It provides quick access to drawing aids such as snapping, constraint modes, and the editing grid. You can show or hide the buttons that appear on the status bar.
The editing toolbar contains commands related to the active editing tool. By default, it appears horizontally at the bottom of the active map or scene. You can customize the size and location of the toolbar.
You can customize the editing toolbar graphically using the pointer.
Customize size and location
To customize the size and location of the editing toolbars, complete the following steps:
If the editing toolbar does not appear in the active view, do one of the following:
In the Create Features pane, click a polyline or polygon feature template.
In the Modify Features pane, click Vertices
and select a polyline or polygon feature.
On the toolbar, click Configure tool feedback options
Choose a size and orientation. To cancel, click anywhere on the map.
Hover over an empty box to preview your selection.
Click the box to apply the size and orientation to the toolbar.
Enable or disable the editing toolbar
If you uncheck Show the editing toolbar on the map, the toolbar disappears. You can enable the toolbar again in the backstage or through the Editor Settings dialog box.
Enable or disable the editing toolbar from Snapping Settings
To enable or disable the editing toolbar from Snapping Settings, complete the following steps:
Click the Edit tab to show the Features group.
On the ribbon, click the
Settings button to bring up the Editor Settings dialog box.
Check or uncheck the Show the editing toolbar on the map check box.
Enable or disable the snapping settings from the application settings dialog window
To enable or disable the snapping settings from the application settings dialog window, complete the following steps:
Click the Project tab to show the New Project page.
On the ribbon, click Settings to bring up the Settings window.
In the General section, click the Edit Settings drop-down arrow.
Configure the status bar
You can customize the tools available on the status bar with the following steps:
Click the drop-down arrow on the status bar at the bottom of the active map or scene and click Customize Buttons
Alternatively, on the ribbon, click the Edit tab. In the Features group, click Settings
.The Editor Settings dialog box appears.
Click the User Interface tab on the Editor Settings dialog box, and expand Status Bar.
Check the Show buttons on the status bar check box.
This shows the enabled buttons on the status bar.
Uncheck this setting to hide the enabled buttons.
Check the check box for each drawing aid button you want to show on the status bar.
Uncheck a check box to hide a button.
Click OK.
