Customize the reference grid
The reference grid
is a configurable square pattern overlay you can use to align features and visualize distances as you modify or create features. You can configure grid spacing, rotation, elevation for 3D maps, snapping and inference, and display and visibility settings.
Change general settings
To change the general settings, including grid spacing, major line intervals, rotation, and grid elevation for 3D maps, complete the following steps:
On the status bar at the bottom of the current map, hover over Grid
, and click the Editor Settings button
.Alternatively, on the ribbon, click the Edit tab, and in the Tools group, click the Editor Settings dialog box launcher
.Click the Grid tab, and expand General.
Change any or all of the following settings:
Spacing
Specify the distance and units between grid lines.
Major line interval
Display major grid lines at the specified interval. Major grid lines appear darker and can provide a visual reference in contrast to the minor grid lines.
Rotate with map
Automatically rotate the grid when you rotate the map.
Elevation
Specify the z-value height at which the grid appears in a 3D map.
Change snapping and inference settings
Snapping and inference settings customize how the pointer snaps to the grid and infers 90-degree constraints.
To change the snapping and inference settings, complete the following steps:
.Click the Grid tab, and expand Snapping and inference.
Change either or both of the following settings:
Snap to grid
Snap the pointer to grid lines and grid intersections based on the active snap settings.
Infer from grid
Snap the pointer perpendicular to a grid line from the previous vertex. This can be useful for quickly sketching orthogonal lines such as square or rectangular features.
Set display and visibility settings
Display and visibility settings customize the appearance of the grid lines, display scale settings for 2D maps, and grid fill options for 3D local maps.
To set the display and visibility settings, complete the following steps:
, and click the Grid Settings button
.Alternatively, on the ribbon, click the Edit tab, and in the Features group, click the Settings dialog box launcher
.Click the Grid tab, and expand Display and visibility.
Grid lines
Display the grid as contiguous lines or as grid points at all intersections.
Maximum Scale
Choose the maximum scale at which the grid is visible. If the map frame is zoomed in beyond this scale, the grid won't draw on the layout.
Minimum Scale
Choose the minimum scale at which the grid is visible. If the map frame is zoomed out beyond this scale, the grid won't draw on the layout.
Dynamic scaling
Display a secondary grid at a larger scale when zooming out, exceeding the Out beyond display scale setting.
This setting is available only with 2D maps.
