Define missing spatial reference
All geographic datasets have a coordinate system that is used throughout Drone2Map to display, measure, and transform geographic data. If the spatial reference for a dataset is unknown, you can specify the correct spatial reference using the Properties window from the Catalog pane.
To specify the correct coordinate system, complete the following steps:
Add a new folder connection in the Catalog pane that has the dataset for which you want to specify the spatial reference.
Tip:
To add a folder connection, in the Catalog pane, right-click Folders
and click Add Folder Connection
. Browse to the desired folder and click OK.Right-click the dataset.
Click Properties
.Click the spatial reference button
.Choose the appropriate spatial reference.
Alternatively, use the Define Projection tool in ArcGIS Pro for more options.
