Edit rasters
The Rasters group on the Edit tab contains a set of tools used to interactively edit pixel values for raster data. It allows you to edit an individual pixel or a group of pixels at one time. The types of operations that you can perform depend on the data source type of your raster dataset.
The Raster tools in ArcGIS Drone2Map allow you to perform many editing tasks on your raster datasets, such as the following:
Edit elevation data to fill voids, remove spikes, or remove holes.
Use preset filters to smooth areas.
Obscure or redact confidential pixels.
Remove above ground features to create a bare earth elevation surface.
Only True Ortho, orthomosaic, DSM and DTM products can be edited using the pixel editing tools. All other raster datasets are not supported.
Use the Edit Rasters functions
The pixel editing tools in the Raster group can only edit one raster dataset at a time. To use the pixel editing tools in the current map view, click the Edit Rasters button
on the Edit tab. Then select the raster type you want to edit from the available three options:
True Ortho—Edit pixels on the True Ortho.
Orthomosaic—Edit pixels on the Orthomosaic.
DSM—Edit pixels for DSM elevation data.
DTM—Edit pixels for DTM elevation data.
The pixel editor keeps its focus on the raster layer that was used to enable it. To edit another layer, click one of the other options available from the edit button if no edits have been made, or click the Stop Editing button
to be prompted to save your edits. The Rasters group gives you access to all the available pixel editing tools you can use on that type of raster dataset. Some of the tools will open the Pixel Editor Operations pane, where you can perform tasks on the same region of pixels, or the same task on different activated regions of pixels. The type of raster data source determines which operations can be performed on your raster dataset.
You can perform edits to the selected raster type using the Operations tools. The Operations tools have parameters that you need to set to perform the operation. Once you set the parameters in these operations, click Apply to perform the edit.
The Region button drop-down menu includes various options to draw different shaped and sized regions. Regions will only perform edits when using operations. The region color picker allows you to choose the color that will be used to draw your region; keep in mind that the selected region will be highlighted in cyan. The Mode drop-down arrow allows you to create a region or edit an existing region. The Region drop-down arrow allows you to choose the tool to create or edit an area of interest. You can create as many regions as you want, and perform edits across multiple selected regions. The selected region is the area that is highlighted in cyan. Use Select
to choose the region you want to work on. Use Clear Selection
to unselect the region. Remove
removes the currently selected region.
You can use the following four Region Mode options to help you create or edit your region:
New
—Use this mode to create a region.Add To
—Use this mode to edit an existing region by adding to the selected region.Remove From
—Use this mode to edit an existing region by removing some of the region.Intersect
—Use this mode to create a region only where the regions all intersect.
There are four Region tools as follows:
Rectangle
—Draw a rectangle to create a region or edit an existing region.Polygon
—Draw a polygon to create a region or edit an existing region.Lasso
—Draw a free-form shape to create a region or edit an existing region.Circle
—Draw a circle to create a region or edit an existing region.
The Operations drop-down menu provides you with the tools you can use to edit an area of interest interactively. The tools that are available depend on the data source type you are editing. Imagery, such as an orthomosaic, will have different operations than elevation data. The Operations based on data type are explained in the following tables:
True Ortho & Orthomosaic operations
Operation |
Description |
Pixelate
Obscure the region by resampling the region to an exaggerated pixel size. The Factor option allows you to set the level of resampling to perform, in which higher values create more pixelation. Check the Sharpen check box to sharpen the image that has been obscured. This will make the region less noticeably obscured. |
Blur
Obscure the selected region with a blurred effect. Blur can also be used to smooth a noisy area. The Factor option allows you to set the level of blurring to perform, in which higher values result in more blurring. Check the Sharpen check box to sharpen the image that has been obscured. This will make the region less noticeably obscured. |
Redact
Cut out the selected region. |
Elevation surface operations
Operation or filter |
Description |
Set Average
Set the selected region to its computed average elevation. |
Set Constant
Set the selected region to a constant elevation. Specify the Value to apply to the region. |
Average Filter
Use an average filter on the selected region. This smooths the elevation values within the region. The Filter Size option allows you to choose the size of your filter window while performing the operation. A filter size of 8 means you are using an 8 by 8 filter window. Larger values result in more smoothing. |
Median Filter
Use a median filter on the selected region. The Filter Size option allows you to choose the size of your filter window while performing the operation. A filter size of 8 means you are using an 8 by 8 filter window. Larger values result in more smoothing. |
Constrained Filter
Use a constrained filter that has a threshold on the maximum a value can change within the selected region. The Filter Size option allows you to choose the size of your filter window while performing the operation. A filter size of 8 means you are using an 8 by 8 filter window. Larger values result in more smoothing. The Threshold is the maximum value that the pixel can change. If the change is larger than the threshold, the original pixel value remains unchanged. |
Terrain Filter
Remove aboveground structures in a DSM while preserving natural slopes in the selected region. Three methods are used for detecting ground points:
Fill Voids
Create pixels where NoData voids exist in your elevation dataset. Voids are often caused by water bodies, insufficient stereo overlap, class type selection, or exclusion. Void filling is most commonly performed when generating a ground surface. Fill Method allows you to choose the maximum width of a void to fill.
Check the Short Range IDW check box to fill small voids using the inverse distance weight (IDW) algorithm. If you turn on this parameter, you must specify the maximum Search Radius that will be used for void filling. A void that is farther away from any valid pixel than this threshold value remains a void. The units of this parameter are the same as the units used in your data's spatial reference system. |
Interpolate from Vertices
Use values from the vertices of your selected region to interpolate the surface. This can be used to remove nonground features or fill NoData gaps. There are four Interpolation Methods for this function:
If you select the Blend check box, the result of the operation buffers the region and interpolates the buffered area so that the result looks seamless. The Blend Width text box allows you to specify the number of pixels to use in the blending interpolation. The blending uses the same interpolation method that was specified for the operation. |
Interpolate from Edges
Use values from the edges of your selected region to interpolate the surface. This can be used to remove nonground features or fill NoData gaps. There are four Interpolation Methods for this function:
The Save group gives you the option to save or discard your edits. The Discard button
will undo all of the edits that you performed and are not committed yet. The Save button
allows you to commit your edits to the current layer that you are editing. The Save as New button
allows you to save your edits to a new raster dataset. This is helpful if you do not want to overwrite your source data, or your data source is a format that is not writable.
