Real-time kinematic data collection
Real-time kinematic (RTK) positioning is a form of surveying that involves the determination of a location at high accuracy using one or more base stations that are connected to a satellite positioning network. The positional accuracy of RTK collections is generally at the centimeter or subcentimeter level. This capability has become easier to implement on a smaller scale, and more drone platform options are becoming available.
RTK drones tend to provide greater benefits over typical consumer model drone platforms. RTK drones are constantly connected to a base station or correction service that helps to increase positional accuracy. This means that even while flying, the image locations are highly accurate and ground control is rarely needed to obtain accurate imagery products. Since they are also more expensive than other models, RTK drones tend to have higher-quality cameras that can capture images at higher resolutions or wider angles.
Real-time kinematic vs. postprocessed kinematic
RTK and postprocessed kinematic (PPK) technologies are both used to obtain highly accurate GPS information. The main difference is in the name: RTK is applied in real time, meaning that a drone has a constant connection between one or more base stations and a satellite constellation providing positional information. With PPK, a drone is also connected to one or more base stations and a satellite constellation. However, the correction information that is provided by any base station is applied to the data post flight, typically through specific software.
With RTK data collection, you eliminate the step of postprocessing. This can save time and money by not having to buy purpose-built software for the task. PPK, however, has increased flexibility in terms of where the drone can be deployed. Since a strong signal is not always necessary between the drone and the base station, the drone can fly more varied terrain without a line of sight. RTK drones require a constant connection between the drone, base station, and satellite for best results. This means flights are typically line of sight and over relatively flat or unobstructed terrain.
Both methods provide highly accurate survey-grade positional information for imagery. ArcGIS Drone2Map can process the corrected datasets from either collection method.
Best practices
The following tips can help you achieve high-accuracy and high-quality field collection results:
When using a base station, if the base station is not set to a known position, you will have high relative accuracy between photos, but you will not have high absolute accuracy relative to the coordinate reference system used. Ensure that the base station matches a known point and those coordinates are in the correct coordinate system for the project.
The drone, drone controller, and base station should be updated to the latest firmware to avoid potential connection issues.
With PPK flights, both the drone and the base station need to record satellite data for postprocessing. Ensure that both are set to record that information and the correct transformation is used when outputting the GPS data from the PPK software.
If using ground control points, ensure that they are equally spread throughout the flight area and that the markers remain in position when moving the base station. Do not use the Fix Image Location for High Accuracy GPS (RTK and PPK) processing option if you are using ground control points, as it can distort accuracy values when you are adjusting with both.
Ensure that the drone and base station are recording in the same coordinate systems. If you're using a correction service, verify the coordinate systems before capturing the flight.
RTK and ground control points
RTK drones are generally more accurate than a typical handheld GPS device. However, RTK positioning is not infallible and GPS coordinates may be inaccurate if poor flight conditions exist or connection issues occur. Collecting ground control points for each flight can mitigate these issues. Using ground control points as a checkpoint measurement can help provide validation of the drone's positional accuracy. If there is a significant shift in the imagery compared to the checkpoint, the drone collection configuration may be incorrect. This applies to both horizontal and vertical measurements.
The following are tips when working with ground control and RTK data:
If you see a significant shift between the RTK imagery and checkpoints, first review the coordinate systems used. Ensure that the imagery coordinate system and project coordinate system are both correctly defined.
Account for the height of the base station if you are using a custom RTK network. Measure the height starting from the top of the GPS receiver. If necessary, you can adjust image altitude to account for this shift.
In the processing options, under the Adjust Images section, check the Fix Image Location for High Accuracy GPS (RTK and PPK) check box. This stops the software from attempting to adjust GPS measurements and use the measurements directly from the imagery metadata instead.
The Fix Image Location for High Accuracy GPS (RTK and PPK) option should only be used with checkpoints and not ground control points. Having this option and ground control linked during the adjustment step can produce accuracy errors.
Additionally, enabling this setting assumes that all the image locations collected by your RTK drone are accurate. If one or more images are determined to not be accurate enough to fix and still return a good adjustment solution, all images will be adjusted to achieve a best fit calibration.
Understanding RTK metadata fields
RTK-enabled drone imagery records metadata fields that provide key details about the quality of the RTK corrections. Understanding what the values in these fields represent can help enhance the accuracy of output products.
To determine which RTK metadata fields your imagery has, you can use the built-in metadata viewer.
The metadata of RTK-enabled drones typically includes the following fields:
rtk_flag—Indicates the quality and precision of geotagging
rtk_std_lon—Measures longitude accuracy
rtk_std_lat—Measures latitude accuracy
rtk_std_hgt—Measures height (altitude) accuracy
The rtk_flag field shows whether RTK corrections were applied and their effect on positioning and the geotagging quality. It evaluates both absolute accuracy (how well GPS coordinates match real-world locations) and relative accuracy (how consistent positions are between images in the same flight). The overall measurement is provided in a value based on the following scale:
0: No positioning—No RTK corrections applied, resulting in low accuracy (tens of meters)
16: Single-point positioning—Low accuracy, around meter level
34-49: RTK float solution—Decimeter to meter level accuracy, influenced by base station connection quality
50: RTK fixed solution—High precision, with accuracy at the centimeter level
The rtk_std_lon field represents the standard deviation of longitude measurements after RTK corrections. A smaller value indicates higher precision and confidence in longitude geotagging.
The rtk_std_lat field reflects the precision of latitude measurements in RTK corrections. A lower value means better accuracy, ensuring the latitude coordinates are closer to their real-world position.
The rtk_std_hgt field represents the standard deviation of altitude measurements after RTK corrections. A smaller value corresponds to higher confidence in height positioning, essential for tasks requiring precise vertical accuracy.
When RTK accuracy fields are detected, individual image accuracy is displayed within the project images table as AccX, AccY, AccZ.
