Share a scene layer
With Drone2Map, you can create a scene layer package from the 3D textured mesh. In addition to viewing the layer in Drone2Map, you can share it as a scene layer in ArcGIS Online or your ArcGIS Enterprise portal. A scene layer is composed of three-dimensional mesh objects and includes z-values (elevation values).
Share items
The following options are available for sharing items, depending on your sharing privileges:
Your organization—Sharing with your organization means only members of your organization have access to your item.
Groups to which you belong—If you are a member of a group, you can share your item with that group. Sharing with specific groups restricts access to a smaller, more focused set of people.
Everyone—Sharing with everyone makes your item public; anybody who has access to the portal website or ArcGIS Online, including anonymous users, can find and use the item, and group owners can include it in their group content.
Everyone, your organization, and groups to which you belong—You can share your item with a larger audience (for example, everyone and your organization) and also share it with a specific group. This allows you to categorize the item as especially relevant to a particular group while still making it available to others in your organization.
This process creates and stores a scene layer package in your account. If you're sharing to an ArcGIS Online organizational account, service credits apply.
Publish a scene
To publish a textured mesh as a scene layer, complete the following steps:
On the Share tab, in the Share As group, click Scene Layer
.Check the layers you want to share. You can share the following scene types:
3D Mesh
3D Point Cloud
DSM Mesh
DSM Point Cloud
Gaussian Splats
Click the Properties tab at the top of the share pane, and check or uncheck the Global Scene option.
To share scene layers in the project coordinate system, uncheck the Global Scene option. When sharing as a local scene, Esri basemap layers will not work, as they are intended to be used with the WGS 1984 Web Mercator coordinate system and do not project on the fly.
Provide a name for the scene in the Title text box.
If your adding the scene to a web catalog, check the Add portal item to web catalog check box.
A web catalog must exist for the project before layers can be added to it. To create a web catalog, click the Create new web catalog button
. For more information about working with catalog datasets, see Use catalog datasets.Optionally, choose a folder to share the features, provide a description, and update the tags.
Check the appropriate check boxes for sharing the scene layers.
Click Share.
