SQL reference for query expressions used in ArcGIS
This topic describes the elements of common selection queries in ArcGIS. Query expressions in ArcGIS use the SQL syntax.
Common queries: searching strings
Strings must always be enclosed in single quotation marks in queries, for example:
\(STATE\_NAME \space = \space 'California'\)
Strings are case sensitive in expressions. To make a case-sensitive search, you can use a SQL function to convert all values to the same case. For file-based data sources such as geodatabases or shapefiles, you can use the UPPER or LOWER function to set the case for a selection. For example, the following expression will select the state whose name is stored as 'Rhode Island' or 'RHODE ISLAND':
\(UPPER(STATE\_NAME) \space = \space 'RHODE \space ISLAND'\)
If the string contains a single quotation mark, you will first need to use another single quotation mark as an escape character, for example:
\(NAME \space = \space 'Alfie''s \space Trough'\)
Use the LIKE operator (instead of the = operator) to build a partial string search. For example, this expression would select Mississippi and Missouri among United States state names:
\(STATE\_NAME \space LIKE \space 'Miss\%'\)
The percent symbol (%) means that anything is acceptable in its place: one character, a hundred characters, or no character. Alternatively, if you want to search with a wildcard that represents one character, use an underscore (_). For example, this expression would find Catherine Smith and Katherine Smith:
\(OWNER\_NAME \space LIKE \space '\_atherine \space smith'\)
You can use greater than (>), less than (<), greater than or equal (>=), less than or equal (<=), not equal (<>), and BETWEEN operators to select string values based on sorting order. For example, this expression will select all the cities in a coverage with names starting with the letters M through Z:
\(CITY\_NAME \space >= \space 'M'\)
String functions can be used to format strings. For instance, the LEFT function would return a certain number of characters starting on the left of the string. In this example, the query would return all states starting with the letter A:
\(LEFT(STATE\_NAME,1) \space = \space 'A'\)
Refer to the documentation of your database management system for a list of supported functions.
Common expressions: Searching for NULL values
You can use the NULL keyword to select features and records that have null values for the specified field. The NULL keyword is always preceded by IS or IS NOT. For example, to find cities whose 1996 population has not been entered, you can use the following:
\(POPULATION \space IS \space NULL\)
Alternatively, to find cities whose 1996 population has been entered, you can use the following:
\(POPULATION96 \space IS \space NOT \space NULL\)
Common expressions: Searching numbers
The decimal point (.) is always used as the decimal delimiter, regardless of your locale or regional settings. The comma cannot be used as a decimal or thousands delimiter in an expression.
You can query numbers using the equal (=), not equal (<>), greater than (>), less than (<), greater than or equal to (>=), less than or equal to (<=), and BETWEEN operators, for example:
\(POPULATION \space >= \space 5000\)
Numeric functions can be used to format numbers. For instance, the ROUND function would round a number to a given number of decimals in a file geodatabase:
\(ROUND(SQKM,0) \space = \space 500\)
Refer to the documentation of your database management system for a list of supported numeric functions.
Dates and time
General rules and common expressions
Geodatabase data sources store dates in a date-time field. However, ArcInfo coverages and shapefiles do not. Therefore, most of the query syntax listed below contains a reference to the time. In some cases, the time part of the query may be safely omitted if the field is known to contain only dates; in other cases, it must be stated, or the query will return a syntax error.
Searching date fields requires careful attention to the syntax required by your data source. If you build a date query in Clause mode of the Query Builder, the correct syntax will be automatically generated for you. Here is an example of a query that will return all records on or after January 1, 2011, for a file geodatabase data source:
\(INCIDENT\_DATE \space >= \space date \space '2011-01-01 \space 00:00:00'\)
Dates are stored in the underlying database as a reference to December 30, 1899, at 00:00:00. This is valid for all the data sources listed here.
The purpose of this section is only to help you query against dates, not time values. When a nonnull time is stored with the dates (for instance, January 12, 1999, 04:00:00), querying against the date only will not return the record because when you pass only a date to a date-time field, it will fill the time with zeros and retrieve only the records where the time is 12:00:00 a.m.
The attribute table shows date and time in a user-friendly format, depending on your regional settings, rather than the underlying database's format. This is fine most of the time, but it also has the following drawbacks:
  • The string shown in the SQL query may only slightly resemble the value shown in the table, especially when time is involved. For instance, a time entered as 00:00:15 will show as 12:00:15 a.m. in the attribute table, with the United States as your regional settings, and the comparable query syntax would be Datefield = '1899-12-30 00:00:15'.
  • The attribute table does not know what the underlying data source is until you save your edits. It will first try to format the value entered to fit its own format, and then upon saving edits, it will try to tweak the resulting value to fit into the database. Because of this, you can enter a time in a shapefile, but you will find that it is dropped when you save your edits. The field will then contain a value '1899-12-30' that will show as 12:00:00 a.m. or the equivalent, depending on your regional settings.
Date-time syntax for enterprise geodatabases
Informix
\(Datefield \space = \space 'yyyy-mm-dd \space hh:mm:ss'\)
The hh:mm:ss part of the query cannot be omitted, even if it is equal to 00:00:00.
Oracle
\(Datefield \space = \space date \space 'yyyy-mm-dd'\)
Keep in mind, this will not return records where the time is not null.
An alternative format for querying dates in Oracle follows:
\(Datefield \space = \space TO\_DATE('yyyy-mm-dd \space hh:mm:ss','YYYY-MM-DD \space HH24:MI:SS')\)
The second parameter 'YYYY-MM-DD HH24:MI:SS' describes the format used for querying. An actual query would look like this:
\(Datefield \space = \space TO\_DATE('2003-01-08 \space 14:35:00','YYYY-MM-DD \space HH24:MI:SS')\)
You can use a shorter version:
\(TO\_DATE('2003-11-18','YYYY-MM-DD')\)
Again, this will not return records where the time is not null.
SQL server
The hh:mm:ss part of the query can be omitted when the time is not set in the records.
An alternative format is this:
\(Datefield \space = \space 'mm/dd/yyyy'\)
IBM DB2
The hh:mm:ss part of the query cannot be omitted, even if the time is equal to 00:00:00.
PostgreSQL
\[ \begin{align*} Datefield \space = \space TIMESTAMP \space 'YYYY-MM-DD \space HH24:MI:SS' \\Datefield \space = \space TIMESTAMP \space 'YYYY-MM-DD' \end{align*} \]
You must specify the full time stamp when using equal-to queries, or else no records will be returned. You could successfully query with the following statements if the table you query contains date records with these exact time stamps (2007-05-29 00:00:00 or 2007-05-29 12:14:25):
\(select \space * \space from \space table \space where \space date \space = \space '2007-05-29 \space 00:00:00';\)
or
\(select \space * \space from \space table \space where \space date \space = \space '2007-05-29 \space 12:14:25';\)
If you use other operators, such as greater than, less than, greater than or equal to, or less than or equal to, you don't need to designate the time, but you can if you want to be that precise. Both of the following statements would work:
\(select \space * \space from \space table \space where \space date \space < \space '2007-05-29';\)
\(select \space * \space from \space table \space where \space date \space < \space '2007-05-29 \space 12:14:25';\)
File geodatabases, shapefiles, coverages, and other file-based data sources
Dates in file geodatabases, shapefiles, and coverages are preceded with date.
File geodatabases support the use of a time in the date field, so this can be added to the expression:
\(Datefield \space = \space date \space 'yyyy-mm-dd \space hh:mm:ss'\)
Shapefiles and coverages do not support the use of time in a date field.
All SQL used by the file geodatabase is based on the SQL-92 standard.
Known limitations
Querying against a date on the left part (first table) of a join only works with file-based data sources, such as file geodatabases, shapefiles, and DBF tables. However, there is a possible workaround for working with nonfile-based data, such as enterprise data, as described below.
Querying against a date on the left part of a join will be successful when using the limited version of SQL developed for file-based data sources. If you are not using such a data source, you can force the expression to use this format. This can be done by making sure the query expression involves fields from more than one join table. For example, if a feature class and a table (FC1 and Table1) are joined and are both from an enterprise geodatabase, the following expressions will fail or return no data:
\[ \begin{align*} FC1.date \space = \space date \space \#01/12/2001\# \\FC1.date \space = \space date \space '01/12/2001' \end{align*} \]
To query successfully, you can create a query as follows:
\(FC1.date \space = \space date \space '01/12/2001' \space and \space Table1.OBJECTID \space > \space 0\)
Since the query involves fields from both tables, the limited SQL version will be used. In this expression, Table1.OBJECTID is always > 0 for records that matched during join creation, so this expression is true for all rows that contain join matches.
To ensure that every record with FC1.date = date '01/12/2001' is selected, use the following query:
\(FC1.date \space = \space date \space '01/12/2001' \space and \space (Table1.OBJECTID \space IS \space NOT \space NULL \space OR \space Table1.OBJECTID \space IS \space NULL)\)
This query will select all records with FC1.date = date '01/12/2001', whether or not there was a join match for each particular record.
Combining expressions
Compound expressions can be built by combining expressions with the AND and OR operators. For example, the following expression would select all the houses that have more than 1,500 square feet and a garage for three or more cars:
\(AREA \space > \space 1500 \space AND \space GARAGE \space > \space 3\)
When you use the OR operator, at least one side of the expression of the two separated by the OR operator must be true for the record to be selected, for example:
\(RAINFALL \space < \space 20 \space OR \space SLOPE \space > \space 35\)
Use the NOT operator at the beginning of an expression to find features or records that don't match the specified expression, for example:
\(NOT \space STATE\_NAME \space = \space 'Colorado'\)
NOT expressions can be combined with AND and OR. For example, this expression would select all the New England states except Maine:
\(SUB\_REGION \space = \space 'New \space England' \space AND \space NOT \space STATE\_NAME \space = \space 'Maine'\)
Calculations
Calculations can be included in expressions using the arithmetic operators +, -, *, and /. Calculations can be between fields and numbers, for example:
\(AREA \space >= \space PERIMETER \space * \space 100\)
Calculations can also be performed between fields. For example, to find the countries with a population density of less than or equal to 25 people per square mile, you could use this expression:
\(POP1990 \space / \space AREA \space <= \space 25\)
Operator precedence
Expressions are evaluated according to standard operator precedence rules. For example, the part of an expression enclosed in parentheses is evaluated before the part that isn't enclosed.
\(HOUSEHOLDS \space > \space MALES \space * \space (POP90\_SQMI \space + \space AREA)\)
You can add parentheses in SQL Edit mode by typing them, or use the Group and Ungroup commands in Clause mode to add or remove them.
Subqueries
A subquery is a query nested within another query and is supported by geodatabase data sources only. It can be used to apply predicate or aggregate functions or to compare data with values stored in another table. This can be done with the IN or ANY keyword. For example, this query would select only the countries that are not also listed in the indep_countries table:
\(COUNTRY\_NAME \space NOT \space IN \space (SELECT \space COUNTRY\_NAME \space FROM \space indep\_countries)\)
Coverages, shapefiles, and other nongeodatabase file-based data sources do not support subqueries. Subqueries that are performed on versioned enterprise feature classes and tables will not return features that are stored in the delta tables. File geodatabases provide the limited support for subqueries explained in this section, while enterprise geodatabases provide full support. For information on the full set of subquery capabilities of enterprise geodatabases, refer to your database management system documentation.
This query would return the features with a GDP2006 greater than the GDP2005 of any of the features contained in countries:
\("GDP2006" \space > \space (SELECT \space MAX("GDP2005") \space FROM \space countries)\)
Subquery support in file geodatabases is limited to the following:
  • Scalar subqueries with comparison operators. A scalar subquery returns a single value, for example:
    For file geodatabases, the set functions AVG, COUNT, MIN, MAX, and SUM can only be used within scalar subqueries.
  • EXISTS predicate, for example:
    \(EXISTS \space (SELECT \space * \space FROM \space indep\_countries \space WHERE \space "COUNTRY\_NAME" \space = \space 'Mexico')\)
Operators
The following is the full list of query operators supported by file geodatabases, shapefiles, coverages, and other file-based data sources. They are also supported by enterprise geodatabases, although these data sources may require different syntax. In addition to the operators below, enterprise geodatabases support other capabilities. See your database management system documentation for details.
Arithmetic operators
You use an arithmetic operator to add, subtract, multiply, and divide numeric values.
Operator
Arithmetic operator for multiplication
Arithmetic operator for division
Arithmetic operator for addition
Arithmetic operator for subtraction
Comparison operators
You use comparison operators to compare one expression to another.
Operator
Less than. It can be used with strings (comparison is based on alphabetical order), numbers, and dates.
Less than or equal to. It can be used with strings (comparison is based on alphabetical order), numbers, and dates.
Not equal to. It can be used with strings (comparison is based on alphabetical order), numbers, and dates.
Greater than. It can be used with strings (comparison is based on alphabetical order), numbers, and dates.
Greater than or equal to. It can be used with strings (comparison is based on alphabetical order), numbers, and dates.
[NOT] BETWEEN x AND y
Selects a record if it has a value greater than or equal to x and less than or equal to y. When preceded by NOT, it selects a record if it has a value outside the specified range. For example, this expression selects all records with a value greater than or equal to 1 and less than or equal to 10:
\("OBJECTID" \space BETWEEN \space 1 \space AND \space 10\)
This is the equivalent of the following expression:
\("OBJECTID" \space >= \space 1 \space AND \space OBJECTID \space <= \space 10\)
However, the expression with BETWEEN provides better performance if you're querying an indexed field.
[NOT] EXISTS
Returns TRUE if the subquery returns at least one record; otherwise, it returns FALSE. For example, this expression returns TRUE if the OBJECTID field contains a value of 50:
\(EXISTS \space (SELECT \space * \space FROM \space parcels \space WHERE \space "OBJECTID" \space = \space 50)\)
EXISTS is supported in file and enterprise geodatabases only.
[NOT] IN
Selects a record if it has one of several strings or values in a field. When preceded by NOT, it selects a record if it doesn't have one of several strings or values in a field. For example, this expression searches for four different state names:
\("STATE\_NAME" \space IN \space ('Alabama', \space 'Alaska', \space 'California', \space 'Florida')\)
IS [NOT] NULL
Selects a record if it has a null value for the specified field. When NULL is preceded by NOT, it selects a record if it has any value for the specified field.
x [NOT] LIKE y [ESCAPE 'escape-character']
Use the LIKE operator (instead of the = operator) with wildcards to build a partial string search. The percent symbol (%) means that anything is acceptable in its place: one character, a hundred characters, or no character. Alternatively, if you want to search with a wildcard that represents one character, use an underscore (_). If you need to access noncharacter data, use the CAST function. For example, this query returns numbers that begin with 8 from the integer field SCORE_INT:
\(CAST \space ("SCORE\_INT" \space AS \space VARCHAR) \space LIKE \space '8\%'\)
To include the percent symbol or underscore in your search string, use the ESCAPE keyword to designate another character as the escape character, which in turn indicates that a real percent sign or underscore immediately follows. For example, this expression returns any string containing 10%, such as 10% DISCOUNT or A10%:
\("AMOUNT" \space LIKE \space '\%10\$\%\%' \space ESCAPE \space '\$'\)
Logical operators
Operator
AND
Combines two conditions and selects a record if both conditions are true. For example, the following expression selects any house with more than 1,500 square feet and a garage for more than two cars:
\("AREA" \space > \space 1500 \space AND \space "GARAGE" \space > \space 2\)
OR
Combines two conditions and selects a record if at least one condition is true. For example, the following expression selects any house with more than 1,500 square feet or a garage for more than two cars:
\("AREA" \space > \space 1500 \space OR \space "GARAGE" \space > \space 2\)
NOT
Selects a record if it doesn't match the expression. For example, the following expression selects all states but California:
\(NOT \space "STATE\_NAME" \space = \space 'California'\)
Logical operators
String operators
Operator
Returns a character string that is the result of concatenating two or more string expressions.
\(FIRST\_NAME \space || \space MIDDLE\_NAME \space || \space LAST\_NAME\)
Functions
The following is the full list of functions supported by file geodatabases, shapefiles, coverages, and other file-based data sources. The functions are also supported by enterprise geodatabases, although these data sources may require different syntax or function names. In addition to the functions below, enterprise geodatabases support other capabilities. See your database management system documentation for details.
Date functions
Function
CURRENT_DATE
Returns the current date.
EXTRACT (extract_field FROM extract_source)
Returns the extract_field portion of the extract_source. The extract_source argument is a date-time expression. The extract_field argument can be one of the following keywords: YEAR, MONTH, DAY, HOUR, MINUTE, or SECOND.
CURRENT TIME
Returns the current time.
Date functions
String functions
Arguments denoted as string_exp can be the name of a column, a character string literal, or the result of another scalar function, where the underlying data type can be represented as a character type.
Arguments denoted as character_exp are variable-length character strings.
Arguments denoted as start or length can be a numeric literal or the result of another scalar function, where the underlying data type can be represented as a numeric type.
These string functions are 1 based; that is, the first character in the string is character 1.
Function
CHAR_LENGTH (string_exp)
Returns the length in characters of the string expression.
LOWER (string_exp)
Returns a string equal to that in string_exp, with all uppercase characters converted to lowercase.
POSITION (character_exp IN character_exp)
Returns the position of the first character expression in the second character expression. The result is an exact numeric with an implementation-defined precision and a scale of zero.
SUBSTRING (string_exp FROM start FOR length)
Returns a character string that is derived from string_exp, beginning at the character position specified by start for length characters.
TRIM (BOTH | LEADING | TRAILING trim_character FROM string_exp)
Returns the string_exp with the trim_character removed from the leading, trailing, or both ends of the string.
UPPER (string_exp)
Returns a string equal to that in string_exp, with all lowercase characters converted to uppercase.
String functions
Numeric functions
All numeric functions return a numeric value.
Arguments denoted as numeric_exp, float_exp, or integer_exp can be the name of a column, the result of another scalar function, or a numeric literal, where the underlying data type could be represented as a numeric type.
Function
ABS (numeric_exp)
Returns the absolute value of numeric_exp.
ACOS (float_exp)
Returns the arccosine of float_exp as an angle, expressed in radians.
ASIN (float_exp)
Returns the arcsine of float_exp as an angle, expressed in radians.
ATAN (float_exp)
Returns the arctangent of float_exp as an angle, expressed in radians.
CEILING (numeric_exp)
Returns the smallest integer greater than or equal to numeric_exp.
COS (float_exp)
Returns the cosine of float_exp, where float_exp is an angle expressed in radians.
FLOOR (numeric_exp)
Returns the largest integer less than or equal to numeric_exp.
LOG (float_exp)
Returns the natural logarithm of float_exp.
LOG10 (float_exp)
Returns the base 10 logarithm of float_exp.
MOD (integer_exp1, integer_exp2)
Returns the remainder of integer_exp1 divided by integer_exp2.
POWER (numeric_exp, integer_exp)
Returns the value of numeric_exp to the power of integer_exp.
ROUND (numeric_exp, integer_exp)
Returns numeric_exp rounded to integer_exp places to the right of the decimal point. If integer_exp is negative, numeric_exp is rounded to |integer_exp| places to the left of the decimal point.
SIGN (numeric_exp)
Returns an indicator of the sign of numeric_exp. If numeric_exp is less than zero, -1 is returned. If numeric_exp equals zero, 0 is returned. If numeric_exp is greater than zero, 1 is returned.
SIN (float_exp)
Returns the sine of float_exp, where float_exp is an angle expressed in radians.
TAN (float_exp)
Returns the tangent of float_exp, where float_exp is an angle expressed in radians.
TRUNCATE (numeric_exp, integer_exp)
Returns numeric_exp truncated to integer_exp places to the right of the decimal point. If integer_exp is negative, numeric_exp is truncated to |integer_exp| places to the left of the decimal point.
Numeric functions
The CAST function
The CAST function converts a value to a specified data type. The syntax is as follows:
CAST (exp AS data_type)
The argument exp can be the name of a column, the result of another scalar function, or a literal. Data_type can be any of the following keywords, which can be specified in uppercase or lowercase: CHAR, VARCHAR, INTEGER, SMALLINT, REAL, DOUBLE, DATE, TIME, DATETIME, NUMERIC, or DECIMAL.
