Create a stand-alone ArcGIS Server site using the Cloud Builder for AWS app
Use the ArcGIS Enterprise Cloud Builder for Amazon Web Services (AWS) app to prepare the resources you need and create a stand-alone ArcGIS GIS Server, ArcGIS Image Server, or ArcGIS GeoEvent Server site on Amazon Web Services.
Prerequisites
You need the following before you can create an ArcGIS Server site using ArcGIS Enterprise Cloud Builder for AWS:
  • Obtain an AWS account. Ensure that you have the AWS account credentials, such as an Access Key ID and Secret Access Key, and that they have access to required AWS services.
  • ArcGIS Enterprise Cloud Builder for AWS uses a Microsoft Windows Server and Ubuntu Server machine images by default. You may need to accept terms in the AWS Marketplace to use these images if you have not used them before.
  • Download and extract ArcGIS Enterprise Cloud Builder for Amazon Web Services.
  • Obtain an ArcGIS Server license file for the role you require.
  • Purchase an SSL certificate from a certifying authority, and configure it for the domain you will use in your deployment.
Create a deployment
When you use the ArcGIS Enterprise Cloud Builder for AWS app, an Amazon Simple Storage Service (S3) bucket is created in the Amazon us-east-1 region to store resources for the deployment. Cloud Builder manages this deployment bucket. Do not delete, rename, or modify this S3 bucket or its contents, as doing so can result in the deployment being out of sync with Cloud Builder.
After you complete the prerequisites, follow these steps to create a stand-alone ArcGIS Server site:
  1. Open the ArcGIS Enterprise Cloud Builder for AWS app from the Start menu on your computer.
  2. Connect to your Amazon Web Services account by doing one of the following:
    • Provide the access key ID and secret access key for your account and click Sign In.
    • Choose the Amazon Web Services profile you defined on the machine where you're running Cloud Builder and click Sign In. See the AWS documentation for information about configuring a local profile.
    Once Cloud Builder connects to your AWS account, it proceeds to the Deployment page.
  3. Click Add Deployment.
    The Choose a Deployment Type page appears.
  4. On the Choose a Deployment Type page, select Stand-alone ArcGIS Server and click Next.
  5. On the Define the Stand-alone ArcGIS Server Deployment page, choose the ArcGIS Server role you require (and for which you have a license).
  6. If you are creating a stand-alone ArcGIS GIS Server site or ArcGIS Image Server site, you can include an enterprise geodatabase.
  7. Click Next.
    The General Configuration Parameters Details page appears.
  8. Choose the AWS Region value where you want the resources deployed.
  9. Choose the operating system to be used on the Amazon Elastic Compute Cloud (EC2) instances: either Ubuntu or Windows.
    If you included ArcGIS Notebook Server in the deployment, Ubuntu is selected by default and cannot be changed.
    If you use a custom Amazon Machine Image, the Ubuntu option indicates any supported Linux operating system on that image; you aren't forced to use Ubuntu.
  10. Provide a name for the deployment.
    This name must be unique. When Cloud Builder verifies that the name is unique, a verified symbol appears.
  11. Provide the ID of a custom Amazon Machine Image in the AMI ID field, or leave the field blank to use the default AMI for the operating system you chose for this deployment.
    If you deploy on an EC2 instance running Ubuntu in Amazon Web Services GovCloud, you must specify an AMI ID; you cannot leave this field blank.
  12. Specify an Amazon Virtual Private Cloud (VPC) to use for the deployment's virtual network.
    • If the VPC exists, choose it from the drop-down menu.
    • To create a VPC, click the Create New VPC button . Provide a name for the VPC, use the default range of IP address or specify a range of IP addresses in a Classless Inter-Domain Routing (CIDR) block, and click Create. Each subnet ID will be created in different, randomly selected AWS zones. See the AWS documentation for information about VPCs and CIDR blocks.
    • If you create a VPC outside of Cloud Builder, such as in AWS Management Console, while Cloud Builder is open, click the Refresh VPCs button to update the VPC ID list.
  13. If you choose an existing VPC, ensure that there are two different subnets in the Subnet1 ID and Subnet2 ID drop-down menus.
    Subnet1 ID and Subnet2 ID values should be in different availability zones in the AWS region in which you are creating the deployment.
  14. Specify an Amazon EC2 Key Pair to use for the deployment's virtual network.
    • If the key pair exists, choose it from the drop-down menu.
    • To create a key pair, click the Create New Key Pair button , provide a name for the key pair, and click Create. See the AWS documentation for information about Amazon EC2 Key Pairs.
    • If you create key pairs outside of Cloud Builder, such as in AWS Management Console, while Cloud Builder is open, click the Refresh Key Pairs button to update the Key Pair list.
  15. Click Next to proceed to the Configure Elastic Load Balancer (ELB) page.
  16. Choose or upload the SSL certificate (.pfx) that is mapped to your domain.
    • If the SSL certificate exists in the Amazon S3 bucket in your account—for example, if you uploaded the certificate when you created another deployment—choose it from the SSL Certificate drop-down list.
    • If you need to upload your certificate, click the Upload New SSL Cert button , browse to the location on your local disk where the certificate file resides, provide the password for your .pfx file, and click Create.
  17. If you chose the certificate from the SSL Certificate drop-down menu, provide the certificate's password in the SSL Certificate Password field.
  18. Choose or create an elastic load balancer for your site. Load balancers can be used for only one site. If all the load balancers in the Elastic Load Balancer (ELB) list are in use, click the Create New ELB button , provide a name, and click Create.
  19. In the Site Domain field, provide the name of the domain that is specified in your SSL certificate. Click Validate to ensure you typed the correct domain.
  20. Click Next to proceed to the ArcGIS Credentials page.
  21. Provide a user name and password for the ArcGIS Server primary site administrator. Type the password again in the Re-Enter Password field to ensure you typed the password you intended.
    The password for your primary site administrator must be at least eight alphanumeric characters. The password can also contain dots (.). The password cannot contain any other special characters or spaces.
    If your deployment uses EC2 instances running Windows, proceed to the next step. If your deployment uses EC2 instances running Ubuntu, proceed to step 23.
  22. Provide a password for the Windows account that will be used to run the ArcGIS Server service account. The account name is always arcgis. Type the password again in the Re-Enter Password field to ensure you typed the password you intended.
    The ArcGIS Server service account follows Microsoft Windows password enforcement policies.
  23. Click Next to proceed to the next page.
  24. Provide information for the Amazon EC2 instances to be used in your site.
    1. Choose an instance type from the Instance Type drop-down list. The list contains only those types that are supported for use with an ArcGIS Server site, but you must have licensing appropriate for the number of cores present in the type you choose. Not all instance types are supported in all AWS regions. See the AWS calculator for specifications and pricing for each instance type. If no price is listed for an instance type in the selected region, that instance type is not available.
    2. In the Drive Size Root field, specify the size, in GB, for the root drive on the ArcGIS Server instances.
    3. From the Number of ArcGIS Server Instances drop-down menu, choose how many EC2 instances to include in the ArcGIS Server site.
      ArcGIS GeoEvent Server sites can contain only one instance.
    4. For an ArcGIS GeoEvent Server site, choose the EC2 instance type to use for the file server instance.
    5. In the File Server Drive Size Root field, type the size you want, in GB, for the root drive on the file server instance.
  25. Choose or upload your ArcGIS Server license. Ensure the license is correct for the ArcGIS Server role you chose to create and is for the same ArcGIS release as the release of Cloud Builder you are using.
    • If your ArcGIS Server license file already exists in the S3 deployment bucket in your account—for example, if you uploaded the file when you created another deployment—choose the license file from the license drop-down list.
    • If you need to upload the license file to the S3 deployment bucket, click the Upload New Server License button , browse to the file on your local disk, and click Upload.
  26. If you are creating an ArcGIS GIS Server site or ArcGIS Image Server site, choose the location for the ArcGIS Server configuration store from the Configuration Store Type drop-down menu.
    • Cloud Store—If you need a highly available ArcGIS Server site, choose a cloud store for the configuration store. This option stores the configuration store and server directories in Amazon DynamoDB and S3.
    • File System—Choose a file system if you want the configuration store and server directories on an EC2 instance.
    ArcGIS GeoEvent Server sites always use a file system for their configuration stores.
  27. Provide a name for the ArcGIS Web Adaptor in the Server Web Adaptor Name field.
  28. Click Next.
    If you included an enterprise geodatabase, the ArcGIS Enterprise Geodatabase Configuration Details page opens. Proceed to the next step. If you did not include an enterprise geodatabase, proceed to step 31.
  29. Choose false from the Is Managed drop-down list.
Legacy:
Managed databases are no longer supported.
  1. Choose the type of Amazon Relational Database Service (RDS) to use to store the geodatabase, the instance class and storage space available for the instance, and the version or engine version of the instance. Also provide a user name and password for the RDS master user.
    If your deployment is on Windows, you can choose Amazon Relational Database Service (RDS) for SQL Server, Amazon RDS for PostgreSQL, or Amazon Aurora (PostgreSQL-compatible edition). If your deployment is on Ubuntu, you can choose Amazon RDS for PostgreSQL or Amazon Aurora (PostgreSQL-compatible edition).
    For information about Amazon database services, see the AWS documentation.
  2. Click Next to proceed to the deployment summary.
  3. Review the deployment summary.
  4. When the summary information is correct, click Create.
    Do not close the deployment page or Cloud Builder until creation completes.
    Once deployment completes, you can view the deployment logs by clicking the log links. Log files are stored in location\Logs\Log in the directory where you extracted Cloud Builder. Error log files are stored in location\Logs\ErrorLog. Click Close to open a list of all your deployments.
When the site is created successfully, the deployment status shows Completed, and you can open ArcGIS Server Manager for the site by clicking the link for the deployment type. Sign in to Server Manager using the site administrator credentials you provided in step 21.
