Localization and ArcGIS Enterprise tools for AWS
ArcGIS Enterprise tools for Amazon Web Services (AWS) default to using Amazon Machine Images (AMI) with the operating system language set to English.
To create a deployment that uses a language other than English, specify the ID of an Amazon Machine Image that is configured with a different locale when you use ArcGIS Enterprise tools for AWS to create deployments, and install ArcGIS language packs to localize ArcGIS.
Install additional operating system languages
If the operating system language you want to use is not included on the Microsoft Windows AMI used to create your deployment, you can download and install the language pack from Microsoft.
Install ArcGIS language packs
ArcGIS language packs are available for ArcGIS Pro shortly after the initial product releases in English. You can apply a language pack to view the interface in a language other than English. Available languages vary by component.
The Portal for ArcGIS and ArcGIS Data Store installations include language-specific resources that allow you to localize the portal website interface and the ArcGIS Data Store Configuration wizard, respectively; you do not need to install an additional language pack for these interfaces. However, language packs are available that allow you to view the Portal for ArcGIS and ArcGIS Data Store help in languages other than English. See Localize Portal for ArcGIS and Localize ArcGIS Data Store to see which languages are available.
The ArcGIS Server installation includes language-specific resources for ArcGIS Server Manager. You do not need to install a language pack for ArcGIS Server Manager. However, to view logs and messages in languages other than English, you must install the ArcGIS Server Resource Language Pack. See Localize ArcGIS Server for more information.
You can download any of the language packs mentioned above from My Esri and apply them to the ArcGIS software installations on your Amazon Elastic Compute Cloud instances.
Change the operating system language
After you install the language packs for ArcGIS Server and ArcGIS Pro, change the language of the operating system. If you need instructions, see the documentation from your operating system provider.
Language displayed by each software component
ArcGIS Server Manager and the Services Directory use the language set for your web browser. See Configuring the display language for ArcGIS Server Manager for details.
After Portal for ArcGIS is installed, the portal administrator configures the language for the portal website. However, individual members of the organization can customize their profiles to display the portal website in the language of their choosing.
The ArcGIS Data Store Configuration wizard uses the language set for your web browser.
After installing a language pack, ArcGIS Pro honors the display language you set for the operating system.
The ArcGIS Enterprise Cloud Builder for Amazon Web Services app is only available in English at this time.
