Manage a deployment using the Cloud Builder for AWS app
Once you create a deployment using ArcGIS Enterprise Cloud Builder for Amazon Web Services (AWS), the deployment is listed on the Deployments page of the Cloud Builder app. From here, you can create a similar deployment from one of your existing deployments, or perform one of the tasks related to your deployment, as described in the following sections.
Deployments you create outside of ArcGIS Enterprise Cloud Builder for AWS (either the app or command line interface) will not appear in Cloud Builder.
Stop and start a deployment
This stops all Amazon Elastic Compute Cloud (EC2) machines. Stopping the EC2 machines when they are not in use can save you some money, but it can only be done if no one needs to use your deployment.
Follow these steps to use Cloud Builder to stop or start one of your deployments on AWS.
Open the ArcGIS Enterprise Cloud Builder for AWS app from the Start menu on your computer.
Connect to your AWS account by doing one of the following:
Provide the access key ID and secret access key for your account and click Sign In.
Choose the AWS profile you defined on the machine where you're running Cloud Builder and click Sign In. See the AWS documentation for information about configuring a local profile.
Once Cloud Builder connects to your AWS account, it proceeds to the Deployment page.
To stop all the machines in a deployment, click the Stop the deployment button
.This button is available only if your deployment created successfully and is currently started.
The Deployment Summary page appears.
Review the summary information to confirm you are stopping the correct deployment and click Stop.
Caution:
Do not close the progress window or Cloud Builder.
If EC2 instances in the deployment participate in an Auto Scaling group, the closing of the progress window does not indicate the instances are stopped. The process that stops the EC2 instances must also detach the instances from the Auto Scaling group, and that can take up to 10 minutes to complete. Therefore, if the EC2 instances in the deployment participate in an Auto Scaling group, you must wait at least 10 minutes before you proceed with the next step.
When all EC2 instances in the deployment are stopped, the job status page appears. If the job succeeded, click Close to return to the Deployments page. If the job failed, click View Process Log to view errors related to the job.
To start all the machines in a deployment when you need them, click the Start the deployment button
.This button is available only if your deployment is stopped.
Review the summary information to confirm you are starting the correct deployment and click Start.
Caution:
When all EC2 machines in the deployment are started, the job status page appears. If the job succeeded, click Close to return to the Deployments page. If the job failed, click View Process Log to view errors related to the job.
View information and access a deployment
You can view summary information about your deployment and access logs, the portal, and ArcGIS Server Manager from the Deployments page of ArcGIS Enterprise Cloud Builder for AWS. In addition to the deployment name and the Amazon region in which it was created, you can see the following information for each deployment:
Status |
Indicates whether the deployment is in the process of being created (InProgress), created successfully (Completed), or failed to create (Failed). |
Created Date |
The day deployment creation completed. |
Type |
Indicates whether the deployment is a single-machine or highly available installation of Portal for ArcGIS, or stand-alone ArcGIS Server site. If you click the type text for an ArcGIS Enterprise deployment, the portal website opens in your default browser. If you click the type text for an ArcGIS GIS Server or ArcGIS Image Server site, ArcGIS Server Manager for that site opens in your default browser. If you click the type text for an ArcGIS GeoEvent Server site, GeoEvent Server Manager opens in your default browser. |
ArcGIS Version |
The version of the Esri ArcGIS Enterprise Amazon Machine Image used to create your deployment. |
Roles |
Provides a list of the types of ArcGIS Server sites in the deployment. If the deployment is a stand-alone ArcGIS Server site, only one role will be listed. If the deployment is an ArcGIS Enterprise deployment, the list of roles will include the hosting server plus any federated servers you included when you created your deployment. Click the role text to open ArcGIS Server Manager for that ArcGIS Server site. |
Summary |
Click View to open the Deployment Summary. Click Download to export the summary as a JSON file that you can use to create other deployments using the ArcGIS Enterprise Cloud Builder Command Line Interface for AWS utility. |
Logs |
Click Deployment Logs to access links to the AWS CloudFormation and CloudWatch log files available for your deployment. |
Click the arrow (>) next to the name of the deployment for which you want to view information.
Use available links (green text) to view or download the deployment summary, view deployment logs, open the portal website, or open ArcGIS Server Manager for specific ArcGIS Server sites.
Delete a deployment
If a deployment fails to create successfully or you no longer need a deployment, delete it.
Deleting a deployment from the Cloud Builder app deletes resources such as the AWS CloudFormation stacks, CloudWatch logs, and the Amazon Simple Storage Service (S3) bucket and DynamoDB table for your cloud store (if you specified Cloud Store for the Configuration Store in the Cloud Builder app). The following assets are not deleted:
Elastic load balancers
Elastic IP addresses
The S3 bucket used to store license files and SSL certificates
The Amazon Virtual Private Cloud (VPC) and subnets
SSL certificates configured in AWS Certificate Manager
Caution:
You cannot recover a deleted deployment.
Follow these steps to delete a deployment and its resources:
Click the Delete the deployment button
next to the name of the deployment you want to delete.The Deployment Summary page appears.
Review the summary information to confirm you are deleting the correct deployment and then click Delete.
Caution:
