Prepare deployment resources using the Cloud Builder CLI for AWS PREP command
The ArcGIS Enterprise Cloud Builder Command Line Interface (CLI) for Amazon Web Services (AWS) PREP command automates several essential prerequisite tasks for an ArcGIS Enterprise deployment on AWS. After preparing a JSON file to store parameter values, run the PREP command to do the following:
Create a network stack and Amazon Simple Storage Service (S3) bucket for the deployment if a bucket does not already exist. The S3 bucket is managed by Cloud Builder.
Create an Amazon Virtual Private Cloud (VPC) for the deployment.
Upload all necessary authorization files and SSL certificates to the S3 bucket.
Import your SSL certificate to AWS Certificate Manager.
You only need to run the PREP command again in the following circumstances:
You want to create another deployment in a different region or on a separate network.
You have more than one AWS account and you want to create deployments for different accounts.
You need to update the SSL certificate for the deployment.
Your ArcGIS licenses expired, and you need to upload new license files.
The PREP command returns information to a text file on your local drive.
Download and install ArcGIS Enterprise Cloud Builder for Amazon Web Services.
See Install ArcGIS Enterprise Cloud Builder for Amazon Web Services for instructions.
The ArcGIS Enterprise Cloud Builder CLI for AWS utility and its supporting files and samples are installed to the location you specify during installation.
Move your SSL certificate (
.pfx) and license files (.prvcor.ecpfor ArcGIS Server, and.jsonfor Portal for ArcGIS) to the machine where you just extracted the ArcGIS Enterprise Cloud Builder CLI for AWS utility.To modify and use the sample
.jsonfiles provided with the utility, make copies of the files in theConfiguration\PrepSamplesfolder.
Important:
You must place the copies in a subfolder under the Configuration folder.
Before running the
PREPcommand with the ArcGIS Enterprise Cloud Builder CLI for AWS utility, modify one of the sample preparation files or create your own.jsonpreparation file.To create a VPC and S3 bucket and upload your SSL certificate and ArcGIS license files in one step, modify your copy of the
allprep.jsonsample file, or create your own.jsonpreparation file that includes the parameters shown in the following example. Open the file in a text editor, set the parameters to the information specific to your account and deployment, and save your changes. For a description of each parameter, see ArcGIS Enterprise Cloud Builder CLI for AWS parameters.In this example, the utility connects to the AWS account using the account's access key and secret access key. License files for all possible component types and an SSL certificate will be copied from the specified local folders and placed in the S3 deployment bucket that is managed by ArcGIS Enterprise Cloud Builder for AWS. A VPC will also be created in availability zones ap-northeast-1b and ap-northeast-1a.
Note that it is possible that all your ArcGIS Server licenses are in the same file.
{ "AWSCredentials": { "AWSAccessKey": "ABCDEFGHIMI4YCPABC", "AWSSecretKey": "ABCDLZDYIzZuXHlWHOPhMqrTmABCD", "AWSRegion": "ap-northeast-1" }, "NetworkStack": { "StackName": "EnterpriseVPC", "AZs": "ap-northeast-1b,ap-northeast-1a", "CreateFlag":true }, "ArcGISEnterpriseFiles": { "PortalLicense": "C:\\ArcGISLicenses\\Your_Portal_License.json", "ServerLicense": "C:\\ArcGISLicenses\\Your_GIS_Server_License.prvc", "NotebookServerLicense": "C:\\ArcGISLicenses\\Your_Notebook_Server_License.prvc", "MissionServerLicense": "C:\\ArcGISLicenses\\Your_Mission_Server_License.prvc", "ImageServerLicense": "C:\\ArcGISLicenses\\Your_Image_Server_License.prvc", "RasterAnalyticsLicense": "C:\\ArcGISLicenses\\Your_Image_Server_License.prvc", "ImageHostingLicense": "C:\\ArcGISLicenses\\Your_Image_Server_License.prvc", "GeoEventLicense": "C:\\ArcGISLicenses\\Your_GeoEvent_Server_License.prvc", "WorkflowManagerLicense": "C:\\ArcGISLicenses\\Your_Workflow_Manager_License.prvc", "KnowledgeServerLicense": "C:\\ArcGISLicenses\\Your_Knowledge_Server_Licesne.prvc", "SSLCertificateFile": "C:\\MyCerts\\wildcard_yourdomain_com.pfx", "SSLCertPassword": "changeit" } }Open Command Prompt and change directories (
cd) to the folder where you installed the ArcGIS Enterprise Cloud Builder CLI for AWS utility and files. Run the utility with thePREPcommand:cloudbuilder.exe PREP -j <prepfilename.json>For example, to use a file named
myallprep.jsonthat you placed in a new prep file subfolder of the ArcGIS Enterprise Cloud Builder CLI for AWS Configuration folder, type the following:cloudbuilder.exe PREP -j Configuration\MyPrepFiles\myallprep.jsonLocate the ArcGIS Enterprise Cloud Builder CLI for AWS utility's output file (in the format
PREP_<date><time>.json) in theCloudBuilder\AWS\CLI\Outputfolder on your local drive.This file contains information you need when you create the deployment.
The output from running the example file in step 5 would include an ID and two subnet IDs for a new VPC, the S3 bucket name, and the unique Amazon Resource Name (ARN) created for your SSL certificate.
"NetworkStack": { "VPCId": "vpc-z9fb11ba", "subnet1": "subnet-z319acee", "subnet2": "subnet-f4fc658f" }, "DeploymentDetails": { "PortalLicense": "resources/licenses/<version>/portal/Your_Portal_License.json", "ServerLicense": "resources/licenses/<version>/server/Your_GIS_Server_License.prvc", "NotebookServerLicense": "resources/licenses/<version>/notebookserver/Your_Notebook_Server_License.prvc", "MissionServerLicense": "resources/licenses/<version>/missionserver/Your_Mission_Server_License.prvc", "ImageServerLicense": "resources/licenses/<version>/image/Your_Image_Server_License.prvc", "RasterAnalyticsLicense": "resources/licenses/<version>//rasteranalytics/Your_Image_Server_License.prvc", "ImageHostingLicense": "resources/licenses/<version>//imagehosting/Your_Image_Server_License.prvc", "GeoEventLicense": "resources/licenses/<version>/geoevent/Your_GeoEvent_Server_License.prvc", "WorkflowManagerLicense": "resources/licenses/<version>/workflow/Your_Workflow_Manager_License.prvc", "KnowledgeServerLicense": "C:\\ArcGISLicenses\\Your_Knowledge_Server_Licesne.prvc", "SSLCertificateFile": "resources/sslcerts/wildcard_yourdomain_com.pfx", "SSLCertificateARN": "arn:aws:acm:ap-northeast-1:123456789123:certificate/xxxxxxxx-xxxx-xxxx-xxxx-xxxxxxxxxxxx", "DeploymentBucket": "esri-aws-1234567890" }The contents of the output file will vary depending on what information you provided in the configuration file.
You're now ready to create a deployment using the command line interface.
