Add databases to an ArcGIS Server site on Azure
To store service data, you can add one of the following types of databases to stand-alone or federated ArcGIS Server sites on Microsoft Azure using ArcGIS Enterprise Cloud Builder for Microsoft Azure:
The database can serve one of the following roles:
A registered database—You can register a database to store simple source data on Azure. You can connect to the database from an ArcGIS Pro client running in the same region on Azure to publish services that reference this data.
A registered database that contains a geodatabase—You can add an enterprise geodatabase to store source data on Azure. To create datasets in the geodatabase, connect to it from an ArcGIS Pro client running in the same region on Azure. Once the geodatabase contains data, you can connect to it from this client and publish services that reference this data.
License:
Registered databases can be used with ArcGIS GIS Server or ArcGIS Image Server sites. The registered database you use with an ArcGIS Image Server site must contain a geodatabase.
To move data to a registered database or geodatabase, see the Microsoft Azure documentation for information on loading data to an Azure database as a service or database on a virtual machine.
Create and register a database
To create a database and register it with an ArcGIS Server site on Azure, complete the following steps:
Start ArcGIS Enterprise Cloud Builder for Microsoft Azure.
Sign in to Microsoft Azure.
If the site with which you want to register the database is in the Microsoft Azure Government cloud, check U.S. Government Cloud.
Choose an Azure Active Directory tenant, click Next, choose the subscription that contains the ArcGIS Server site to which you will add a registered database, and click Next.
Ensure V2 Sites is selected.
In the Deployments list, click the Register a database, object store, or cloud store button next to the ArcGIS Server site or ArcGIS Enterprise deployment.
Ensure that the Register database option is selected at the top of the window.
Choose the database service or database to use.
Microsoft Azure SQL Database
Microsoft Azure SQL Managed Instance Database
Microsoft Azure Database for PostgreSQL
Microsoft SQL Server
Choose what to register:
To register an enterprise geodatabase to use as a data source for a GIS Server site, check the Enable as geodatabase check box.
To register a database to use as a data source for a GIS Server site, uncheck the Enable as geodatabase check box.
To register an enterprise geodatabase as the raster store for an ArcGIS Image Server site, check Enable as geodatabase and Register as a raster store. The option to register a raster store is only available for ArcGIS Image Server sites.
In the Site Administrator section, type the username and password for the primary site administrator account for the ArcGIS Server site.
Optionally, add a user-assigned managed identity for authentication purposes when accessing a database service.
Click the Add button
in the Assign User Assigned Managed Identity section.Choose the subscription that contains the identity.
Choose the user-assigned managed identity from the Identity drop-down list and click Add.
Click Next.
If you chose Microsoft Azure SQL Database, provide the following information to create the database server and database:
Click the Create button
next to Database Server.Type a name for the server.
Provide the username and password for the database server administrator.
Click Create.
next to Database and type a name for the database.Click Check Availability to confirm the database name is unique.
Choose a performance level from the Type drop-down menu.
For information on performance levels available for Microsoft Azure SQL Database, see the Microsoft Azure documentation.
Click Create.
If you chose Microsoft Azure SQL Managed Instance Database, provide the following information:
Choose or create a subnet for the instance.
Choose an instance type for the database server.
Specify a storage size for the database server.
You can either type a number or use the up or down arrows to change the size from the default.
Type the username and password for the database server administrator.
Click Create.
Click Create.
If you chose Microsoft Azure Database for PostgreSQL, provide the following information to create the database server and database:
Choose the version of Microsoft Azure Database for PostgreSQL to use.
Click Create.
Click Create.
If you chose Microsoft SQL Server, provide the following information to create the database server and database:
In the Database Server field, type a name for the virtual machine.
Click Machine Options next to Database Server.
Choose an instance type from the Image drop-down menu.
To change specifications for the database server size, click the Configure Virtual Machine button
.For the OS Disk Type value, choose one of the following drive types for the operating system disk:
SSD—A premium solid-state drive
Standard SSD—A standard solid-state drive
From the Machine Type drop-down menu, choose the type of virtual machine to use.
Choose the size, in gibibytes (GiB), of the operating system disk.
To add another drive to the virtual machine to store data, check Add a data disk? and choose the disk type and size for the data drive.
Click Apply to close the Configure Virtual Machine dialog box.
Click Apply to close the Database Server Machine Options dialog box.
Type a name for the database.
In the Database Administrator section, type the username and password to be used for the database administrator.
If you checked the Enable as geodatabase option, this same password will be used for the geodatabase administrator (sde) account.
In the Database User section, type the username and password to be used for a data owner.
This is the account that services will use to authenticate with the database to access the data.
Click Next to proceed to the Deployment Options settings.
Choose or create a storage account for the deployment. To create a storage account, do the following:
Provide a name for the storage account.
Names must be unique. Click Check availability to confirm that the storage account name is unique.
Choose the Azure region in which to create the storage account.
Choose an existing resource group for the storage account, or click the Create button
to create one.Choose the type of redundancy for the storage account: Geo-Redundant, Locally Redundant, or Read-Access Geo-Redundant.
See Azure Storage redundancy in the Microsoft Azure documentation for a description of each option.
Specify the kind of Azure storage account to use: Storage (a legacy account type), StorageV2 (a basic account type), or BlobStorage (only supports Azure Blob Storage).
Once the storage account is created, click Close.
Click Next to view a summary of your settings.
Review the settings in the Summary pane. If anything needs to be changed, click Back to go to the page where you need to change the information.
Tip:
Click Save summary to save the site configuration information to a text file so you can refer to it for information such as usernames or machine names.
Click Generate cost estimate to calculate the approximate cost of the Azure infrastructure you will use in the deployment. When you finish generating the estimate, click Close.
This estimate does not include data storage costs.
Click Save automation artifacts to export a
.zipfile containing information and files you can use in automation scripts to re-create this deployment, and do the following:Browse to a location on the local disk and provide a name for the archive file.
Choose the type of automation format with which you will use the artifacts.
Click Generate to create the file.
When all settings are correct and you have saved the files you need, click Finish to create the database (and geodatabase if applicable), and register the database with the ArcGIS Server site.
Use an existing database
If you have an existing database instance in Azure that you want to register with an ArcGIS Server site that you created using Cloud Builder, provide the following when you register the instance using Cloud Builder:
The name of the existing database server
The database administrator** username and password
To register an existing SQL Server instance on Azure, you must also do the following to allow communication with the instance:
Change the SQL Server instance's authentication method to SQL Authentication.
Create or enable a SQL Server-authenticated database administrator account.
Open port 1433 in the virtual machine's firewall.
See the Microsoft documentation for instructions.
