Deployment management using Cloud Builder for Azure
A new version of ArcGIS Enterprise Cloud Builder for Microsoft Azure is available with each ArcGIS release. To manage the deployments that you create using ArcGIS Enterprise Cloud Builder for Microsoft Azure, the deployment and Cloud Builder versions must match. For example, to add machines to 12.2 deployments or register a database with an 12.2 deployment, you must use the 12.2 version of ArcGIS Enterprise Cloud Builder for Microsoft Azure.
Tip:
You can have different versions of ArcGIS Enterprise Cloud Builder for Microsoft Azure on the same machine, allowing you to manage version-specific deployments.
The one management task that you must complete using a newer version Cloud Builder is upgrading a deployment. After you upgrade using Cloud Builder, the deployment and Cloud Builder versions again match, and you can continue to use Cloud Builder to perform the following management tasks for the upgraded deployments:
